QtxActionMgr::XMLReader Class Reference
XML file reader. More...
#include <QtxActionMgr.h>
Inheritance diagram for QtxActionMgr::XMLReader:
 XMLReader (const QString &, const QString &, const QString &)
virtual ~XMLReader ()
virtual bool read (const QString &, Creator &) const
 Read the file and fill and action manager with actions by using actions creator. More...
- Public Member Functions inherited from QtxActionMgr::Reader
 Reader ()
virtual ~Reader ()
QStringList options () const
 Get the list of options. More...
QString option (const QString &, const QString &=QString()) const
 Get option value. More...
void setOption (const QString &, const QString &)
 Set option value. More...
virtual bool read (const QString &, Creator &) const =0
 Read the file and fill and action manager with actions by using help actions creator. More...
virtual void read (const QDomNode &, const int, Creator &) const
 Read XML mode and create an item if requied. More...
virtual bool isNodeSimilar (const QDomNode &, const QString &) const
 Check node name correspondance to some pattern. More...
XML file reader.
This class is used to read files of XML format to create actions and fill an action manager with actions automatically.
◆ XMLReader()
QtxActionMgr::XMLReader::XMLReader ( const QString &  root,
const QString &  item,
const QString &  dir
rootroot XML tag name
itemmenu item XML tag name
dirresources directory (containing icons, etc)
References QtxActionMgr::Reader::setOption().
◆ ~XMLReader()
QtxActionMgr::XMLReader::~XMLReader ( )
◆ isNodeSimilar()
bool QtxActionMgr::XMLReader::isNodeSimilar ( const QDomNode &  node,
const QString &  pattern
nodeXML file node
patternnode name pattern
true if node satisfies pattern
◆ read() [1/2]
void QtxActionMgr::XMLReader::read ( const QDomNode &  parent_node,
const int  parent_id,
Creator &  cr
parent_nodeparent XML file node
parent_idparent action ID
cractions creator
References QtxActionMgr::Creator::append().
◆ read() [2/2]
bool QtxActionMgr::XMLReader::read ( const QString &  fname,
Creator &  cr
fnameXML file name
cractions creator
true on success and false in case of error
Implements QtxActionMgr::Reader.
