QtxPopupMgr::PopupCreator Class Reference
Popup menu actions creator. More...
Inheritance diagram for QtxPopupMgr::PopupCreator:
 PopupCreator (QtxActionMgr::Reader *, QtxPopupMgr *)
virtual ~PopupCreator ()
virtual int append (const QString &, const bool, const ItemAttributes &, const int)
 Create and append new action to the action manager. More...
virtual QString rule (const ItemAttributes &, const QtxPopupMgr::RuleType=VisibleRule) const
 Get the rule for the menu item. More...
- Public Member Functions inherited from QtxActionMgr::Creator
 Creator (QtxActionMgr::Reader *)
virtual ~Creator ()
Reader * reader () const
 Get actions reader. More...
virtual int append (const QString &, const bool, const ItemAttributes &, const int)=0
 Create (and probably append to the action manager) new action. More...
virtual void connect (QAction *) const
 Connect action to some specific slot(s). More...
virtual bool loadPixmap (const QString &, QPixmap &) const
 Load pixmap from the file. More...
QtxPopupMgr * myMgr
- Static Protected Member Functions inherited from QtxActionMgr::Creator
static int intValue (const ItemAttributes &, const QString &, const int)
 Get integer attribute value from the attribute map. More...
static QString strValue (const ItemAttributes &, const QString &, const QString &=QString())
 Get string attribute value from the attribute map. More...
Used by Reader to create actions by reading descriptions from the file and fill in the action manager with the actions.
◆ PopupCreator()
QtxPopupMgr::PopupCreator::PopupCreator ( QtxActionMgr::Reader *  r,
QtxPopupMgr *  mgr
rmenu action reader
mgrpopup menu manager
◆ ~PopupCreator()
QtxPopupMgr::PopupCreator::~PopupCreator ( )
◆ append()
int QtxPopupMgr::PopupCreator::append ( const QString &  tag,
const bool  subMenu,
const ItemAttributes &  attr,
const int  pId
tagitem tag name
subMenutrue if this item is submenu
attrattributes map
pIdparent action ID
menu action ID
Implements QtxActionMgr::Creator.
References QtxPopupMgr::EnableRule, QtxActionMenuMgr::insert(), QtxActionMgr::registerAction(), QtxPopupMgr::rule(), QtxActionMgr::separator(), QtxPopupMgr::ToggleRule, and QtxPopupMgr::VisibleRule.
◆ rule()
QString QtxPopupMgr::PopupCreator::rule ( const ItemAttributes &  ,
const QtxPopupMgr::RuleType  = VisibleRule
Default implementation returns empty rule.
attrattributes map
ruleTyperule type (QtxPopupMgr::RuleType)
rule for the menu item corresponding to the rule type
◆ myMgr
QtxPopupMgr* QtxPopupMgr::PopupCreator::myMgr
