LightApp_Selection Class Reference
#include <LightApp_Selection.h>
Inheritance diagram for LightApp_Selection:
 LightApp_Selection ()
virtual ~LightApp_Selection ()
virtual void init (const QString &, LightApp_SelectionMgr *)
virtual bool processOwner (const LightApp_DataOwner *)
virtual int count () const
virtual QVariant parameter (const QString &) const
virtual QVariant parameter (const int, const QString &) const
void setModuleName (const QString)
- Public Member Functions inherited from QtxPopupSelection
 QtxPopupSelection ()
virtual ~QtxPopupSelection ()
virtual int count () const =0
 Get number of the selected objects. More...
 Get the parameter value. More...
virtual QVariant parameter (const int, const QString &) const =0
 Get value of the parameter which is of list type. More...
QString option (const QString &) const
 Get an option value. More...
void setOption (const QString &, const QString &)
 Set an option value. More...
QtxPopupMgr * popupMgr () const
void setPopupMgr (QtxPopupMgr *)
Protected Types
enum  ObjectInformation { OI_Entry , OI_Reference , OI_RefEntry , OI_User }
QString entry (const int) const
bool isReference (const int) const
LightApp_Study * study () const
QString activeViewType () const
SUIT_ViewWindow * activeVW () const
virtual QString referencedToEntry (const QString &) const
QVariant objectInfo (const int, const int) const
void setObjectInfo (const int, const int, const QVariant &)
Private Types
typedef QMap< int, QVariant > ObjectInfo
typedef QVector< ObjectInfo > ObjectInfoVector
LightApp_Study * myStudy
QString myContext
ObjectInfoVector myObjects
Custom selection class, allowing to build popup with rules on the base of owners selected in all selectors (popup client has more priority). It is able to return values of standard object properties (isVisible,isComponent,canBeDisplayed,isReference, etc)
◆ ObjectInfo
typedef QMap<int, QVariant> LightApp_Selection::ObjectInfo
◆ ObjectInfoVector
◆ ObjectInformation
OI_Entry
OI_Reference
OI_RefEntry
OI_User
◆ LightApp_Selection()
LightApp_Selection::LightApp_Selection ( )
Constructor
◆ ~LightApp_Selection()
LightApp_Selection::~LightApp_Selection ( )
◆ activeViewType()
QString LightApp_Selection::activeViewType ( ) const
Gets type of active view manager.
References activeVW(), SUIT_ViewManager::getType(), and SUIT_ViewWindow::getViewManager().
◆ activeVW()
SUIT_ViewWindow * LightApp_Selection::activeVW ( ) const
◆ count()
int LightApp_Selection::count ( ) const
Gets count of entries.
Implements QtxPopupSelection.
References myObjects.
◆ entry()
QString LightApp_Selection::entry ( const int  index) const
Gets entry with index index.
References objectInfo(), and OI_Entry.
◆ init()
◆ isReference()
bool LightApp_Selection::isReference ( const int  index) const
Returns true if i-th selected object was reference to object with entry( i )
References objectInfo(), and OI_Reference.
◆ objectInfo()
QVariant LightApp_Selection::objectInfo ( const int  idx,
const int  inf
Gets specified information about object with index idx.
◆ parameter() [1/2]
◆ parameter() [2/2]
QVariant LightApp_Selection::parameter ( const QString &  p) const
Gets global parameters.
Gets the object parameter.
Gets global parameters. client, isActiveView, activeView etc.
Reimplemented from QtxPopupSelection.
References CAM_Application::activeModule(), activeViewType(), activeVW(), SUIT_Study::application(), myContext, myStudy, CAM_Module::name(), and QtxPopupSelection::parameter().
◆ processOwner()
bool LightApp_Selection::processOwner ( const LightApp_DataOwner *  )
Perform additional processing of the selected item (to be redefined by successors if necessary). Returns true by default. Note: if this method returns false, the item will be removed from the items list and not taken into account when showing popup menu.
ownera data owner being processed
true if the owner should be collected and false otherwise
◆ referencedToEntry()
QString LightApp_Selection::referencedToEntry ( const QString &  entry) const
◆ setModuleName()
void LightApp_Selection::setModuleName ( const  QString)
◆ setObjectInfo()
void LightApp_Selection::setObjectInfo ( const int  idx,
const int  inf,
const QVariant &  val
Sets specified information about object with index idx.
◆ study()
LightApp_Study * LightApp_Selection::study ( ) const
inlineprotected
Gets study.
◆ myContext
QString LightApp_Selection::myContext
◆ myObjects
ObjectInfoVector LightApp_Selection::myObjects
◆ myStudy
LightApp_Study* LightApp_Selection::myStudy
