SUIT_FileDlg Class Reference
An extension of the Qt Open/Save file dialog box. More...
#include <SUIT_FileDlg.h>
Inheritance diagram for SUIT_FileDlg:
 SUIT_FileDlg (QWidget *, bool, bool=true, bool=true)
 SUIT_FileDlg (QWidget *parent, const QString &initial, const QStringList &filters, const QString &caption=QString(), const bool open=true, const bool showQuickDir=true, SUIT_FileValidator *validator=0)
virtual ~SUIT_FileDlg ()
bool isOpenDlg () const
 Check if the dialog box is used for opening or saving the file. More...
bool checkPermissions () const
 Get 'check file permissions' flag. More...
void setCheckPermissions (const bool)
 Set 'check file permissions' flag. More...
SUIT_FileValidator * validator () const
 Get file validator. More...
void setValidator (SUIT_FileValidator *)
 Set file validator. More...
bool addWidgets (QWidget *, QWidget *, QWidget *)
 Adds the specified widgets to the bottom of the file dialog. More...
QStringList selectedFiles () const
 Get list of selected files. More...
QString selectedFile () const
 Get selected file. More...
void selectFile (const QString &)
 Selects current file. More...
static QString getLastVisitedDirectory ()
 Get last visited directory. More...
static QString getFileName (QWidget *, const QString &, const QStringList &, const QString &=QString(), const bool=true, const bool=true, SUIT_FileValidator *=0)
 Show dialog box for the file opening/saving. More...
static QString getFileName (QWidget *, const QString &, const QString &, const QString &=QString(), const bool=true, const bool=true, SUIT_FileValidator *=0)
 Show dialog box for the file opening/saving. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.This method can be used to select the file for opening or saving. The behavior is defined by the open parameter. Note, that selection validation depends on the dialog mode used. More...
static QString getFileName (QWidget *parent, const QString &initial, const QStringList &filters, QString &selectedFilter, const QString &caption=QString(), const bool open=true, const bool showQuickDir=true, SUIT_FileValidator *validator=0)
static QStringList getOpenFileNames (QWidget *, const QString &, const QStringList &, const QString &=QString(), const bool=true, SUIT_FileValidator *=0)
 Show dialog box for the multiple files selection. More...
static QStringList getOpenFileNames (QWidget *, const QString &, const QStringList &, QString &, const QString &=QString(), const bool=true, SUIT_FileValidator *=0)
static QStringList getOpenFileNames (QWidget *, const QString &, const QString &, const QString &=QString(), const bool=true, SUIT_FileValidator *=0)
 Show dialog box for the multiple file opening. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.If initial parameter is not null string it is used as starting directory or file at which dialog box is opened. More...
static QString getExistingDirectory (QWidget *, const QString &, const QString &=QString(), const bool=true, SUIT_FileValidator *=0)
 Show dialog box for the existing directory selection. More...
static QString getLastVisitedPath ()
 Get last visited path. More...
Protected Slots
void accept ()
 Called when the user presses "Open"or "Save" button. More...
void quickDir (const QString &)
 Called when user selects directory from the "Quick Dir" combo box. More...
void addQuickDir ()
 Called when user presses "Quick Dir Add" button. More...
virtual bool event (QEvent *)
 Customize events processing. More...
QLineEdit * lineEdit () const
 Get line edit which is used to enter file name. More...
virtual bool acceptData ()
 Validate user selection. More...
QString addExtension (const QString &) const
 Add an extension to the specified file name. More...
bool processPath (const QString &)
 Processes selection : tries to set specified sirectory or filename as current file dialog selection. More...
void addFilter (const QString &)
 Add file filter and activates it. More...
static bool hasWildCards (const QString &)
 Check if the string contains wildcard symbols. More...
void polish ()
 Polish the dialog box. More...
void updateSideBar ()
 Update side bar URLs list. More...
SUIT_FileValidator * myValidator
 file validator More...
QLabel * myQuickLab
 quick dir panel: label More...
QComboBox * myQuickCombo
 quick dir panel: combo box More...
QPushButton * myQuickButton
 quick dir panel: button More...
QStringList myUrls
 sidebar urls More...
bool myCheckPermissions
 check permissions option More...
Static Private Attributes
static QString myLastVisitedPath
 last visited path More...
The class SUIT_FileDlg provides a set of static methods which canbe used for file or directories selection:
Examples:
// select file to dump contents of the view
QStringList filters;
filters << "Image files (*.bmp *.gif *.jpg )" << "All files (*)";
QString fileName = SUIT_FileDlg::getFileName( desktop(),
QString(),
filters,
"Dump view",
false );
if ( !fileName.isEmpty() ) {
... writing image to the file
// select list of files to open in the editor windows
filters << "*.cpp | *.cxx | *.c++" << "*.h | *.hpp | *.hxx";
QStringList fileNames = SUIT_FileDlg::getOpenFileName( desktop(),
QString(),
filters,
QString() );
if ( !fileNames.isEmpty() ) {
... open files
static QString getFileName(QWidget *, const QString &, const QStringList &, const QString &=QString(), const bool=true, const bool=true, SUIT_FileValidator *=0)
Definition: SUIT_FileDlg.cxx:815
The class SUIT_FileDlg can be subclassed to implement custom file dialog boxes. The class provides a set of methods which can be used in subclasses:
See also
SUIT_FileValidator class.
