SALOME_Actor Class Reference
The class is a basic one for all SALOME VTK presentation. More...
#include <SALOME_Actor.h>
Inheritance diagram for SALOME_Actor:
 vtkTypeMacro (SALOME_Actor, VTKViewer_Actor) virtual Standard_Boolean hasIO()
 To check, if the SALOME_Actor has a reference to SALOME_InteractiveObject. More...
virtual const Handle (SALOME_InteractiveObject) &getIO()
 Get correspoinding reference to SALOME_InteractiveObject. More...
virtual void setIO (const Handle(SALOME_InteractiveObject)&theIO)
 Set reference to SALOME_InteractiveObject. More...
virtual void setName (const char *theName)
 Name the SALOME_Actor. More...
virtual void SetTransform (VTKViewer_Transform *theTransform)
 Apply view transformation. More...
virtual void SetPosition (double _arg1, double _arg2, double _arg3)
 Apply additional position. More...
virtual void SetPosition (double _arg[3])
virtual void SetVisibility (int)
 Visibility management. More...
virtual bool ShouldBeDisplayed ()
 Gets know whether the actor should be displayed or not. More...
virtual void AddToRender (vtkRenderer *theRendere)
 To publish the actor an all its internal devices. More...
virtual void RemoveFromRender (vtkRenderer *theRendere)
 To remove the actor an all its internal devices. More...
vtkRenderer * GetRenderer ()
 Get reference on renderer where it is published. More...
virtual void SetInteractor (vtkRenderWindowInteractor *theInteractor)
 To set interactor in order to use vtkInteractorObserver devices. More...
virtual void Update ()
 Put a request to redraw the view. More...
virtual void SetSelector (SVTK_Selector *theSelector)
 Set selector in order to the actor at any time can restore current selection. More...
virtual void highlight (bool theHighlight)
 Just to update visibility of the highlight devices. More...
virtual void Highlight (bool theHighlight)
 To map current selection to VTK representation. More...
virtual bool PreHighlight (vtkInteractorStyle *theInteractorStyle, SVTK_SelectionEvent *theSelectionEvent, bool theIsHighlight)
 To process prehighlight (called from SVTK_InteractorStyle) More...
virtual bool Highlight (vtkInteractorStyle *theInteractorStyle, SVTK_SelectionEvent *theSelectionEvent, bool theIsHighlight)
 To process highlight (called from SVTK_InteractorStyle) More...
virtual bool IsDisplayNameActor () const
 To get flag of displaying of name actor. More...
virtual void SetIsDisplayNameActor (bool theIsDisplayNameActor)
 To set flag of displaying of name actor. More...
virtual void SetNameActorText (const char *theText)
 To set text of name actor. More...
virtual void SetNameActorOffset (double theOffset[2])
 To set offset of name actor. More...
virtual void GetNameActorSize (vtkRenderer *theRenderer, double theSize[2]) const
 To get size of name actor. More...
virtual void UpdateNameActors ()
 To update visibility of name actors. More...
virtual void SetMarkerStd (VTK::MarkerType, VTK::MarkerScale)
 Set standard point marker. More...
virtual void SetMarkerTexture (int, VTK::MarkerTexture)
 Set custom point marker. More...
virtual VTK::MarkerType GetMarkerType ()
 Get type of the point marker. More...
virtual VTK::MarkerScale GetMarkerScale ()
 Get scale of the point marker. More...
virtual int GetMarkerTexture ()
 Get texture identifier of the point marker. More...
void SetPointPicker (vtkPointPicker *thePointPicker)
 To set up a picker for nodal selection (initialized by SVTK_Renderer::AddActor) More...
void SetCellPicker (vtkCellPicker *theCellPicker)
 To set up a picker for cell selection (initialized by SVTK_Renderer::AddActor) More...
void SetPointAreaPicker (SVTK_AreaPicker *theAreaPicker)
 To set up a picker for point rectangle selection (initialized by SVTK_Renderer::AddActor) More...
