VTKViewer_Trihedron Class Reference
#include <VTKViewer_Trihedron.h>
Inheritance diagram for VTKViewer_Trihedron:
enum  Axis { X = 0 , Y , Z }
enum  TVisibility { eOff , eOn , eOnlyLineOn }
 vtkTypeMacro (VTKViewer_Trihedron, vtkObject) static VTKViewer_Trihedron *New()
virtual void SetSize (double theSize)
virtual double GetSize ()
virtual void SetVisibility (TVisibility theVis)
virtual void VisibilityOff ()
virtual void VisibilityOn ()
virtual TVisibility GetVisibility ()
virtual void AddToRender (vtkRenderer *theRenderer)
virtual void RemoveFromRender (vtkRenderer *theRenderer)
virtual int GetVisibleActorCount (vtkRenderer *theRenderer)
virtual bool OwnActor (const vtkActor *theActor)
virtual void SetTextColor (Axis axis, double theRed, double theGreen, double theBlue)
 VTKViewer_Trihedron ()
 VTKViewer_Trihedron (const VTKViewer_Trihedron &)
virtual ~VTKViewer_Trihedron ()
vtkActorCollection * myPresent
VTKViewer_Axis * myAxis [3]
double mySize
This class provide support trihedron object in vtk viewer.
◆ Axis
X
Y
Z
◆ TVisibility
eOff
eOn
eOnlyLineOn
◆ VTKViewer_Trihedron() [1/2]
VTKViewer_Trihedron::VTKViewer_Trihedron ( )
Initialize fields by default values.
◆ VTKViewer_Trihedron() [2/2]
VTKViewer_Trihedron::VTKViewer_Trihedron ( const VTKViewer_Trihedron &  )
Const copy constructor.
◆ ~VTKViewer_Trihedron()
VTKViewer_Trihedron::~VTKViewer_Trihedron ( )
Destructor. Remove all fileds.
Destructor
References myAxis, and myPresent.
◆ AddToRender()
void VTKViewer_Trihedron::AddToRender ( vtkRenderer *  theRenderer)
Add to render all Axis
theRenderer- vtkRenderer pointer
References myAxis, and VTKViewer_Axis::SetCamera().
◆ GetSize()
virtual double VTKViewer_Trihedron::GetSize ( )
Get size of trihedron.
mySize- double value
◆ GetVisibility()
VTKViewer_Trihedron::TVisibility VTKViewer_Trihedron::GetVisibility ( )
Gets visibility of myAxis[0] actor.
visibility of first axis
References VTKViewer_Axis::GetVisibility(), and myAxis.
◆ GetVisibleActorCount()
int VTKViewer_Trihedron::GetVisibleActorCount ( vtkRenderer *  theRenderer)
Return count of visible actors.
Reimplemented in SVTK_Trihedron.
References VTK::ActorCollectionCopy::GetActors(), and OwnActor().
◆ OwnActor()
bool VTKViewer_Trihedron::OwnActor ( const vtkActor *  theActor)
Check if actor belongs to the trihedron object
theActor- vtkActor pointer
Returntrue if the actor belongs to the trihedron object
Check if actor belongs to the axis object
Returntrue if the actor belongs to the axis object
References myAxis, myPresent, and OwnActor().
◆ RemoveFromRender()
void VTKViewer_Trihedron::RemoveFromRender ( vtkRenderer *  theRenderer)
Remove all actors from theRenderer which are in myPresent.
References myAxis, myPresent, and RemoveFromRender().
◆ SetSize()
void VTKViewer_Trihedron::SetSize ( double  theSize)
Sets size of trihedron.
theSize- double value
Set size of axes
References myAxis, mySize, and SetSize().
◆ SetTextColor()
void VTKViewer_Trihedron::SetTextColor ( Axis  axis,
double  theRed,
double  theGreen,
double  theBlue
Sets a color to a text for the given axis
axis- axis to change a text color
theRed- red color component
theGreen- green color component
theBlue- blue color component
References myAxis, and VTKViewer_Axis::SetTextColor().
◆ SetVisibility()
void VTKViewer_Trihedron::SetVisibility ( TVisibility  theVis)
Sets visibility for all Axis to theVis
Set visibility of axes
References myAxis, and SetVisibility().
◆ VisibilityOff()
virtual void VTKViewer_Trihedron::VisibilityOff ( )
OFF visibility for all Axis.
◆ VisibilityOn()
virtual void VTKViewer_Trihedron::VisibilityOn ( )
ON visibility for all Axis.
◆ vtkTypeMacro()
VTKViewer_Trihedron::vtkTypeMacro ( VTKViewer_Trihedron  ,
vtkObject
vtk type macros.
Create new instance of VTKViewer_Trihedron.
◆ myAxis
VTKViewer_Axis* VTKViewer_Trihedron::myAxis[3]
  • myAxis[0] - X Axis actor
  • myAxis[1] - Y Axis actor
  • myAxis[2] - Z Axis actor
◆ myPresent
vtkActorCollection* VTKViewer_Trihedron::myPresent
Actor collection
◆ mySize
double VTKViewer_Trihedron::mySize
Common size for trihedron, for each axis.
