QtxResourceMgr::Resources Class Reference
Represents container for settings read from the resource file. More...
 Resources (QtxResourceMgr *, const QString &)
virtual ~Resources ()
QString file () const
 Get resources file name. More...
void setFile (const QString &)
 Set resources file name. More...
QString value (const QString &, const QString &, const bool, const OptionsMap &) const
 Get string representation of parameter value. More...
void setValue (const QString &, const QString &, const QString &)
 Set parameter value. More...
bool hasSection (const QString &) const
 Check section existence. More...
bool hasValue (const QString &, const QString &) const
 Check parameter existence. More...
void removeSection (const QString &)
 Remove resourcs section. More...
void removeValue (const QString &, const QString &)
 Remove parameter from the section. More...
QPixmap loadPixmap (const QString &, const QString &, const QString &, const OptionsMap &) const
 Load and return pixmap from external file. More...
QTranslator * loadTranslator (const QString &, const QString &, const QString &, const OptionsMap &) const
 Load translator. More...
void clear ()
 Remove all sections. More...
QStringList sections () const
 Get all sections names. More...
QStringList parameters (const QString &) const
 Get all parameters name in specified section. More...
QString path (const QString &, const QString &, const QString &, const OptionsMap &) const
 Get absolute path to the file which name is defined by the parameter. More...
QtxResourceMgr * resMgr () const
 Get resource manager. More...
Private Types
typedef QMap< QString, Section > SectionMap
typedef QMap< QString, QString > OptionsMap
Section section (const QString &)
 Get resources section by specified name. More...
const Section section (const QString &) const
QString makeSubstitution (const QString &, const QString &, const QString &, const OptionsMap &) const
 Substitute variables by their values. More...
QString fileName (const QString &, const QString &, const QString &, const OptionsMap &) const
 Get file path. More...
QtxResourceMgr * myMgr
 resources manager More...
SectionMap mySections
 sections map More...
QString myFileName
 resources file name More...
QMap< QString, QPixmap > myPixmapCache
 pixmaps cache More...
Friends
class QtxResourceMgr::Format
◆ OptionsMap
typedef QMap<QString, QString> QtxResourceMgr::Resources::OptionsMap
◆ SectionMap
typedef QMap<QString, Section> QtxResourceMgr::Resources::SectionMap
◆ Resources()
QtxResourceMgr::Resources::Resources ( QtxResourceMgr *  mgr,
const QString &  fileName
mgrparent resources manager
fileNameresources file name
◆ ~Resources()
QtxResourceMgr::Resources::~Resources ( )
◆ clear()
void QtxResourceMgr::Resources::clear ( )
◆ file()
QString QtxResourceMgr::Resources::file ( ) const
This file is used to load/save operations.
file name
See also
setFile()
◆ fileName()
QString QtxResourceMgr::Resources::fileName ( const QString &  sect,
const QString &  prefix,
const QString &  name,
const OptionsMap &  constants
Get file path.
The file name is defined by name argument, while directory name is retrieved from resources parameter prefix of section sec. Both directory and file name can be relative. If the directory is relative, it is calculated from the initial resources file name (see file()). Directory parameter can contain environment variables, which are substituted automatically. File existence is not checked.
secsection name
prefixparameter containing directory name
namefile name
absolute file path or null QString if prefix parameter does not exist in section \sec
See also
path(), file(), makeSubstitution()
References Qtx::addSlash(), QtxResourceMgr::constants(), Qtx::dir(), QtxResourceMgr::hasValue(), QtxResourceMgr::path(), and QtxResourceMgr::value().
◆ hasSection()
bool QtxResourceMgr::Resources::hasSection ( const QString &  sect) const
sectsection name
true if section exists
◆ hasValue()
bool QtxResourceMgr::Resources::hasValue ( const QString &  sect,
sectsection name
nameparameter name
true if parameter exists in specified section
References QtxResourceMgr::hasSection().
◆ loadPixmap()
QPixmap QtxResourceMgr::Resources::loadPixmap ( const QString &  sect,
If QtxResourceMgr::isPixmapCached() is true then cached pixmap is returned (if it is already loaded), otherwise it is loaded from file. If the file name is invalid, null pixmap is returned.
sectsection name
prefixparameter containing resources directory name
namepixmap file name
pixmap loaded from file
References QtxResourceMgr::constants().
◆ loadTranslator()
QTranslator * QtxResourceMgr::Resources::loadTranslator ( const QString &  sect,
Load translator.
sectsection name
nametranslation file name
just created and loaded translator or 0 in case of error
References QtxResourceMgr::constants(), Qtx::dir(), and Qtx::file().
◆ makeSubstitution()
QString QtxResourceMgr::Resources::makeSubstitution ( const QString &  str,
Environment variable is substituted by its value. For other variables resource manager tries to find value among defined resources parameters.
strstring to be processed
sectsection, where variables are searched
namename of variable which must be ignored during substitution
processed string (with all substitutions made)
References QtxResourceMgr::constants(), Qtx::findEnvVar(), Qtx::getenv(), QtxResourceMgr::hasValue(), and QtxResourceMgr::value().
◆ parameters()
QStringList QtxResourceMgr::Resources::parameters ( const QString &  sec) const
secsection name
list of settings names
◆ path()
QString QtxResourceMgr::Resources::path ( const QString &  sec,
secsection name
namefile name
absolute file path or null QString if file does not exist
See also
fileName(), file(), makeSubstitution()
◆ removeSection()
void QtxResourceMgr::Resources::removeSection ( const QString &  sect)
sectsecton name
◆ removeValue()
void QtxResourceMgr::Resources::removeValue ( const QString &  sect,
sectsection name
nameparameter name
◆ resMgr()
QtxResourceMgr * QtxResourceMgr::Resources::resMgr ( ) const
resource manager pointer
◆ section() [1/2]
QtxResourceMgr::Section QtxResourceMgr::Resources::section ( const QString &  sn)
If section does not exist it is created (empty).
snsection name
resources section
References IMap< Key, Value >::insert().
◆ section() [2/2]
const QtxResourceMgr::Section QtxResourceMgr::Resources::section ( const QString &  sn) const
snsection name
resources section
◆ sections()
QStringList QtxResourceMgr::Resources::sections ( ) const
list of section names
◆ setFile()
void QtxResourceMgr::Resources::setFile ( const QString &  fn)
fnfile name
See also
file()
◆ setValue()
void QtxResourceMgr::Resources::setValue ( const QString &  sect,
const QString &  val
sectsection name
nameparameter name
valparameter value
See also
value(), makeSubstitution()
◆ value()
QString QtxResourceMgr::Resources::value ( const QString &  sect,
const bool  subst,
sectsection name
nameparameter name
substif true, perform variables substitution
parameter value or null QString if there is no such parameter
See also
setValue(), makeSubstitution()
References QtxResourceMgr::constants(), and QtxResourceMgr::hasValue().
◆ QtxResourceMgr::Format
friend class QtxResourceMgr::Format
friend
◆ myFileName
QString QtxResourceMgr::Resources::myFileName
resources file name
◆ myMgr
QtxResourceMgr* QtxResourceMgr::Resources::myMgr
resources manager
◆ myPixmapCache
QMap<QString,QPixmap> QtxResourceMgr::Resources::myPixmapCache
pixmaps cache
◆ mySections
SectionMap QtxResourceMgr::Resources::mySections
sections map
