SVTK_Selector Class Referenceabstract
Define an abstract interface for selection in SVTK package. More...
#include <SVTK_Selector.h>
Inheritance diagram for SVTK_Selector:
typedef int TFilterID
 vtkTypeMacro (SVTK_Selector, vtkObject) virtual void SetSelectionMode(Selection_Mode theMode)=0
 To change current Selection_Mode (as outside effect, it invokes selectionChange signal) More...
virtual Selection_Mode SelectionMode () const =0
 Get current Selection_Mode. More...
virtual void ClearIObjects ()=0
 Clear selection. More...
virtual SALOME_Actor * GetActor (const Handle(SALOME_InteractiveObject)&theIO) const =0
 Try to find corresponding SALOME_Actor for given reference on SALOME_InteractiveObject. More...
virtual bool IsSelected (const Handle(SALOME_InteractiveObject)&theIO) const =0
 Check, is the SALOME_InteractiveObject is present into selection. More...
virtual bool IsSelected (SALOME_Actor *theActor) const =0
 Check, is the SALOME_Actor is present into selection. More...
virtual bool AddIObject (const Handle(SALOME_InteractiveObject)&theIO)=0
 Modify the selection by adding new reference on SALOME_InteractiveObject. More...
virtual bool AddIObject (SALOME_Actor *theActor)=0
 Modify the selection by adding new reference on SALOME_Actor. More...
virtual bool RemoveIObject (const Handle(SALOME_InteractiveObject)&theIO)=0
 Modify the selection by removing a reference on SALOME_InteractiveObject. More...
virtual bool RemoveIObject (SALOME_Actor *theActor)=0
 Modify the selection by removing a reference on SALOME_Actor. More...
virtual const SALOME_ListIO & StoredIObjects () const =0
 Get all SALOME_InteractiveObject references that is present into selection. More...
virtual int IObjectCount () const =0
 Get number of selected objects. More...
virtual bool HasIndex (const Handle(SALOME_InteractiveObject)&theIO) const =0
 Check, if the SALOME_InteractiveObject has a subselection. More...
virtual void GetIndex (const Handle(SALOME_InteractiveObject)&theIO, SVTK_TIndexedMapOfVtkId &theIndex)=0
 Get indexes of subslection for given SALOME_InteractiveObject. More...
virtual bool AddOrRemoveIndex (const Handle(SALOME_InteractiveObject)&theIO, const SVTK_TIndexedMapOfVtkId &theIndices, bool theIsModeShift)=0
 Change indices of subselection for given SALOME_InteractiveObject. More...
virtual bool AddOrRemoveIndex (const Handle(SALOME_InteractiveObject)&theIO, const SVTK_TVtkIDsMap &theIndices, bool theIsModeShift)=0
 Change indexes of subslection for given SALOME_InteractiveObject. More...
virtual bool AddOrRemoveIndex (const Handle(SALOME_InteractiveObject)&theIO, int theIndex, bool theIsModeShift)=0
 Change index of subslection for given SALOME_InteractiveObject. More...
virtual void RemoveIndex (const Handle(SALOME_InteractiveObject)&theIO, int theIndex)=0
virtual bool IsIndexSelected (const Handle(SALOME_InteractiveObject)&theIO, int theIndex) const =0
 Check, if the given index is present in subselection. More...
virtual void ClearIndex ()=0
 Clear subselection. More...
virtual bool HasCompositeIndex (const Handle(SALOME_InteractiveObject)&theIO) const =0
 ! Composite indexes More...
virtual void GetCompositeIndex (const Handle(SALOME_InteractiveObject)&theIO, SVTK_IndexedMapOfVtkIds &theIds)=0
 Get composite indexes of subslection for given SALOME_InteractiveObject. More...
virtual bool AddOrRemoveCompositeIndex (const Handle(SALOME_InteractiveObject)&theIO, const SVTK_IndexedMapOfVtkIds &theIds, bool theIsModeShift)=0
 Change composite indices of subselection for given SALOME_InteractiveObject. More...
virtual bool AddOrRemoveCompositeIndex (const Handle(SALOME_InteractiveObject)&theIO, SVTK_ListOfVtk ids, bool theIsModeShift)=0
 Change composite index of subslection for given SALOME_InteractiveObject. More...
