SVTK_Renderer Class Reference
#include <SVTK_Renderer.h>
Inheritance diagram for SVTK_Renderer:
 vtkTypeMacro (SVTK_Renderer, vtkObject) static SVTK_Renderer *New()
vtkRenderer * GetDevice ()
 Get its device. More...
virtual void Initialize (vtkRenderWindowInteractor *theInteractor, SVTK_Selector *theSelector)
 Initialize the class. More...
virtual void AddActor (VTKViewer_Actor *theActor, bool theIsAdjustActors=true)
 Publishes pointed actor into the renderer. More...
virtual void RemoveActor (VTKViewer_Actor *theActor, bool theIsAdjustActors=true)
 Removes pointed actor from the renderer. More...
VTKViewer_Transform * GetTransform ()
 Get special container that keeps scaling of the scene. More...
virtual void SetScale (double theScale[3])
 Allows to apply a scale on the whole scene. More...
void GetScale (double theScale[3])
 Allows to get a scale that is applied on the whole scene. More...
void SetSelectionProp (const double &theRed=1, const double &theGreen=1, const double &theBlue=0, const int &theWidth=5)
 Applies color and size (PointSize and LineWidth) of primitives in selection mode. More...
void SetPreselectionProp (const double &theRed=0, const double &theGreen=1, const double &theBlue=1, const int &theWidth=5)
 Applies color and size (PointSize and LineWidth) of primitives in preselection mode. More...
void SetSelectionTolerance (const double &theTolNodes=0.025, const double &theTolCell=0.001, const double &theTolObjects=0.025)
 Setup requested tolerance for the picking. More...
void AdjustActors ()
 Adjust all intenal actors (trihedron and graduated rules) to the scene. More...
void SetTrihedronSize (double theSize, const bool theRelative=true)
 Set size of the trihedron in percents from bounding box of the scene. More...
double GetTrihedronSize () const
 Get size of the trihedron in percents from bounding box of the scene. More...
bool IsTrihedronRelative () const
 Shows if the size of the trihedron is relative. More...
VTKViewer_Trihedron * GetTrihedron ()
 Get trihedron control. More...
bool IsTrihedronDisplayed ()
 Is trihedron displayed. More...
void OnViewTrihedron ()
 Toggle trihedron visibility. More...
void SetTrihedronVisibility (const bool)
 Set Toggle trihedron visibility. More...
void OnAdjustTrihedron ()
 Adjust size of the trihedron to the bounding box of the scene. More...
SVTK_CubeAxesActor2D * GetCubeAxes ()
 Get graduated rules control. More...
bool IsCubeAxesDisplayed ()
 Is graduated rules displayed. More...
void OnViewCubeAxes ()
 Toggle graduated rules visibility. More...
void OnAdjustCubeAxes ()
 Adjust size of the graduated rules to the bounding box of the scene. More...
void OnFitAll ()
 Fit all presentation in the scene into the window. More...
void onFitSelection ()
 Fit all selected presentation in the scene. More...
void OnFitIObjects (const SALOME_ListIO &objects)
 Fit given presentations in the scene. More...
void OnResetView ()
 Set camera into predefined state. More...
void OnResetClippingRange ()
 Reset camera clipping range to adjust the range to the bounding box of the scene. More...
void OnFrontView ()
 To reset direction of the camera to front view. More...
void OnBackView ()
 To reset direction of the camera to back view. More...
void OnTopView ()
 To reset direction of the camera to top view. More...
void OnBottomView ()
 To reset direction of the camera to bottom view. More...
void OnRightView ()
 To reset direction of the camera to right view. More...
void OnLeftView ()
 To reset direction of the camera to left view. More...
void onClockWiseView ()
 To rotate view 90 degrees clockwise. More...
void onAntiClockWiseView ()
 To rotate view 90 degrees counterclockwise. More...
 SVTK_Renderer ()
 ~SVTK_Renderer ()
virtual bool OnAdjustActors ()
static void ProcessEvents (vtkObject *object, unsigned long event, void *clientdata, void *calldata)
double myPriority
vtkSmartPointer< vtkCallbackCommand > myEventCallbackCommand
vtkSmartPointer< vtkRenderer > myDevice
vtkRenderWindowInteractor * myInteractor
vtkSmartPointer< SVTK_Selector > mySelector
vtkSmartPointer< VTKViewer_Transform > myTransform
vtkSmartPointer< vtkPointPicker > myPointPicker
vtkSmartPointer< vtkCellPicker > myCellPicker
vtkSmartPointer< SVTK_AreaPicker > myPointAreaPicker
vtkSmartPointer< SVTK_AreaPicker > myCellAreaPicker
vtkSmartPointer< vtkProperty > myPreHighlightProperty
vtkSmartPointer< vtkProperty > myHighlightProperty
vtkSmartPointer< SVTK_CubeAxesActor2D > myCubeAxes
vtkSmartPointer< VTKViewer_Trihedron > myTrihedron
double myTrihedronSize
bool myIsTrihedronRelative
double myBndBox [6]
The class is a container for #vtkRenderer instance. Main goal of the class is to apply common behaviour to all SALOME_Actor, like selection and preselection colors. Also, the class is responsible for management of internal actors like trihedron an so on.