void SetCellAreaPicker (SVTK_AreaPicker *theAreaPicker)
 To set up a picker for cell rectangle selection (initialized by SVTK_Renderer::AddActor) More...
double * GetGravityCenter (int)
 To find a gravity center of object. More...
void SetPreHighlightProperty (vtkProperty *theProperty)
 To set up a prehighlight property (initialized by SVTK_Renderer::AddActor) More...
void SetHighlightProperty (vtkProperty *theProperty)
 To set up a highlight property (initialized by SVTK_Renderer::AddActor) More...
- Public Member Functions inherited from VTKViewer_Actor
 vtkTypeMacro (VTKViewer_Actor, vtkLODActor) virtual const char *getName()
 Get its name. More...
 Name the VTKViewer_Actor. More...
virtual void SetOpacity (double theOpacity)
 Change opacity. More...
virtual double GetOpacity ()
 Get current opacity. More...
virtual void SetColor (double r, double g, double b)
 Change color. More...
virtual void GetColor (double &r, double &g, double &b)
 Get current color. More...
virtual void SetColor (const double theRGB[3])
virtual void SetMaterial (std::vector< vtkProperty * > theProps)
 Change material. More...
virtual vtkProperty * GetFrontMaterial ()
 Get current front material. More...
virtual vtkProperty * GetBackMaterial ()
 Get current back material. More...
virtual vtkIdType GetNodeObjId (vtkIdType theVtkID)
 Maps VTK index of a node to corresponding object index. More...
virtual double * GetNodeCoord (vtkIdType theObjID)
 Get coordinates of a node for given object index. More...
virtual vtkIdType GetNodeVtkId (vtkIdType theObjID)
 Maps object index of a node to corresponding VTK index. More...
virtual vtkIdType GetElemObjId (vtkIdType theVtkID)
 Maps VTK index of a cell to corresponding object index. More...
virtual vtkCell * GetElemCell (vtkIdType theObjID)
 Get corresponding #vtkCell for given object index. More...
virtual int GetObjDimension (const vtkIdType theObjId)
 Get dimension of corresponding mesh element. More...
virtual void SetMapper (vtkMapper *theMapper)
 To insert some additional filters and then sets the given #vtkMapper. More...
virtual vtkDataSet * GetInput ()
 Allows to get initial #vtkDataSet. More...
virtual vtkMTimeType GetMTime ()
 To calculatate last modified time. More...
virtual void SetRepresentation (int theMode)
 Set representation (VTK_SURFACE, VTK_POINTS, VTK_WIREFRAME and so on) More...
virtual int GetRepresentation ()
 Get current representation mode. More...
virtual int getDisplayMode ()
 Get current display mode (obsolete) More...
virtual void setDisplayMode (int theMode)
 Set display mode (obsolete) More...
void SetInfinitive (bool theIsInfinite)
 Set infinive flag. More...
virtual bool IsInfinitive ()
 Get infinive flag. More...
virtual double * GetBounds ()
 To calcualte current bounding box. More...
void GetBounds (double bounds[6])
virtual bool IsSetCamera () const
virtual bool IsResizable () const
virtual void SetSize (const double)
virtual void SetCamera (vtkCamera *)
void SetResolveCoincidentTopology (bool theIsResolve)
 Set ResolveCoincidentTopology flag. More...
void SetPolygonOffsetParameters (double factor, double units)
 Set ResolveCoincidentTopology parameters. More...
void GetPolygonOffsetParameters (double &factor, double &units)
 Get current ResolveCoincidentTopology parameters. More...
virtual void Render (vtkRenderer *, vtkMapper *)
virtual double GetShrinkFactor ()
 Get current shrink factor. More...
virtual bool IsShrunkable ()
 Is the actor is shrunkable. More...
virtual bool IsShrunk ()
 Is the actor is shrunk. More...