virtual void RemoveCompositeIndex (const Handle(SALOME_InteractiveObject)&theIO, SVTK_ListOfVtk ids)=0
virtual bool IsCompositeIndexSelected (const Handle(SALOME_InteractiveObject)&theIO, SVTK_ListOfVtk ids) const =0
 Check, if the given composite index is present in subselection. More...
virtual void ClearCompositeIndex ()=0
 Clear composite indexes subselection. More...
virtual void SetFilter (const Handle(VTKViewer_Filter)&theFilter)=0
 To apply a filter on the selection. More...
virtual Handle (VTKViewer_Filter) GetFilter(const TFilterID theId) const =0
 To get a section filter by its number. More...
virtual bool IsFilterPresent (const TFilterID theId) const =0
 Check, if a filter with given number is applyed. More...
virtual void RemoveFilter (const TFilterID theId)=0
 To remove a filter from the selection. More...
virtual bool IsValid (SALOME_Actor *theActor, const int theId, const bool theIsNode=false) const =0
 Check, if the index satisfy to the installed filters. More...
virtual void StartPickCallback ()=0
virtual void EndPickCallback ()=0
 To invoke selectionChanged signals. More...
virtual vtkActorCollection * Pick (const SVTK_SelectionEvent *theEvent, vtkRenderer *theRenderer) const =0
virtual void SetTolerance (const double &theTolerance)=0
virtual void SetDynamicPreSelection (bool theIsDynPreselect)=0
virtual bool GetDynamicPreSelection () const =0
virtual void SetPreSelectionEnabled (bool theEnabled)=0
virtual bool IsPreSelectionEnabled () const =0
virtual void SetSelectionEnabled (bool theEnabled)=0
virtual bool IsSelectionEnabled () const =0
static SVTK_Selector * New ()
The class implements selection functionality through storing corresponding references to SALOME_InteractiveObject. For implementation of subselection modes it keeps a corresponding map of sub indexes.
Also, for each SALOME_InteractiveObject it tries to keep corresponding refenrence to SALOME_Actor
◆ TFilterID
◆ AddIObject() [1/2]
virtual bool SVTK_Selector::AddIObject ( const Handle(SALOME_InteractiveObject)&  theIO)
pure virtual
Implemented in SVTK_SelectorDef.
◆ AddIObject() [2/2]
virtual bool SVTK_Selector::AddIObject ( SALOME_Actor *  theActor)
pure virtual
◆ AddOrRemoveCompositeIndex() [1/2]
virtual bool SVTK_Selector::AddOrRemoveCompositeIndex ( const Handle(SALOME_InteractiveObject)&  theIO,
const SVTK_IndexedMapOfVtkIds &  theIds,
bool  theIsModeShift
pure virtual
◆ AddOrRemoveCompositeIndex() [2/2]
SVTK_ListOfVtk  ids,
bool  theIsModeShift
pure virtual
◆ AddOrRemoveIndex() [1/3]
virtual bool SVTK_Selector::AddOrRemoveIndex ( const Handle(SALOME_InteractiveObject)&  theIO,
const SVTK_TIndexedMapOfVtkId &  theIndices,
bool  theIsModeShift
pure virtual
◆ AddOrRemoveIndex() [2/3]
const SVTK_TVtkIDsMap &  theIndices,
bool  theIsModeShift
pure virtual
◆ AddOrRemoveIndex() [3/3]
int  theIndex,
bool  theIsModeShift
pure virtual
◆ ClearCompositeIndex()
virtual void SVTK_Selector::ClearCompositeIndex ( )
pure virtual
◆ ClearIndex()
virtual void SVTK_Selector::ClearIndex ( )
pure virtual
Clear subselection.
◆ ClearIObjects()
virtual void SVTK_Selector::ClearIObjects ( )
pure virtual
Clear selection.