◆ SUIT_FileDlg() [1/2]
SUIT_FileDlg::SUIT_FileDlg ( QWidget *  parent,
bool  open,
bool  showQuickDir = true,
bool  modal = true
parentparent widget
openif true dialog box is used for file opening, otherwise - for saving
showQuickDirif true the quick directory list widgets will be shown
modalif true the dialog box will be modal
References addQuickDir(), addWidgets(), QtxResourceMgr::booleanValue(), myLastVisitedPath, myQuickButton, myQuickCombo, myQuickLab, myUrls, myValidator, processPath(), quickDir(), SUIT_Session::resourceMgr(), SUIT_Session::session(), QtxResourceMgr::stringValue(), and updateSideBar().
◆ SUIT_FileDlg() [2/2]
const QString &  initial,
const QStringList &  filters,
const QString &  caption = QString(),
const bool  open = true,
const bool  showQuickDir = true,
SUIT_FileValidator *  validator = 0
parentparent widget
initialinitial file (or directory) dialog box to be opened on
filtersfile filters list
captiondialog box title
validatorcustom file validator
References processPath(), setValidator(), and validator().
◆ ~SUIT_FileDlg()
SUIT_FileDlg::~SUIT_FileDlg ( )
References setValidator().
◆ accept
void SUIT_FileDlg::accept ( )
protectedslot
Verifies the user choice and closes dialog box, setting the return code to QDialog::Accepted
See also
acceptData()
References acceptData(), and myLastVisitedPath.
◆ acceptData()
bool SUIT_FileDlg::acceptData ( )
The validation is done by calling the corresponding methods of the validator. If the validator is not set, this method always returns true.
This method can be re-implemented in the subclasses to customize the file dialog behavior. Another solution could be implementing own file validator class.
true if user selection (file(s) or directory) is valid
See also
SUIT_FileValidator class, validator(), setValidator()
References addFilter(), SUIT_FileValidator::canOpen(), SUIT_FileValidator::canReadDir(), SUIT_FileValidator::canSave(), SUIT_FileValidator::canWriteDir(), checkPermissions(), hasWildCards(), isOpenDlg(), lineEdit(), selectedFiles(), and validator().
◆ addExtension()
QString SUIT_FileDlg::addExtension ( const QString &  fileName) const
The extension is extracted from the active filter.
fileNamefile name to be processed
fileName with the extension added
References Qtx::extension(), and IGNORE_NON_MATCHING_EXTENSION.
◆ addFilter()
void SUIT_FileDlg::addFilter ( const QString &  filter)
filternew file filter
◆ addQuickDir
void SUIT_FileDlg::addQuickDir ( )
protectedslot
Adds current directory to the quick directories list and to the preferences.
References myQuickCombo, myUrls, SUIT_Session::resourceMgr(), SUIT_Session::session(), QtxResourceMgr::setValue(), QtxResourceMgr::stringValue(), and updateSideBar().
◆ addWidgets()
bool SUIT_FileDlg::addWidgets ( QWidget *  l,
QWidget *  w,
QWidget *  b
The first widget (usually label) l is placed underneath the "file name" and the "file types" labels. The widget w is placed underneath the file types combobox. The last widget (usually button) b is placed underneath the Cancel push button.
In general, the widgets can be arbitrary. This method is added to support the functionality provided by the Qt series 3.x.
If you don't want to have one of the widgets added, pass 0 in that widget's position. Every time this function is called, a new row of widgets is added to the bottom of the file dialog.
lfirst widget (e.g. text label)
wsecond widget (e.g. combo box)
bthird widget (e.g. push button)
true if widgets have been added successfully
◆ checkPermissions()
bool SUIT_FileDlg::checkPermissions ( ) const
flag value
See also
setCheckPermissions()
References myCheckPermissions.
◆ event()
bool SUIT_FileDlg::event ( QEvent *  e)
eevent
true if the event e was recognized and processed
References polish().
◆ getExistingDirectory()
QString SUIT_FileDlg::getExistingDirectory ( QWidget *  parent,
If initial parameter is not null string it is used as starting directory at which dialog box is opened.
The parameter caption is used as dialog box title. If it is is empty, the default title is used.
The parameter showQuickDir specifies if it is necessary to show additional quick directories list controls in the bottom part of the dialog box.
