QtxResourceMgr::Format Class Referenceabstract
Generic resources files reader/writer class. More...
#include <QtxResourceMgr.h>
Inheritance diagram for QtxResourceMgr::Format:
 Format (const QString &)
virtual ~Format ()
QString format () const
 Get the format name. More...
QStringList options () const
 Get options names. More...
QString option (const QString &) const
 Get the value of the option with specified name. More...
void setOption (const QString &, const QString &)
 Set the value of the option with specified name. More...
bool load (Resources *)
 Load resources from the resource file. More...
bool save (Resources *)
 Save resources to the resource file. More...
virtual bool load (const QString &, QMap< QString, Section > &)=0
 Load resources from the specified resources file. More...
virtual bool save (const QString &, const QMap< QString, Section > &)=0
 Save resources to the specified resources file. More...
QString myFmt
 format name More...
QMap< QString, QString > myOpt
 options map More...
◆ Format()
QtxResourceMgr::Format::Format ( const QString &  fmt)
fmtformat name (for example, "xml" or "ini")
◆ ~Format()
QtxResourceMgr::Format::~Format ( )
◆ format()
QString QtxResourceMgr::Format::format ( ) const
format name
◆ load() [1/2]
bool QtxResourceMgr::Format::load ( const QString &  fname,
QMap< QString, Section > &  secMap
protectedpure virtual
Should be implemented in the successors.
fnameresources file name
secMapresources map to be filled in
true on success and false on error
Implemented in QtxResourceMgr::IniFormat, QtxResourceMgr::XmlFormat, and QtxResourceMgr::JsonFormat.
◆ load() [2/2]
bool QtxResourceMgr::Format::load ( Resources *  res)
resresources object
References QtxResourceMgr::load(), QtxResourceMgr::Resources::myFileName, QtxResourceMgr::Resources::mySections, and QtxResourceMgr::sections().
◆ option()
QString QtxResourceMgr::Format::option ( const QString &  opt) const
If option doesn't exist then null QString is returned.
optoption name
option value
◆ options()
QStringList QtxResourceMgr::Format::options ( ) const
Get options names.
list of the format options
◆ save() [1/2]
bool QtxResourceMgr::Format::save ( const QString &  fname,
const QMap< QString, Section > &  secMap
secMapresources map
◆ save() [2/2]
bool QtxResourceMgr::Format::save ( Resources *  res)
resresources object
References QtxResourceMgr::appName(), Qtx::dir(), Qtx::mkDir(), QtxResourceMgr::Resources::myFileName, QtxResourceMgr::Resources::mySections, QtxResourceMgr::Resources::resMgr(), QtxResourceMgr::save(), and QtxResourceMgr::userFileName().
◆ setOption()
void QtxResourceMgr::Format::setOption ( const QString &  opt,
const QString &  val
optoption name
valoption value
◆ myFmt
QString QtxResourceMgr::Format::myFmt
format name
◆ myOpt
QMap<QString, QString> QtxResourceMgr::Format::myOpt
options map