◆ EndPickCallback()
virtual void SVTK_Selector::EndPickCallback ( )
pure virtual
◆ GetActor()
virtual SALOME_Actor * SVTK_Selector::GetActor ( const Handle(SALOME_InteractiveObject)&  theIO) const
pure virtual
◆ GetCompositeIndex()
virtual void SVTK_Selector::GetCompositeIndex ( const Handle(SALOME_InteractiveObject)&  theIO,
pure virtual
◆ GetDynamicPreSelection()
virtual bool SVTK_Selector::GetDynamicPreSelection ( ) const
pure virtual
◆ GetIndex()
virtual void SVTK_Selector::GetIndex ( const Handle(SALOME_InteractiveObject)&  theIO,
SVTK_TIndexedMapOfVtkId &  theIndex
pure virtual
◆ Handle()
virtual SVTK_Selector::Handle ( VTKViewer_Filter  ) const
pure virtual
◆ HasCompositeIndex()
virtual bool SVTK_Selector::HasCompositeIndex ( const Handle(SALOME_InteractiveObject)&  theIO) const
pure virtual
! Composite indexes
◆ HasIndex()
virtual bool SVTK_Selector::HasIndex ( const Handle(SALOME_InteractiveObject)&  theIO) const
pure virtual
◆ IObjectCount()
virtual int SVTK_Selector::IObjectCount ( ) const
pure virtual
◆ IsCompositeIndexSelected()
virtual bool SVTK_Selector::IsCompositeIndexSelected ( const Handle(SALOME_InteractiveObject)&  theIO,
SVTK_ListOfVtk  ids
pure virtual
◆ IsFilterPresent()
virtual bool SVTK_Selector::IsFilterPresent ( const TFilterID  theId) const
pure virtual
◆ IsIndexSelected()
virtual bool SVTK_Selector::IsIndexSelected ( const Handle(SALOME_InteractiveObject)&  theIO,
int  theIndex
pure virtual
◆ IsPreSelectionEnabled()
virtual bool SVTK_Selector::IsPreSelectionEnabled ( ) const
pure virtual
◆ IsSelected() [1/2]
virtual bool SVTK_Selector::IsSelected ( const Handle(SALOME_InteractiveObject)&  theIO) const
pure virtual
◆ IsSelected() [2/2]
virtual bool SVTK_Selector::IsSelected ( SALOME_Actor *  theActor) const
pure virtual
◆ IsSelectionEnabled()
virtual bool SVTK_Selector::IsSelectionEnabled ( ) const
pure virtual
◆ IsValid()
virtual bool SVTK_Selector::IsValid ( SALOME_Actor *  theActor,
const int  theId,
const bool  theIsNode = false
pure virtual
◆ New()
SVTK_Selector * SVTK_Selector::New ( )
new SVTK_Selector
◆ Pick()
virtual vtkActorCollection * SVTK_Selector::Pick ( const SVTK_SelectionEvent *  theEvent,
vtkRenderer *  theRenderer
pure virtual
◆ RemoveCompositeIndex()
virtual void SVTK_Selector::RemoveCompositeIndex ( const Handle(SALOME_InteractiveObject)&  theIO,
SVTK_ListOfVtk  ids
pure virtual
◆ RemoveFilter()
virtual void SVTK_Selector::RemoveFilter ( const TFilterID  theId)
pure virtual
◆ RemoveIndex()
virtual void SVTK_Selector::RemoveIndex ( const Handle(SALOME_InteractiveObject)&  theIO,
int  theIndex
pure virtual
◆ RemoveIObject() [1/2]
virtual bool SVTK_Selector::RemoveIObject ( const Handle(SALOME_InteractiveObject)&  theIO)
pure virtual
◆ RemoveIObject() [2/2]
virtual bool SVTK_Selector::RemoveIObject ( SALOME_Actor *  theActor)
pure virtual
◆ SelectionMode()
virtual Selection_Mode SVTK_Selector::SelectionMode ( ) const
pure virtual
◆ SetDynamicPreSelection()
virtual void SVTK_Selector::SetDynamicPreSelection ( bool  theIsDynPreselect)
pure virtual
◆ SetFilter()
virtual void SVTK_Selector::SetFilter ( const Handle(VTKViewer_Filter)&  theFilter)
pure virtual
◆ SetPreSelectionEnabled()
virtual void SVTK_Selector::SetPreSelectionEnabled ( bool  theEnabled)
pure virtual
◆ SetSelectionEnabled()
virtual void SVTK_Selector::SetSelectionEnabled ( bool  theEnabled)
pure virtual
◆ SetTolerance()
virtual void SVTK_Selector::SetTolerance ( const double &  theTolerance)
pure virtual
◆ StartPickCallback()
virtual void SVTK_Selector::StartPickCallback ( )
pure virtual
◆ StoredIObjects()
virtual const SALOME_ListIO & SVTK_Selector::StoredIObjects ( ) const
pure virtual
◆ vtkTypeMacro()
SVTK_Selector::vtkTypeMacro ( SVTK_Selector  ,
vtkObject
pure virtual
