SPV3D_CADSelection Class Reference
SPV3D_CADSelection handles various selection modes available on RenderViews. More...
#include <SPV3D_CADSelection.h>
Inheritance diagram for SPV3D_CADSelection:
enum  SelectionMode { SELECT_SOLIDS , SELECT_FACES , SELECT_EDGES , SELECT_VERTICES }
Public Slots
virtual void actionTriggered (bool val)
 For checkable actions, this calls this->beginSelection() or this->endSelection() is val is true or false, respectively. More...
 SPV3D_CADSelection (QObject *parent, pqRenderView *view, SelectionMode mode)
 If view is nullptr, this reaction will track the active-view maintained by pqActiveObjects. More...
 ~SPV3D_CADSelection () override
void SetMode (const SPV3D_CADSelection::SelectionMode mode)
 Set the selectionMode. More...
Private Slots
void setView (pqView *view)
 Called when this object was created with nullptr as the view and the active view changes. More...
void setRepresentation (pqDataRepresentation *representation)
 Called when the active representation changes. More...
void beginSelection ()
 starts the selection i.e. More...
void endSelection ()
 finishes the selection. More...
void updateEnableState ()
void onRightButtonPress ()
 Disable preselection during rotation using the right button. More...
void onRightButtonRelease ()
void selectionChanged (vtkObject *, unsigned long, void *calldata)
 callback called when the vtkPVRenderView is done with selection. More...
void onMouseMove ()
 callback called for mouse move events when in 'interactive selection' modes. More...
void onLeftButtonRelease ()
 callback called for click events when in 'interactive selection' modes. More...
int getSelectionModifier ()
void fastSelection (bool presel=false)
 makes fast selection. More...
void cleanupObservers ()
 cleans up observers. More...
 Q_DISABLE_COPY (SPV3D_CADSelection) QPointer< pqRenderView > View
QPointer< pqDataRepresentation > Representation
QMetaObject::Connection RepresentationConnection
vtkSMRepresentationProxy * CurrentRepresentation = nullptr
SelectionMode Mode
int PreviousRenderViewMode
vtkWeakPointer< vtkObject > ObservedObject
unsigned long ObserverIds [4]
int MousePosition [2]
QComboBox * selectionComboBox
bool DisablePreSelection = false
Simply create multiple instances of SPV3D_CADSelection to handle selection modes for that RenderView. SPV3D_CADSelection uses internal static members to ensure that at most 1 view (and 1 type of selection) is in selection-mode at any given time.
◆ SelectionMode
SELECT_SOLIDS
SELECT_FACES
SELECT_EDGES
SELECT_VERTICES
◆ SPV3D_CADSelection()
SPV3D_CADSelection::SPV3D_CADSelection ( QObject *  parent,
pqRenderView *  view,
SelectionMode  mode
References Mode, MousePosition, ObserverIds, PreviousRenderViewMode, setRepresentation(), setView(), updateEnableState(), and View.
◆ ~SPV3D_CADSelection()
SPV3D_CADSelection::~SPV3D_CADSelection ( )
override
References cleanupObservers().
◆ actionTriggered
void SPV3D_CADSelection::actionTriggered ( bool  val)
virtualslot
For non-checkable actions, this call this->beginSelection() and this->endSelection() in that order.
References beginSelection(), and endSelection().
◆ beginSelection
void SPV3D_CADSelection::beginSelection ( )
privateslot
setup render view in selection mode.
References ObservedObject, ObserverIds, onLeftButtonRelease(), onMouseMove(), onRightButtonPress(), onRightButtonRelease(), PreviousRenderViewMode, and View.
◆ cleanupObservers()
void SPV3D_CADSelection::cleanupObservers ( )
References ObservedObject, and ObserverIds.
◆ endSelection
void SPV3D_CADSelection::endSelection ( )
privateslot
Doesn't cause the selection, just returns the render view to previous interaction mode.
References cleanupObservers(), CurrentRepresentation, PreviousRenderViewMode, and View.
◆ fastSelection()
void SPV3D_CADSelection::fastSelection ( bool  presel = false)
◆ getSelectionModifier()
int SPV3D_CADSelection::getSelectionModifier ( )
References View.
◆ onLeftButtonRelease()
void SPV3D_CADSelection::onLeftButtonRelease ( )
References fastSelection().
◆ onMouseMove()
void SPV3D_CADSelection::onMouseMove ( )
References DisablePreSelection, fastSelection(), SPV3D_Prs::FromVtkIdToEntry(), and Representation.
◆ onRightButtonPress
void SPV3D_CADSelection::onRightButtonPress ( )
privateslot
References DisablePreSelection.
◆ onRightButtonRelease
void SPV3D_CADSelection::onRightButtonRelease ( )
privateslot
◆ Q_DISABLE_COPY()
SPV3D_CADSelection::Q_DISABLE_COPY ( SPV3D_CADSelection  )
◆ selectionChanged()
void SPV3D_CADSelection::selectionChanged ( vtkObject *  ,
unsigned long  ,
void *  calldata
References endSelection(), getSelectionModifier(), and View.
◆ SetMode()
void SPV3D_CADSelection::SetMode ( const SPV3D_CADSelection::SelectionMode  mode)
References Mode.
◆ setRepresentation
void SPV3D_CADSelection::setRepresentation ( pqDataRepresentation *  representation)
privateslot
References endSelection(), Representation, RepresentationConnection, and updateEnableState().
◆ setView
void SPV3D_CADSelection::setView ( pqView *  view)
privateslot
References endSelection(), and View.
◆ updateEnableState
void SPV3D_CADSelection::updateEnableState ( )
privateslot
◆ CurrentRepresentation
vtkSMRepresentationProxy* SPV3D_CADSelection::CurrentRepresentation = nullptr
◆ DisablePreSelection
bool SPV3D_CADSelection::DisablePreSelection = false
◆ Mode
SelectionMode SPV3D_CADSelection::Mode
◆ MousePosition
int SPV3D_CADSelection::MousePosition[2]
◆ ObservedObject
vtkWeakPointer<vtkObject> SPV3D_CADSelection::ObservedObject
◆ ObserverIds
unsigned long SPV3D_CADSelection::ObserverIds[4]
◆ PreviousRenderViewMode
int SPV3D_CADSelection::PreviousRenderViewMode
◆ Representation
QPointer<pqDataRepresentation> SPV3D_CADSelection::Representation
◆ RepresentationConnection
QMetaObject::Connection SPV3D_CADSelection::RepresentationConnection
◆ selectionComboBox
QComboBox* SPV3D_CADSelection::selectionComboBox
