SUIT_FileValidator Class Reference
Provides functionality to check the file or directory existance and permissions. More...
#include <SUIT_FileValidator.h>
Inheritance diagram for SUIT_FileValidator:
 SUIT_FileValidator (QWidget *=0)
virtual ~SUIT_FileValidator ()
virtual bool canOpen (const QString &, bool=true)
 Check if the specified file exists and (optionally) can be read. More...
virtual bool canSave (const QString &, bool=true)
 Check if the specified file can be written. More...
virtual bool canReadDir (const QString &, bool=true)
 Check if the specified directory exists and (optionally) can be read. More...
virtual bool canWriteDir (const QString &, bool=true)
 Check if the specified directory can be written. More...
QWidget * parent () const
 Get parent widget. More...
QWidget * myParent
See also
SUIT_FileDlg class
◆ SUIT_FileValidator()
SUIT_FileValidator::SUIT_FileValidator ( QWidget *  parent = 0)
parentparent widget (used as parent when displaying information message boxes)
◆ ~SUIT_FileValidator()
virtual SUIT_FileValidator::~SUIT_FileValidator ( )
◆ canOpen()
bool SUIT_FileValidator::canOpen ( const QString &  fileName,
bool  checkPermission = true
If file does not exists or can not be read (if checkPermission is true) and parent() is not null, shows error message box.
fileNamefile path
checkPermissionif true (default) check also file permissions
false if file does not exist or if it does not have read permissions (if checkPermission is true)
References SUIT_MessageBox::critical(), and parent().
◆ canReadDir()
bool SUIT_FileValidator::canReadDir ( const QString &  dirName,
If directory does not exists or can not be read (if checkPermission is true) and parent() is not null, shows error message box.
dirNamedirectory path
checkPermissionif true (default) check also directory permissions
false if directory does not exist or if it does not have read permissions (if checkPermission is true)
◆ canSave()
bool SUIT_FileValidator::canSave ( const QString &  fileName,
If file already exists and parent() is not null, prompts question message box to the user to confirm file overwriting.
If file can not be written (if checkPermission is true) and parent() is not null, shows error message box.
fileNamefile path
false if file exists and user rejects file overwriting or if file does not have write permissions (if checkPermission is true)
Reimplemented in LightApp_PyFileValidator.
References SUIT_MessageBox::critical(), Qtx::dir(), myParent, parent(), and SUIT_MessageBox::question().
◆ canWriteDir()
bool SUIT_FileValidator::canWriteDir ( const QString &  dirName,
If directory does not exists or can not be modified (if checkPermission is true) and parent() is not null, shows error message box.
false if directory does not exist or if it does not have write permissions (if checkPermission is true)
◆ parent()
QWidget * SUIT_FileValidator::parent ( ) const
Get parent widget.
parent widget
References myParent.
◆ myParent
QWidget* SUIT_FileValidator::myParent
