QtxWorkstackDrag Class Reference
Workstack drag object. More...
#include <QtxWorkstack.h>
Inheritance diagram for QtxWorkstackDrag:
 QtxWorkstackDrag (QtxWorkstack *, QtxWorkstackChild *)
virtual ~QtxWorkstackDrag ()
 Custom event filter. More...
void dropWidget ()
 Called when drop operation is finished. More...
void updateTarget (const QPoint &)
 Detect and set dropping target widget. More...
QtxWorkstackArea * detectTarget (const QPoint &, int &) const
 Detect dropping target. More...
void setTarget (QtxWorkstackArea *, const int)
 Set dropping target. More...
void drawRect ()
 Draw floating rectangle. More...
void endDrawRect ()
 Delete rubber band on the end on the dragging operation. More...
void startDrawRect ()
 Create rubber band to be drawn on the dragging operation. More...
QtxWorkstack * myWS
 parent workstack More...
QtxWorkstackChild * myChild
 workstack child widget container More...
int myTab
 workarea tab page index More...
QtxWorkstackArea * myArea
 workarea More...
QRubberBand * myTabRect
 tab bar rubber band More...
QRubberBand * myAreaRect
 workarea rubber band More...
◆ QtxWorkstackDrag()
QtxWorkstackDrag::QtxWorkstackDrag ( QtxWorkstack *  ws,
QtxWorkstackChild *  child
wsparent workstack
childchild widget container
◆ ~QtxWorkstackDrag()
QtxWorkstackDrag::~QtxWorkstackDrag ( )
References endDrawRect().
◆ detectTarget()
QtxWorkstackArea * QtxWorkstackDrag::detectTarget ( const QPoint &  p,
int &  tab
pcurrent dragging position
tabresulting target tab page index
target workarea or 0 if there is no correct drop target
References QtxWorkstack::areaAt(), myWS, and QtxWorkstackArea::tabAt().
◆ drawRect()
void QtxWorkstackDrag::drawRect ( )
◆ dropWidget()
void QtxWorkstackDrag::dropWidget ( )
Inserts dropped widget to the target workarea.
References QtxWorkstackArea::insertChild(), myArea, myChild, and myTab.
◆ endDrawRect()
void QtxWorkstackDrag::endDrawRect ( )
References myAreaRect, and myTabRect.
◆ eventFilter()
bool QtxWorkstackDrag::eventFilter ( QObject *  ,
QEvent *  e
oevent receiver widget
eevent
true if event should be filtered (stop further processing)
References drawRect(), dropWidget(), endDrawRect(), and updateTarget().
◆ setTarget()
void QtxWorkstackDrag::setTarget ( QtxWorkstackArea *  area,
const int  tab
areanew target workarea
tabtarget workarea's tab page index
References drawRect(), myArea, myTab, and startDrawRect().
◆ startDrawRect()
void QtxWorkstackDrag::startDrawRect ( )
References myAreaRect, myTabRect, and Plot2d::Rectangle.
◆ updateTarget()
void QtxWorkstackDrag::updateTarget ( const QPoint &  p)
References detectTarget(), and setTarget().
◆ myArea
QtxWorkstackArea* QtxWorkstackDrag::myArea
workarea
◆ myAreaRect
QRubberBand* QtxWorkstackDrag::myAreaRect
◆ myChild
QtxWorkstackChild* QtxWorkstackDrag::myChild
◆ myTab
int QtxWorkstackDrag::myTab
◆ myTabRect
QRubberBand* QtxWorkstackDrag::myTabRect
tab bar rubber band
◆ myWS
QtxWorkstack* QtxWorkstackDrag::myWS
parent workstack