The validation of the user selection is done with help of the file validator (SUIT_FileValidator class). The last parameter validator can be used to pass the custom file validator to the dialog box.
parentparent widget
initialinitial directory dialog box to be opened on
selected directory name or null string if dialog box is cancelled
See also
getFileName(), getOpenFileNames()
References processPath(), selectedFile(), setValidator(), and validator().
◆ getFileName() [1/3]
QString SUIT_FileDlg::getFileName ( QWidget *  parent,
const QString &  filters,
The parameter filters defines file filters (wildcards) to be used. This is the list of wildcards, separated by the ";;" symbols. If filters list is empty, "All files (*)" is used by default.
parentparent widget
filtersfile filters separated by ";;"
selected file name or null string if dialog box is cancelled
See also
getOpenFileNames(), getExistingDirectory()
References getFileName(), and validator().
◆ getFileName() [2/3]
The parameter filters defines file filters (wildcards) to be used. If filters list is empty, "All files (*)" is used by default.
parentparent widget
See also
References selectedFile(), and validator().
◆ getFileName() [3/3]
QString &  selectedFilter,
The parameter selectedFilter outputs a filter selected by user.
parentparent widget
selectedFilteroutputs a filter selected by user
See also
◆ getLastVisitedDirectory()
QString SUIT_FileDlg::getLastVisitedDirectory ( )
Note, that last visited path is memorized only if the dialog box is accepted.
References myLastVisitedPath.
◆ getLastVisitedPath()
QString SUIT_FileDlg::getLastVisitedPath ( )
last visited path
◆ getOpenFileNames() [1/3]
QStringList SUIT_FileDlg::getOpenFileNames ( QWidget *  parent,
parentparent widget
selected file names or empty list if dialog box is cancelled
See also
getFileName(), getExistingDirectory()
References getOpenFileNames(), and validator().
◆ getOpenFileNames() [2/3]
parentparent widget
See also
References processPath(), selectedFiles(), setValidator(), and validator().
◆ getOpenFileNames() [3/3]
The parameter selectedFilter inputs a filter selected by user.
parentparent widget
selectedFilterinputs a filter selected by user
See also
◆ hasWildCards()
bool SUIT_FileDlg::hasWildCards ( const QString &  s)
staticprotected
sstring to be checked (for example, file name)
true if string contains "*" or "?" symbols
◆ isOpenDlg()
bool SUIT_FileDlg::isOpenDlg ( ) const
true if dialog is used for file opening and false otherwise
◆ lineEdit()
QLineEdit * SUIT_FileDlg::lineEdit ( ) const
line edit widget or0 if it could not be found
◆ polish()
void SUIT_FileDlg::polish ( )
◆ processPath()
bool SUIT_FileDlg::processPath ( const QString &  path)
pathfile or directory path
true if path is processed correctly and false otherwise
References Qtx::dir(), Qtx::file(), and selectFile().
◆ quickDir
void SUIT_FileDlg::quickDir ( const QString &  dirPath)
protectedslot
Browses the file dialog to the specified directory (if it is valid).
dirPathselected directory
References SUIT_MessageBox::critical(), and processPath().
◆ selectedFile()
QString SUIT_FileDlg::selectedFile ( ) const
Get selected file.
selected file name or null string if file is not selected
References selectedFiles().
◆ selectedFiles()
QStringList SUIT_FileDlg::selectedFiles ( ) const
selected file names
References addExtension().
◆ selectFile()
void SUIT_FileDlg::selectFile ( const QString &  f)
This version of selectFile() methods works similar to Qt version 3.x: it selects the given file as current and it changes the current file dialog's directory to the directory of the file
f- new current file name
References Qtx::dir().
◆ setCheckPermissions()
void SUIT_FileDlg::setCheckPermissions ( const bool  checkPerm)
If this flag is set and file validator is not null, the validator will check the file permissions also.
checkPermnew flag value
See also
checkPermissions()
◆ setValidator()
void SUIT_FileDlg::setValidator ( SUIT_FileValidator *  v)
Set file validator.
Destroys previous validator if the dialog owns it.
vnew file validator
See also
validator()
References myValidator, and SUIT_FileValidator::parent().
◆ updateSideBar()
void SUIT_FileDlg::updateSideBar ( )
References myUrls.
◆ validator()
SUIT_FileValidator * SUIT_FileDlg::validator ( ) const
Get file validator.
current file validator
See also
setValidator()
References myValidator.
◆ myCheckPermissions
bool SUIT_FileDlg::myCheckPermissions
◆ myLastVisitedPath
QString SUIT_FileDlg::myLastVisitedPath
staticprivate
last visited path
◆ myQuickButton
QPushButton* SUIT_FileDlg::myQuickButton
◆ myQuickCombo
QComboBox* SUIT_FileDlg::myQuickCombo
◆ myQuickLab
QLabel* SUIT_FileDlg::myQuickLab
◆ myUrls
QStringList SUIT_FileDlg::myUrls
sidebar urls
◆ myValidator
SUIT_FileValidator* SUIT_FileDlg::myValidator
file validator