virtual void SetShrink ()
 Insert shrink filter into pipeline. More...
virtual void UnShrink ()
 Remove shrink filter from pipeline. More...
virtual void GetChildActors (vtkActorCollection *)
 Used to obtain all dependent actors. More...
virtual void EnableSelection (bool)
 Is notified on enabling/disabling selection. More...
virtual bool hasHighlight ()
 Ask, if the descendant of the VTKViewer_Actor will implement its own highlight or not. More...
virtual bool isHighlighted ()
 Ask, if the VTKViewer_Actor is already highlighted. More...
virtual bool isPreselected ()
 Ask, if the VTKViewer_Actor is already preselected. More...
virtual void SetPreSelected (bool thePreselect=false)
 Set preselection mode. More...
void SetPreviewProperty (vtkProperty *theProperty)
virtual void SetQuadraticArcMode (bool theFlag)
 Setting for displaying quadratic elements. More...
virtual bool GetQuadraticArcMode () const
virtual void SetQuadraticArcAngle (double theMaxAngle)
virtual double GetQuadraticArcAngle () const
virtual vtkDataSet * GetHighlightedDataSet ()
 Return pointer to the dataset, which used to calculation of the bounding box of the actor. More...
static SALOME_Actor * New ()
- Static Public Member Functions inherited from VTKViewer_Actor
static VTKViewer_Actor * New ()
static void GetDefaultPolygonOffsetParameters (double &factor, double &units)
 Get default ResolveCoincidentTopology parameters. More...
 Handle (SALOME_InteractiveObject) myIO
 SALOME_Actor ()
 ~SALOME_Actor ()
- Protected Member Functions inherited from VTKViewer_Actor
void InitPipeLine (vtkMapper *theMapper)
 VTKViewer_Actor ()
 ~VTKViewer_Actor ()
vtkRenderWindowInteractor * myInteractor
vtkRenderer * myRenderer
Selection_Mode mySelectionMode
vtkSmartPointer< SVTK_Selector > mySelector
vtkSmartPointer< vtkPointPicker > myPointPicker
vtkSmartPointer< vtkCellPicker > myCellPicker
vtkSmartPointer< SVTK_AreaPicker > myPointAreaPicker
vtkSmartPointer< SVTK_AreaPicker > myCellAreaPicker
vtkSmartPointer< SVTK_Actor > myPreHighlightActor
vtkSmartPointer< SVTK_Actor > myHighlightActor
vtkSmartPointer< VTKViewer_Actor > myOutlineActor
vtkSmartPointer< vtkOutlineSource > myOutline
bool myIsDisplayNameActor
vtkSmartPointer< VTKViewer_FramedTextActor > myNameActor
- Protected Attributes inherited from VTKViewer_Actor
bool myIsResolveCoincidentTopology
double myPolygonOffsetFactor
double myPolygonOffsetUnits
std::string myName
double myOpacity
int myDisplayMode
bool myIsInfinite
bool myStoreMapping
VTKViewer_GeometryFilter * myGeomFilter
VTKViewer_TransformFilter * myTransformFilter
std::vector< vtkPassThrough * > myPassFilter
int myRepresentation
vtkProperty * myProperty
vtkProperty * PreviewProperty
bool myIsPreselected
bool myIsHighlighted
Abstract class of SALOME Objects in VTK.
It provide highlight and prehighlight capabilites, common way to publish and remove VTK presentation, mapping of VTK and object IDs and so on.
◆ SALOME_Actor()
SALOME_Actor::SALOME_Actor ( )
◆ ~SALOME_Actor()
SALOME_Actor::~SALOME_Actor ( )
Destructor
◆ AddToRender()
void SALOME_Actor::AddToRender ( vtkRenderer *  theRenderer)
Publishes the actor in all its internal devices
Reimplemented from VTKViewer_Actor.
