LightApp_Displayer Class Reference
#include <LightApp_Displayer.h>
Inheritance diagram for LightApp_Displayer:
 LightApp_Displayer ()
virtual ~LightApp_Displayer ()
void Display (const QString &, const bool=true, SALOME_View *=0)
virtual void Display (const QStringList &, const bool=true, SALOME_View *=0)
virtual void Redisplay (const QString &, const bool=true)
virtual void Erase (const QStringList &, const bool forced=false, const bool updateViewer=true, SALOME_View *=0)
void Erase (const QString &, const bool forced=false, const bool updateViewer=true, SALOME_View *=0)
virtual void EraseAll (const bool forced=false, const bool updateViewer=true, SALOME_View *=0)
virtual bool IsDisplayed (const QString &, SALOME_View *=0) const
void UpdateViewer () const
virtual bool canBeDisplayed (const QString &, const QString &) const
bool canBeDisplayed (const QString &) const
void setVisibilityState (const QString &entry, Qtx::VisibilityState) const
- Public Member Functions inherited from SALOME_Displayer
virtual ~SALOME_Displayer ()
void UpdatePrs (SALOME_Prs *)
 This Update() method should be called to update given presentation created anywhere by anybody. More...
virtual void Update (SALOME_OCCPrs *)
 Update SALOME_OCCPrs presentation. More...
virtual void Update (SALOME_VTKPrs *)
 Update SALOME_VTKPrs presentation. More...
virtual void Update (SALOME_PV3DPrs *)
 Update SALOME_PV3DPrs presentation. More...
virtual void Update (SALOME_Prs2d *)
 Update SALOME_Prs2d presentation. More...
virtual void BeforeDisplay (SALOME_View *, const SALOME_OCCPrs *)
virtual void AfterDisplay (SALOME_View *, const SALOME_OCCPrs *)
 Null body here. More...
virtual void BeforeDisplay (SALOME_View *, const SALOME_VTKPrs *)
virtual void AfterDisplay (SALOME_View *, const SALOME_VTKPrs *)
virtual void BeforeDisplay (SALOME_View *, const SALOME_PV3DPrs *)
virtual void AfterDisplay (SALOME_View *, const SALOME_PV3DPrs *)
virtual void BeforeDisplay (SALOME_View *, const SALOME_Prs2d *)
virtual void AfterDisplay (SALOME_View *, const SALOME_Prs2d *)
virtual void BeforeErase (SALOME_View *, const SALOME_OCCPrs *)
virtual void AfterErase (SALOME_View *, const SALOME_OCCPrs *)
virtual void BeforeErase (SALOME_View *, const SALOME_VTKPrs *)
virtual void AfterErase (SALOME_View *, const SALOME_VTKPrs *)
virtual void BeforeErase (SALOME_View *, const SALOME_PV3DPrs *)
virtual void AfterErase (SALOME_View *, const SALOME_PV3DPrs *)
virtual void BeforeErase (SALOME_View *, const SALOME_Prs2d *)
virtual void AfterErase (SALOME_View *, const SALOME_Prs2d *)
virtual void UpdateVisibility (SALOME_View *, const SALOME_Prs *, bool)
static SALOME_View * GetActiveView ()
static LightApp_Displayer * FindDisplayer (const QString &, const bool)
virtual SALOME_Prs * buildPresentation (const QString &, SALOME_View *=0)
QString myLastEntry
Uniform mechanism of display/erase of objects in different views. Objects are specified by string entry
◆ LightApp_Displayer()
LightApp_Displayer::LightApp_Displayer ( )
Default constructor
◆ ~LightApp_Displayer()
LightApp_Displayer::~LightApp_Displayer ( )
Destructor
◆ buildPresentation()
SALOME_Prs * LightApp_Displayer::buildPresentation ( const QString &  entry,
SALOME_View *  theViewFrame = 0
presentation of object, built with help of CreatePrs method
entry- object entry
theViewFrame- view
See also
CreatePrs()
References SALOME_View::CreatePrs(), and GetActiveView().
◆ canBeDisplayed() [1/2]
bool LightApp_Displayer::canBeDisplayed ( const QString &  entry) const
true, if object can be displayed in any type of viewer
entry- object entry
References SUIT_Session::activeApplication(), canBeDisplayed(), and SUIT_Session::session().
