SPV3D_Prs Class Reference
#include <SPV3D_Prs.h>
Inheritance diagram for SPV3D_Prs:
 SPV3D_Prs (const char *entry, SPV3D_ViewWindow *view)
 ~SPV3D_Prs ()
void SetName (const std::string &name)
SPV3D_Prs * deepCopy () const
void FillUsingActor (vtkActor *actor) const
void DisplayIn (SALOME_View *v) const override
 It uses double dispatch in order to invoke Display() method corresponding to the actual type of presentation. More...
void SetPVRenderInfo (SPV3D_EXPORTSPV3DData *pvRendInfo)
pqPipelineSource * GetSourceProducer () const
void SetRepresentation (pqDataRepresentation *repr) const
pqDataRepresentation * GetRepresentation () const
bool IsNull () const override
 Should return true, if this presentation contains a graphic object. More...
void hide () const
bool isVisible () const
- Public Member Functions inherited from SALOME_PV3DPrs
 SALOME_PV3DPrs (const char *e)
virtual void DisplayIn (SALOME_View *) const
virtual void EraseIn (SALOME_View *, const bool=false) const
 It uses double dispatch in order to invoke Erase() method corresponding to the actual type of presentation. More...
virtual void BeforeDisplayIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke BeforeDisplayIn() method corresponding to the actual type of presentation. More...
virtual void AfterDisplayIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke AfterDisplayIn() method corresponding to the actual type of presentation. More...
virtual void BeforeEraseIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke BeforeEraseIn() method corresponding to the actual type of presentation. More...
virtual void AfterEraseIn (SALOME_Displayer *, SALOME_View *) const
 It uses double dispatch in order to invoke AfterEraseIn() method corresponding to the actual type of presentation. More...
virtual void Update (SALOME_Displayer *)
 It uses double dispatch in order to invoke Update() method corresponding to the actual type of presentation. More...
virtual void LocalSelectionIn (SALOME_View *, const int) const
 Key method for double dispatch of activation of sub-shapes selection. More...
virtual void LocalSelectionIn (SALOME_View *, const std::list< int >) const
- Public Member Functions inherited from SALOME_Prs
 SALOME_Prs (const char *)
virtual ~SALOME_Prs ()
const char * GetEntry () const
 Get entry. More...
virtual void DisplayIn (SALOME_View *) const =0
 Key method for double dispatch of display operation. More...
virtual void EraseIn (SALOME_View *, const bool=false) const =0
 Key method for double dispatch of erase operation. More...
virtual void BeforeDisplayIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of pre-display operation. More...
virtual void AfterDisplayIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of post-display operation. More...
virtual void BeforeEraseIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of pre-erase operation. More...
virtual void AfterEraseIn (SALOME_Displayer *, SALOME_View *) const =0
 Key method for double dispatch of post-erase operation. More...
virtual void Update (SALOME_Displayer *)=0
 Key method for double dispatch of update operation. More...
virtual bool IsNull () const =0
virtual void LocalSelectionIn (SALOME_View *, const int) const =0
bool IsClippable () const
void SetClippable (bool isClippable)
static vtkIdType FromEntryToVtkId (const char *)
static const char * FromVtkIdToEntry (vtkIdType)
 SPV3D_Prs (const SPV3D_Prs &other)=default
SPV3D_EXPORTSPV3DData * _pvRendInfo = nullptr
SPV3D_ViewWindow * _view = nullptr
 Name attached to the displayable object in the study. More...
Static Private Attributes
static vtkIdType cellid = 0
static vtkIdType nbsolid = 0
- Protected Attributes inherited from SALOME_Prs
std::string myEntry
bool myIsClippable
◆ SPV3D_Prs() [1/2]
SPV3D_Prs::SPV3D_Prs ( const char *  entry,
SPV3D_ViewWindow *  view
explicit
◆ ~SPV3D_Prs()
SPV3D_Prs::~SPV3D_Prs ( )
◆ SPV3D_Prs() [2/2]
SPV3D_Prs::SPV3D_Prs ( const SPV3D_Prs &  other)
privatedefault
◆ deepCopy()
SPV3D_Prs * SPV3D_Prs::deepCopy ( ) const
References SPV3D_Prs().
◆ DisplayIn()
void SPV3D_Prs::DisplayIn ( SALOME_View *  v) const
overridevirtual
Dispatches display operation to proper Display() method of SALOME_View
Reimplemented from SALOME_PV3DPrs.
References SALOME_PV3DPrs::DisplayIn().
◆ FillUsingActor()
void SPV3D_Prs::FillUsingActor ( vtkActor *  actor) const
◆ FromEntryToVtkId()
vtkIdType SPV3D_Prs::FromEntryToVtkId ( const char *  entry)
◆ FromVtkIdToEntry()
const char * SPV3D_Prs::FromVtkIdToEntry ( vtkIdType  id)
◆ GetRepresentation()
pqDataRepresentation * SPV3D_Prs::GetRepresentation ( ) const
◆ GetSourceProducer()
pqPipelineSource * SPV3D_Prs::GetSourceProducer ( ) const
◆ hide()
void SPV3D_Prs::hide ( ) const
◆ IsNull()
bool SPV3D_Prs::IsNull ( ) const
overridevirtual
Implements SALOME_Prs.
References _pvRendInfo, SALOME_Prs::GetEntry(), and SPV3D_EXPORTSPV3DData::havePrs().
◆ isVisible()
bool SPV3D_Prs::isVisible ( ) const
◆ SetName()
void SPV3D_Prs::SetName ( const std::string &  name)
◆ SetPVRenderInfo()
void SPV3D_Prs::SetPVRenderInfo ( SPV3D_EXPORTSPV3DData *  pvRendInfo)
◆ SetRepresentation()
void SPV3D_Prs::SetRepresentation ( pqDataRepresentation *  repr) const
◆ _name
std::string SPV3D_Prs::_name
◆ _pvRendInfo
SPV3D_EXPORTSPV3DData* SPV3D_Prs::_pvRendInfo = nullptr
◆ _view
SPV3D_ViewWindow* SPV3D_Prs::_view = nullptr
◆ cellid
vtkIdType SPV3D_Prs::cellid = 0
staticprivate
◆ nbsolid
vtkIdType SPV3D_Prs::nbsolid = 0
staticprivate