References myHighlightActor, myNameActor, myOutlineActor, myPreHighlightActor, and myRenderer.
◆ GetGravityCenter()
double * SALOME_Actor::GetGravityCenter ( int  theObjId)
theObjId- identification of object
References VTKViewer_Actor::GetElemCell().
◆ GetMarkerScale()
VTK::MarkerScale SALOME_Actor::GetMarkerScale ( )
References myPreHighlightActor.
◆ GetMarkerTexture()
int SALOME_Actor::GetMarkerTexture ( )
◆ GetMarkerType()
VTK::MarkerType SALOME_Actor::GetMarkerType ( )
◆ GetNameActorSize()
void SALOME_Actor::GetNameActorSize ( vtkRenderer *  theRenderer,
double  theSize[2]
theRenderer- renderer
theSize- size of name actor
References myNameActor.
◆ GetRenderer()
vtkRenderer * SALOME_Actor::GetRenderer ( )
References myRenderer.
◆ Handle() [1/2]
virtual const SALOME_Actor::Handle ( SALOME_InteractiveObject  ) &
◆ Handle() [2/2]
◆ highlight()
void SALOME_Actor::highlight ( bool  theIsHighlight)
Updates visibility of the highlight devices
References VTKViewer_Actor::GetHighlightedDataSet(), myOutline, and myOutlineActor.
◆ Highlight() [1/2]
void SALOME_Actor::Highlight ( bool  theIsHighlight)
◆ Highlight() [2/2]
◆ IsDisplayNameActor()
bool SALOME_Actor::IsDisplayNameActor ( ) const
flag to display or not to display name actor
References myIsDisplayNameActor.
◆ New()
static SALOME_Actor * SALOME_Actor::New ( )
◆ PreHighlight()
◆ RemoveFromRender()
void SALOME_Actor::RemoveFromRender ( vtkRenderer *  theRenderer)
Removes the actor from all its internal devices
References myHighlightActor, myNameActor, myOutlineActor, and myPreHighlightActor.
◆ SetCellAreaPicker()
void SALOME_Actor::SetCellAreaPicker ( SVTK_AreaPicker *  theAreaPicker)
To set up a picker for cell rectangle of polygonal selection (initialized by SVTK_Renderer::AddActor)
theAreaPicker- new picker
References myCellAreaPicker.
◆ SetCellPicker()
void SALOME_Actor::SetCellPicker ( vtkCellPicker *  theCellPicker)
theCellPicker- new picker
References myCellPicker.
◆ SetHighlightProperty()
void SALOME_Actor::SetHighlightProperty ( vtkProperty *  theProperty)
References myHighlightActor.
◆ SetInteractor()
void SALOME_Actor::SetInteractor ( vtkRenderWindowInteractor *  theInteractor)
Sets interactor in order to use vtkInteractorObserver devices
theInteractor- new interactor
References myInteractor.
◆ setIO()
void SALOME_Actor::setIO ( const Handle(SALOME_InteractiveObject)&  theIO)
Sets reference to SALOME_InteractiveObject
theIO- new SALOME_InteractiveObject
◆ SetIsDisplayNameActor()
void SALOME_Actor::SetIsDisplayNameActor ( bool  theIsDisplayNameActor)
theIsDisplayNameActorflag to display or not to display name actor
References QtxResourceMgr::booleanValue(), myIsDisplayNameActor, SUIT_Session::resourceMgr(), SUIT_Session::session(), and UpdateNameActors().
◆ SetMarkerStd()
void SALOME_Actor::SetMarkerStd ( VTK::MarkerType  theMarkerType,
VTK::MarkerScale  theMarkerScale
theMarkerTypetype of the marker
theMarkerScalescale of the marker
References myHighlightActor, and myPreHighlightActor.
