QtxWorkstackArea Class Reference
Workstack widget workarea. More...
#include <QtxWorkstack.h>
Inheritance diagram for QtxWorkstackArea:
class  RestoreEvent
 Internal class used to forward restore info events to the workarea. More...
class  WidgetEvent
 Internal class used to forward child widgets events to the workarea. More...
Signals
void activated (QWidget *)
 Emitted when child widget is activated. More...
void contextMenuRequested (QWidget *, QPoint)
 Emitted when context popup menu is requested. More...
void deactivated (QtxWorkstackArea *)
 Emitted when workarea is deactivated. More...
 QtxWorkstackArea (QWidget *)
virtual ~QtxWorkstackArea ()
bool isNull () const
 Check if workarea contains any widgets. More...
bool isEmpty () const
 Check if workarea contains visible widgets. More...
QtxWorkstackChild * insertWidget (QWidget *, const int=-1, Qt::WindowFlags=0)
 Add widget to the workarea. More...
void removeWidget (QWidget *, const bool=true)
 Remove widget from workarea. More...
void insertChild (QtxWorkstackChild *, const int=-1)
void removeChild (QtxWorkstackChild *, const bool=true)
 Remove child from workarea. More...
QWidget * activeWidget () const
 Get active child widget. More...
void setActiveWidget (QWidget *)
 Set active widget. More...
bool contains (QWidget *) const
 Check if area owns the specified widget. More...
QWidgetList widgetList () const
 Get all visible child widgets. More...
QList< QtxWorkstackChild * > childList () const
bool isActive () const
 Check if workarea is active. More...
void updateActiveState ()
 Update active tab bar state (active/inactive). More...
QtxWorkstack * workstack () const
 Get parent workstack. More...
 Custom event filter. More...
QRect floatRect () const
 Get rectangle to be drawn when highlighting drop area. More...
QRect floatTab (const int) const
 Get rectangle to be drawn when highlighting drop area on tab bar. More...
int tabAt (const QPoint &) const
 Get tab index by point. More...
void saveState (QDataStream &) const
 Save the own widgets configuration into data stream. More...
bool restoreState (QDataStream &, QMap< QString, QtxWorkstackChild * > &)
 Restore the widgets configuration from data stream info. More...
void showTabBar (bool=true)
 Show/Hide tab bar. More...
virtual void customEvent (QEvent *)
 Event handler for custom events. More...
virtual void focusInEvent (QFocusEvent *)
 Customize focus in event handler. More...
virtual void mousePressEvent (QMouseEvent *)
 Customize mouse press event handler. More...
Private Types
enum  { ActivateWidget = QEvent::User , FocusWidget , MakeCurrent , RestoreWidget }
 Custom events. More...
typedef QList< QtxWorkstackChild * > ChildList
Private Slots
void onClose ()
 Called when user presses "Close" button. More...
void onCurrentChanged (int)
 Called when user selects any tab page. More...
void onChildDestroyed (QObject *)
 Called when area's child widget container is destroyed. More...
void onChildShown (QtxWorkstackChild *)
 Called when child widget container is shown. More...
void onChildHidden (QtxWorkstackChild *)
 Called when child widget container is hidden. More...
void onChildActivated (QtxWorkstackChild *)
 Called when child widget container is activated. More...
void onChildCaptionChanged (QtxWorkstackChild *)
 Called when child widget container's title is changed. More...
void onDragActiveTab ()
 Called when user starts tab page dragging. More...
void onContextMenuRequested (QPoint)
 Create and show popup menu for the area. More...
void updateState ()
 Update internal state. More...
void updateCurrent ()
 Update current child widget container. More...
void updateTab (QWidget *)
 Update tab bar. More...
QWidget * widget (const int) const
 Get child widget by specified identifier. More...
int widgetId (QWidget *) const
 Get child widget identifier. More...
QtxWorkstackChild * child (QWidget *) const
 Get child widget container. More...
QtxWorkstackChild * child (const int) const
void setWidgetActive (QWidget *)
 Set active child widget. More...
int generateId () const
 Generate unique widget identifier. More...
QWidget * myTop
 workarea top widget More...
QtxWorkstackTabBar * myBar
 workarea tab bar header More...
ChildList myList
 child widgets list More...
