SALOME_PV3DPrs Class Reference
#include <SALOME_Prs.h>
Inheritance diagram for SALOME_PV3DPrs:
 SALOME_PV3DPrs (const char *e)
virtual void DisplayIn (SALOME_View *) const
 It uses double dispatch in order to invoke Display() method corresponding to the actual type of presentation. More...
virtual void EraseIn (SALOME_View *, const bool=false) const
 It uses double dispatch in order to invoke Erase() method corresponding to the actual type of presentation. More...
virtual void BeforeDisplayIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke BeforeDisplayIn() method corresponding to the actual type of presentation. More...
virtual void AfterDisplayIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke AfterDisplayIn() method corresponding to the actual type of presentation. More...
virtual void BeforeEraseIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke BeforeEraseIn() method corresponding to the actual type of presentation. More...
virtual void AfterEraseIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke AfterEraseIn() method corresponding to the actual type of presentation. More...
virtual void Update (SALOME_Displayer *)
 It uses double dispatch in order to invoke Update() method corresponding to the actual type of presentation. More...
virtual void LocalSelectionIn (SALOME_View *, const int) const
 Key method for double dispatch of activation of sub-shapes selection. More...
virtual void LocalSelectionIn (SALOME_View *, const std::list< int >) const
- Public Member Functions inherited from SALOME_Prs
 SALOME_Prs (const char *)
virtual ~SALOME_Prs ()
const char * GetEntry () const
 Get entry. More...
virtual void DisplayIn (SALOME_View *) const =0
 Key method for double dispatch of display operation. More...
virtual void EraseIn (SALOME_View *, const bool=false) const =0
 Key method for double dispatch of erase operation. More...
virtual void BeforeDisplayIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of pre-display operation. More...
virtual void AfterDisplayIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of post-display operation. More...
virtual void BeforeEraseIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of pre-erase operation. More...
virtual void AfterEraseIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of post-erase operation. More...
virtual void Update (SALOME_Displayer *)=0
 Key method for double dispatch of update operation. More...
virtual bool IsNull () const =0
 Should return true, if this presentation contains a graphic object. More...
virtual void LocalSelectionIn (SALOME_View *, const int) const =0
bool IsClippable () const
void SetClippable (bool isClippable)
- Protected Attributes inherited from SALOME_Prs
std::string myEntry
bool myIsClippable
Base class for PV3D graphic object (pqPipelineSource) wrappers. This intermediate class is necessary to avoid dependencies from ParaView libs.
◆ SALOME_PV3DPrs()
SALOME_PV3DPrs::SALOME_PV3DPrs ( const char *  e)
inlineexplicit
◆ AfterDisplayIn()
void SALOME_PV3DPrs::AfterDisplayIn ( SALOME_Displayer *  d,
SALOME_View *  v
Dispatches display operation to proper AfterDisplay() method of SALOME_Displayer
Implements SALOME_Prs.
References SALOME_Displayer::AfterDisplay().
◆ AfterEraseIn()
void SALOME_PV3DPrs::AfterEraseIn ( SALOME_Displayer *  d,
SALOME_View *  v
Dispatches display operation to proper AfterErase() method of SALOME_Displayer
References SALOME_Displayer::AfterErase().
◆ BeforeDisplayIn()
void SALOME_PV3DPrs::BeforeDisplayIn ( SALOME_Displayer *  d,
SALOME_View *  v
Dispatches display operation to proper BeforeDisplay() method of SALOME_Displayer
References SALOME_Displayer::BeforeDisplay().
◆ BeforeEraseIn()
void SALOME_PV3DPrs::BeforeEraseIn ( SALOME_Displayer *  d,
SALOME_View *  v
Dispatches display operation to proper BeforeErase() method of SALOME_Displayer
References SALOME_Displayer::BeforeErase().
◆ DisplayIn()
void SALOME_PV3DPrs::DisplayIn ( SALOME_View *  v) const
Dispatches display operation to proper Display() method of SALOME_View
Reimplemented in SPV3D_Prs.
References SALOME_View::Display().
◆ EraseIn()
void SALOME_PV3DPrs::EraseIn ( SALOME_View *  v,
const bool  forced = false
Dispatches display operation to proper Erase() method of SALOME_View
References SALOME_View::Erase().
◆ LocalSelectionIn() [1/2]
void SALOME_PV3DPrs::LocalSelectionIn ( SALOME_View *  v,
const int  mode
Dispatches operation to proper LocalSelectionIn() method of SALOME_View
References LocalSelectionIn().
◆ LocalSelectionIn() [2/2]
const std::list< int >  modes
Reimplemented from SALOME_Prs.
References SALOME_View::LocalSelection().
◆ Update()
void SALOME_PV3DPrs::Update ( SALOME_Displayer *  d)
Dispatches update operation to proper Update() method of SALOME_Displayer
References SALOME_Displayer::Update().