◆ SetMarkerTexture()
void SALOME_Actor::SetMarkerTexture ( int  theMarkerId,
VTK::MarkerTexture  theMarkerTexture
theMarkerIdid of the marker texture
theMarkerTexturemarker texture
◆ setName()
void SALOME_Actor::setName ( const char *  theName)
Sets name the SALOME_Actor
theName- new name
◆ SetNameActorOffset()
void SALOME_Actor::SetNameActorOffset ( double  theOffset[2])
theOffset- offset of name actor
◆ SetNameActorText()
void SALOME_Actor::SetNameActorText ( const char *  theText)
theText- text of name actor
◆ SetPointAreaPicker()
void SALOME_Actor::SetPointAreaPicker ( SVTK_AreaPicker *  theAreaPicker)
To set up a picker for point rectangle or polygonal selection (initialized by SVTK_Renderer::AddActor)
References myPointAreaPicker.
◆ SetPointPicker()
void SALOME_Actor::SetPointPicker ( vtkPointPicker *  thePointPicker)
thePointPicker- new picker
References myPointPicker.
◆ SetPosition() [1/2]
void SALOME_Actor::SetPosition ( double  _arg1,
double  _arg2,
double  _arg3
References myHighlightActor, myOutlineActor, and myPreHighlightActor.
◆ SetPosition() [2/2]
void SALOME_Actor::SetPosition ( double  _arg[3])
References SetPosition().
◆ SetPreHighlightProperty()
void SALOME_Actor::SetPreHighlightProperty ( vtkProperty *  theProperty)
◆ SetSelector()
void SALOME_Actor::SetSelector ( SVTK_Selector *  theSelector)
theSelector- new selector
References mySelector.
◆ SetTransform()
void SALOME_Actor::SetTransform ( VTKViewer_Transform *  theTransform)
theTransform- transformation
◆ SetVisibility()
void SALOME_Actor::SetVisibility ( int  theVisibility)
◆ ShouldBeDisplayed()
bool SALOME_Actor::ShouldBeDisplayed ( )
◆ Update()
void SALOME_Actor::Update ( )
◆ UpdateNameActors()
void SALOME_Actor::UpdateNameActors ( )
Update visibility of name actors
References VTK::ActorCollectionCopy::GetActors(), GetRenderer(), IsDisplayNameActor(), and myNameActor.
◆ vtkTypeMacro()
SALOME_Actor::vtkTypeMacro ( SALOME_Actor  ,
VTKViewer_Actor
◆ myCellAreaPicker
vtkSmartPointer<SVTK_AreaPicker> SALOME_Actor::myCellAreaPicker
◆ myCellPicker
vtkSmartPointer<vtkCellPicker> SALOME_Actor::myCellPicker
◆ myHighlightActor
vtkSmartPointer<SVTK_Actor> SALOME_Actor::myHighlightActor
◆ myInteractor
vtkRenderWindowInteractor* SALOME_Actor::myInteractor
◆ myIsDisplayNameActor
bool SALOME_Actor::myIsDisplayNameActor
◆ myNameActor
vtkSmartPointer<VTKViewer_FramedTextActor> SALOME_Actor::myNameActor
◆ myOutline
vtkSmartPointer<vtkOutlineSource> SALOME_Actor::myOutline
◆ myOutlineActor
vtkSmartPointer<VTKViewer_Actor> SALOME_Actor::myOutlineActor
◆ myPointAreaPicker
vtkSmartPointer<SVTK_AreaPicker> SALOME_Actor::myPointAreaPicker
◆ myPointPicker
vtkSmartPointer<vtkPointPicker> SALOME_Actor::myPointPicker
◆ myPreHighlightActor
vtkSmartPointer<SVTK_Actor> SALOME_Actor::myPreHighlightActor
◆ myRenderer
vtkRenderer* SALOME_Actor::myRenderer
◆ mySelectionMode
Selection_Mode SALOME_Actor::mySelectionMode
◆ mySelector
vtkSmartPointer<SVTK_Selector> SALOME_Actor::mySelector