QAbstractButton * myClose
 close button More...
QStackedWidget * myStack
 widget stack More...
◆ ChildList
◆ anonymous enum
anonymous enum
Custom events.
ActivateWidget
activate widget event
FocusWidget
focus receiving widget event
MakeCurrent
RestoreWidget
◆ QtxWorkstackArea()
QtxWorkstackArea::QtxWorkstackArea ( QWidget *  parent)
◆ ~QtxWorkstackArea()
QtxWorkstackArea::~QtxWorkstackArea ( )
◆ activated
void QtxWorkstackArea::activated ( QWidget *  w)
signal
wchild widget being activated
◆ activeWidget()
QWidget * QtxWorkstackArea::activeWidget ( ) const
active widget
References myBar, QtxWorkstackTabBar::tabId(), and widget().
◆ child() [1/2]
QtxWorkstackChild * QtxWorkstackArea::child ( const int  id) const
References myList.
◆ child() [2/2]
QtxWorkstackChild * QtxWorkstackArea::child ( QWidget *  wid) const
widchild widget
child widget container corresponding to the wid
References myList.
◆ childList()
QList< QtxWorkstackChild * > QtxWorkstackArea::childList ( ) const
References myList.
◆ contains()
bool QtxWorkstackArea::contains ( QWidget *  wid) const
widwidget to be checked
true if area contains widget
References child().
◆ contextMenuRequested
void QtxWorkstackArea::contextMenuRequested ( QWidget *  w,
QPoint  p
signal
wchild widget popup menu requested for
ppoint popup menu to be shown at
◆ customEvent()
◆ deactivated
void QtxWorkstackArea::deactivated ( QtxWorkstackArea *  wa)
signal
waworkarea being deactivated
◆ eventFilter()
bool QtxWorkstackArea::eventFilter ( QObject *  o,
QEvent *  e
Process events from child widgets.
oevent receiver widget
eevent
true if event should be filtered (stop further processing)
References ActivateWidget, FocusWidget, and myClose.
◆ floatRect()
QRect QtxWorkstackArea::floatRect ( ) const
area drop rectangle
References myStack.
◆ floatTab()
QRect QtxWorkstackArea::floatTab ( const int  idx) const
idxtab index
tab bar drop rectrangle
References myBar.
◆ focusInEvent()
void QtxWorkstackArea::focusInEvent ( QFocusEvent *  e)
efocus in event
References activated(), activeWidget(), myBar, and QtxWorkstackTabBar::updateActiveState().
◆ generateId()
int QtxWorkstackArea::generateId ( ) const
first non shared widget ID
References myList.
◆ insertChild()
◆ insertWidget()
QtxWorkstackChild * QtxWorkstackArea::insertWidget ( QWidget *  wid,
const int  idx = -1,
Qt::WindowFlags  f = 0
widwidget to be added
idxposition in the area widget to be added to
fwidget flags
child widget container object (or 0 if index is invalid)
References child(), insertChild(), and myStack.
◆ isActive()
bool QtxWorkstackArea::isActive ( ) const
true if area is active
References QtxWorkstack::activeArea(), and workstack().
◆ isEmpty()
bool QtxWorkstackArea::isEmpty ( ) const
true if area is empty (all child widgets are removed or now shown)
References myList.
◆ isNull()
bool QtxWorkstackArea::isNull ( ) const
true if area is null (havn't any child widgets)
References myList.
◆ mousePressEvent()
void QtxWorkstackArea::mousePressEvent ( QMouseEvent *  e)
emouse press event
References activated(), and activeWidget().
◆ onChildActivated
void QtxWorkstackArea::onChildActivated ( QtxWorkstackChild *  c)
privateslot
cchild widget container being activated
References setWidgetActive(), and QtxWorkstackChild::widget().
◆ onChildCaptionChanged
void QtxWorkstackArea::onChildCaptionChanged ( QtxWorkstackChild *  c)
privateslot
cchild widget container which title is changed
References updateTab(), and QtxWorkstackChild::widget().
◆ onChildDestroyed
void QtxWorkstackArea::onChildDestroyed ( QObject *  obj)
privateslot
objwidget container being destroyed
References removeChild().
◆ onChildHidden
void QtxWorkstackArea::onChildHidden ( QtxWorkstackChild *  )
privateslot
cchild widget container being hidden
References updateState().