◆ canBeDisplayed() [2/2]
bool LightApp_Displayer::canBeDisplayed ( const QString &  ,
const QString &
true, if object can be displayed in this type of viewer
entry- object entry
viewer_type- type of viewer
◆ Display() [1/2]
void LightApp_Displayer::Display ( const QString &  entry,
const bool  updateViewer = true,
Displays object in view
entry- object entry
updateViewer- is it necessary to update viewer
theViewFrame- view
References Display().
◆ Display() [2/2]
void LightApp_Displayer::Display ( const QStringList &  list,
list- object entries
theViewFrame- view
References SALOME_View::AfterDisplay(), SALOME_View::BeforeDisplay(), buildPresentation(), SALOME_View::Display(), GetActiveView(), myLastEntry, SALOME_View::Repaint(), setVisibilityState(), and Qtx::ShownState.
◆ Erase() [1/2]
void LightApp_Displayer::Erase ( const QString &  entry,
const bool  forced = false,
Erases object in view
entry- object entry
forced- deletes object from viewer (otherwise it will be erased, but cached)
theViewFrame- view
References Erase().
◆ Erase() [2/2]
void LightApp_Displayer::Erase ( const QStringList &  list,
theViewFrame- view
References SALOME_View::AfterErase(), SALOME_View::BeforeErase(), SALOME_View::CreatePrs(), SALOME_View::Erase(), GetActiveView(), Qtx::HiddenState, myLastEntry, SALOME_View::Repaint(), and setVisibilityState().
◆ EraseAll()
void LightApp_Displayer::EraseAll ( const bool  forced = false,
Erases all objects in view
forced- deletes objects from viewer
theViewFrame- view
References SUIT_Session::activeApplication(), SUIT_Application::activeStudy(), SALOME_View::EraseAll(), GetActiveView(), Qtx::HiddenState, SALOME_View::Repaint(), SUIT_Session::session(), and LightApp_Study::setVisibilityStateForAll().
◆ FindDisplayer()
LightApp_Displayer * LightApp_Displayer::FindDisplayer ( const QString &  mod_name,
const bool  load
displayer, corresponding to module
mod_name- name or title of module.
It is better to use name (component data type) in any case when you are not sure the title is not empty.
load- is module has to be forced loaded
References SUIT_Session::activeApplication(), SUIT_Application::activeStudy(), CAM_Application::addModule(), CAM_Module::connectToStudy(), LightApp_Module::displayer(), LightApp_Application::loadModule(), CAM_Application::module(), CAM_Application::moduleDisplayer(), SUIT_Session::session(), and LightApp_Module::updateModuleVisibilityState().
◆ GetActiveView()
SALOME_View * LightApp_Displayer::GetActiveView ( )
active view
References SUIT_Session::activeApplication(), and SUIT_Session::session().
◆ IsDisplayed()
bool LightApp_Displayer::IsDisplayed ( const QString &  entry,
true if object is displayed in viewer
entry- object entry
theViewFrame- view
References GetActiveView(), Handle(), and SALOME_View::isVisible().
◆ Redisplay()
void LightApp_Displayer::Redisplay ( const QString &  entry,
Redisplays object in view
entry- object entry
References SUIT_Session::activeApplication(), SUIT_Application::desktop(), Display(), Erase(), GetActiveView(), SUIT_ViewManager::getViewModel(), IsDisplayed(), SUIT_Session::session(), and SUIT_Desktop::windows().
◆ setVisibilityState()
void LightApp_Displayer::setVisibilityState ( const QString &  theEntry,
Qtx::VisibilityState  theState
Find the active study and set the 'visibility state' property of the object
mod_name- name of module
References SUIT_Session::activeApplication(), SUIT_Application::activeStudy(), SUIT_Session::session(), and LightApp_Study::setVisibilityState().
◆ UpdateViewer()
void LightApp_Displayer::UpdateViewer ( ) const
Updates active view
References GetActiveView(), and SALOME_View::Repaint().
◆ myLastEntry
QString LightApp_Displayer::myLastEntry