◆ SVTK_Renderer()
SVTK_Renderer::SVTK_Renderer ( )
◆ ~SVTK_Renderer()
SVTK_Renderer::~SVTK_Renderer ( )
◆ AddActor()
void SVTK_Renderer::AddActor ( VTKViewer_Actor *  theActor,
bool  theIsAdjustActors = true
References AdjustActors(), GetDevice(), GetTransform(), myCellAreaPicker, myCellPicker, myHighlightProperty, myInteractor, myPointAreaPicker, myPointPicker, myPreHighlightProperty, and mySelector.
◆ AdjustActors()
void SVTK_Renderer::AdjustActors ( )
Adjusts size of actors
References GetDevice(), OnAdjustActors(), and ResetCameraClippingRange().
◆ GetCubeAxes()
SVTK_CubeAxesActor2D * SVTK_Renderer::GetCubeAxes ( )
References myCubeAxes.
◆ GetDevice()
vtkRenderer * SVTK_Renderer::GetDevice ( )
Get its device.
renderer's device
References myDevice.
◆ GetScale()
void SVTK_Renderer::GetScale ( double  theScale[3])
References myTransform, and theScale.
◆ GetTransform()
VTKViewer_Transform * SVTK_Renderer::GetTransform ( )
References myTransform.
◆ GetTrihedron()
VTKViewer_Trihedron * SVTK_Renderer::GetTrihedron ( )
trihedron control
References myTrihedron.
◆ GetTrihedronSize()
double SVTK_Renderer::GetTrihedronSize ( ) const
References myTrihedronSize.
◆ Initialize()
void SVTK_Renderer::Initialize ( vtkRenderWindowInteractor *  theInteractor,
SVTK_Selector *  theSelector
Initialize renderer
References myInteractor, mySelector, and SetSelectionTolerance().
◆ IsCubeAxesDisplayed()
bool SVTK_Renderer::IsCubeAxesDisplayed ( )
true if graduated rules displayed
◆ IsTrihedronDisplayed()
bool SVTK_Renderer::IsTrihedronDisplayed ( )
true if trihedron is displayed
References VTKViewer_Trihedron::eOn, and myTrihedron.
◆ IsTrihedronRelative()
bool SVTK_Renderer::IsTrihedronRelative ( ) const
true if the size of the trihedron is relative
References myIsTrihedronRelative.
◆ OnAdjustActors()
◆ OnAdjustCubeAxes()
void SVTK_Renderer::OnAdjustCubeAxes ( )
References AdjustActors().
◆ OnAdjustTrihedron()
void SVTK_Renderer::OnAdjustTrihedron ( )
◆ onAntiClockWiseView()
void SVTK_Renderer::onAntiClockWiseView ( )
References GetDevice().
◆ OnBackView()
void SVTK_Renderer::OnBackView ( )
References GetDevice(), and OnFitAll().
◆ OnBottomView()
void SVTK_Renderer::OnBottomView ( )
◆ onClockWiseView()
void SVTK_Renderer::onClockWiseView ( )
◆ OnFitAll()
void SVTK_Renderer::OnFitAll ( )
References VTKViewer_Trihedron::eOnlyLineOn, GetDevice(), IsCubeAxesDisplayed(), IsTrihedronDisplayed(), myCubeAxes, myTrihedron, ResetCamera(), and ResetCameraClippingRange().
◆ OnFitIObjects()
void SVTK_Renderer::OnFitIObjects ( const SALOME_ListIO &  objects)
References ComputeBounds(), VTK::ActorCollectionCopy::GetActors(), GetDevice(), Handle(), and isBoundValid().
◆ onFitSelection()
void SVTK_Renderer::onFitSelection ( )
References ComputeBounds(), VTK::ActorCollectionCopy::GetActors(), GetDevice(), Handle(), isBoundValid(), and mySelector.
◆ OnFrontView()
void SVTK_Renderer::OnFrontView ( )
◆ OnLeftView()
void SVTK_Renderer::OnLeftView ( )
◆ OnResetClippingRange()
void SVTK_Renderer::OnResetClippingRange ( )
References GetDevice(), and ResetCameraClippingRange().