◆ onChildShown
void QtxWorkstackArea::onChildShown ( QtxWorkstackChild *  )
privateslot
cchild widget container being shown
◆ onClose
void QtxWorkstackArea::onClose ( )
privateslot
References activeWidget().
◆ onContextMenuRequested
void QtxWorkstackArea::onContextMenuRequested ( QPoint  p)
privateslot
pmouse pointer position at which popup menu should be shown
References contextMenuRequested(), myBar, tabAt(), QtxWorkstackTabBar::tabId(), and widget().
◆ onCurrentChanged
void QtxWorkstackArea::onCurrentChanged ( int  )
privateslot
idxtab page index (not used)
References activated(), activeWidget(), and updateCurrent().
◆ onDragActiveTab
void QtxWorkstackArea::onDragActiveTab ( )
privateslot
References activeWidget(), child(), and workstack().
◆ removeChild()
void QtxWorkstackArea::removeChild ( QtxWorkstackChild *  child,
const bool  del = true
childchild to be removed
delif true the widget should be also deleted
References activated(), child(), QtxWorkstackChild::id(), QtxWorkstackTabBar::indexOf(), isNull(), myBar, myList, myStack, onChildActivated(), onChildCaptionChanged(), onChildDestroyed(), onChildHidden(), onChildShown(), updateState(), and QtxWorkstackChild::widget().
◆ removeWidget()
void QtxWorkstackArea::removeWidget ( QWidget *  wid,
widwidget to be removed
References child(), and removeChild().
◆ restoreState()
bool QtxWorkstackArea::restoreState ( QDataStream &  stream,
QMap< QString, QtxWorkstackChild * > &  map
true in successful case.
References MakeCurrent, RestoreWidget, and QtxWorkstack::WidgetMarker.
◆ saveState()
void QtxWorkstackArea::saveState ( QDataStream &  stream) const
◆ setActiveWidget()
void QtxWorkstackArea::setActiveWidget ( QWidget *  wid)
Set active widget.
widwidget to be made active
References QtxWorkstackTabBar::indexOf(), myBar, and widgetId().
◆ setWidgetActive()
void QtxWorkstackArea::setWidgetActive ( QWidget *  wid)
widwidget to be set active
◆ showTabBar()
void QtxWorkstackArea::showTabBar ( bool  visible = true)
Show/Hide tab bar.
References myBar, and myTop.
◆ tabAt()
int QtxWorkstackArea::tabAt ( const QPoint &  pnt) const
ppoint
tab covering point or -1 if there is no tab covering point
References myBar.
◆ updateActiveState()
void QtxWorkstackArea::updateActiveState ( )
References isActive(), myBar, and QtxWorkstackTabBar::setActive().
◆ updateCurrent()
void QtxWorkstackArea::updateCurrent ( )
Raises widget when active tab page is changed.
References child(), myBar, myStack, and QtxWorkstackTabBar::tabId().
◆ updateState()
◆ updateTab()
void QtxWorkstackArea::updateTab ( QWidget *  wid)
Update tab bar.
widtab page widget
◆ widget()
QWidget * QtxWorkstackArea::widget ( const int  id) const
idwidget ID
widget or 0, if identifier in invalid
References child(), and QtxWorkstackChild::widget().
◆ widgetId()
int QtxWorkstackArea::widgetId ( QWidget *  wid) const
widwidget
widget ID or -1 if widget is not found
References child(), and QtxWorkstackChild::id().
◆ widgetList()
QWidgetList QtxWorkstackArea::widgetList ( ) const
list of visible child widgets
References myList, QtxWorkstackChild::visibility(), and QtxWorkstackChild::widget().
◆ workstack()
QtxWorkstack * QtxWorkstackArea::workstack ( ) const
workstack owning this workarea
◆ myBar
QtxWorkstackTabBar* QtxWorkstackArea::myBar
◆ myClose
QAbstractButton* QtxWorkstackArea::myClose
close button
◆ myList
ChildList QtxWorkstackArea::myList
child widgets list
◆ myStack
QStackedWidget* QtxWorkstackArea::myStack
widget stack
◆ myTop
QWidget* QtxWorkstackArea::myTop
workarea top widget
