QtxPopupSelection Class Referenceabstract
This class is a part of the popup menu management system. More...
#include <QtxPopupMgr.h>
Inheritance diagram for QtxPopupSelection:
 QtxPopupSelection ()
virtual ~QtxPopupSelection ()
virtual int count () const =0
 Get number of the selected objects. More...
virtual QVariant parameter (const QString &) const
 Get the parameter value. More...
virtual QVariant parameter (const int, const QString &) const =0
 Get value of the parameter which is of list type. More...
QString option (const QString &) const
 Get an option value. More...
void setOption (const QString &, const QString &)
 Set an option value. More...
QtxPopupMgr * popupMgr () const
void setPopupMgr (QtxPopupMgr *)
Private Types
typedef QMap< QString, QString > OptionsMap
typedef QPointer< QtxPopupMgr > PopupMgrPtr
QString equalityParam () const
 Get symbol which detects the name of the parameter list. More...
QString selCountParam () const
 Get name of the parameter, specifing number of selected objects. More...
OptionsMap myOptions
PopupMgrPtr myPopupMgr
The QtxPopupSelection class is used as back-end for getting value of each parameter found in the rule by the expression parser.
For example, it can be used for the analyzing of the currently selected objects and defining the values of the parameters used in the rules syntax expression. Rules, in their turn, define each action state - visibility, enabled and toggled state.
◆ OptionsMap
typedef QMap<QString, QString> QtxPopupSelection::OptionsMap
◆ PopupMgrPtr
typedef QPointer<QtxPopupMgr> QtxPopupSelection::PopupMgrPtr
◆ QtxPopupSelection()
QtxPopupSelection::QtxPopupSelection ( )
◆ ~QtxPopupSelection()
QtxPopupSelection::~QtxPopupSelection ( )
◆ count()
int QtxPopupSelection::count ( ) const
pure virtual
nb of selected objects
Implemented in LightApp_Selection.
◆ equalityParam()
QString QtxPopupSelection::equalityParam ( ) const
equality symbol (by default, "$")
References option().
◆ option()
QString QtxPopupSelection::option ( const QString &  optName) const
optNameoption name
option value or empty string if option is not found
References myOptions.
◆ parameter() [1/2]
QVariant QtxPopupSelection::parameter ( const int  idx,
const QString &  name
pure virtual
idxparameter index
nameparameter name
parameter value
◆ parameter() [2/2]
QVariant QtxPopupSelection::parameter ( const QString &  str) const
strparameter name
parameter value
Reimplemented in LightApp_Selection.
References QtxEvalSetSets::add(), count(), equalityParam(), parameter(), QtxPopupMgr::parameter(), popupMgr(), and selCountParam().
◆ popupMgr()
QtxPopupMgr * QtxPopupSelection::popupMgr ( ) const
References myPopupMgr.
◆ selCountParam()
QString QtxPopupSelection::selCountParam ( ) const
parameter name (by default, "selcount")
◆ setOption()
void QtxPopupSelection::setOption ( const QString &  optName,
const QString &  opt
optNameoption name
optoption value
◆ setPopupMgr()
void QtxPopupSelection::setPopupMgr ( QtxPopupMgr *  pm)
◆ myOptions
OptionsMap QtxPopupSelection::myOptions
◆ myPopupMgr
PopupMgrPtr QtxPopupSelection::myPopupMgr