◆ OnResetView()
void SVTK_Renderer::OnResetView ( )
Sets camera into predefined state
References VTKViewer_Trihedron::eOnlyLineOn, GetDevice(), IsCubeAxesDisplayed(), IsTrihedronDisplayed(), myCubeAxes, myTrihedron, and ResetCamera().
◆ OnRightView()
void SVTK_Renderer::OnRightView ( )
◆ OnTopView()
void SVTK_Renderer::OnTopView ( )
◆ OnViewCubeAxes()
void SVTK_Renderer::OnViewCubeAxes ( )
References IsCubeAxesDisplayed(), and myCubeAxes.
◆ OnViewTrihedron()
void SVTK_Renderer::OnViewTrihedron ( )
References IsTrihedronDisplayed(), and myTrihedron.
◆ ProcessEvents()
void SVTK_Renderer::ProcessEvents ( vtkObject *  object,
void *  clientdata,
void *  calldata
staticprotected
Main process event method
References OnFitAll(), OnResetClippingRange(), and OnResetView().
◆ RemoveActor()
void SVTK_Renderer::RemoveActor ( VTKViewer_Actor *  theActor,
References AdjustActors(), GetDevice(), myCellPicker, and myPointPicker.
◆ SetPreselectionProp()
void SVTK_Renderer::SetPreselectionProp ( const double &  theRed = 0,
const double &  theGreen = 1,
const double &  theBlue = 1,
const int &  theWidth = 5
References myPreHighlightProperty.
◆ SetScale()
void SVTK_Renderer::SetScale ( double  theScale[3])
References AdjustActors(), VTK::ActorCollectionCopy::GetActors(), GetDevice(), myTransform, and theScale.
◆ SetSelectionProp()
void SVTK_Renderer::SetSelectionProp ( const double &  theRed = 1,
const double &  theBlue = 0,
References myHighlightProperty.
◆ SetSelectionTolerance()
void SVTK_Renderer::SetSelectionTolerance ( const double &  theTolNodes = 0.025,
const double &  theTolCell = 0.001,
const double &  theTolObjects = 0.025
References myCellAreaPicker, myCellPicker, myPointAreaPicker, myPointPicker, and mySelector.
◆ SetTrihedronSize()
void SVTK_Renderer::SetTrihedronSize ( double  theSize,
const bool  theRelative = true
theSize- new size
theRelative- if it is true, then size is mesured in percents from bounding box of the scene, otherwise - in viewer units
References AdjustActors(), myIsTrihedronRelative, and myTrihedronSize.
◆ SetTrihedronVisibility()
void SVTK_Renderer::SetTrihedronVisibility ( const bool  show)
Set trihedron visibility
◆ vtkTypeMacro()
SVTK_Renderer::vtkTypeMacro ( SVTK_Renderer  ,
vtkObject
◆ myBndBox
double SVTK_Renderer::myBndBox[6]
◆ myCellAreaPicker
vtkSmartPointer<SVTK_AreaPicker> SVTK_Renderer::myCellAreaPicker
◆ myCellPicker
vtkSmartPointer<vtkCellPicker> SVTK_Renderer::myCellPicker
◆ myCubeAxes
vtkSmartPointer<SVTK_CubeAxesActor2D> SVTK_Renderer::myCubeAxes
◆ myDevice
vtkSmartPointer<vtkRenderer> SVTK_Renderer::myDevice
◆ myEventCallbackCommand
vtkSmartPointer<vtkCallbackCommand> SVTK_Renderer::myEventCallbackCommand
◆ myHighlightProperty
vtkSmartPointer<vtkProperty> SVTK_Renderer::myHighlightProperty
◆ myInteractor
vtkRenderWindowInteractor* SVTK_Renderer::myInteractor
◆ myIsTrihedronRelative
bool SVTK_Renderer::myIsTrihedronRelative
◆ myPointAreaPicker
vtkSmartPointer<SVTK_AreaPicker> SVTK_Renderer::myPointAreaPicker
◆ myPointPicker
vtkSmartPointer<vtkPointPicker> SVTK_Renderer::myPointPicker
◆ myPreHighlightProperty
vtkSmartPointer<vtkProperty> SVTK_Renderer::myPreHighlightProperty
◆ myPriority
double SVTK_Renderer::myPriority
◆ mySelector
vtkSmartPointer<SVTK_Selector> SVTK_Renderer::mySelector
◆ myTransform
vtkSmartPointer<VTKViewer_Transform> SVTK_Renderer::myTransform
◆ myTrihedron
vtkSmartPointer<VTKViewer_Trihedron> SVTK_Renderer::myTrihedron
◆ myTrihedronSize
double SVTK_Renderer::myTrihedronSize
