VTKViewer_Actor Class Reference
#include <VTKViewer_Actor.h>
Inheritance diagram for VTKViewer_Actor:
 vtkTypeMacro (VTKViewer_Actor, vtkLODActor) virtual const char *getName()
 Get its name. More...
virtual void setName (const char *theName)
 Name the VTKViewer_Actor. More...
virtual void SetOpacity (double theOpacity)
 Change opacity. More...
virtual double GetOpacity ()
 Get current opacity. More...
virtual void SetColor (double r, double g, double b)
 Change color. More...
virtual void GetColor (double &r, double &g, double &b)
 Get current color. More...
virtual void SetColor (const double theRGB[3])
virtual void SetMaterial (std::vector< vtkProperty * > theProps)
 Change material. More...
virtual vtkProperty * GetFrontMaterial ()
 Get current front material. More...
virtual vtkProperty * GetBackMaterial ()
 Get current back material. More...
virtual vtkIdType GetNodeObjId (vtkIdType theVtkID)
 Maps VTK index of a node to corresponding object index. More...
virtual double * GetNodeCoord (vtkIdType theObjID)
 Get coordinates of a node for given object index. More...
virtual vtkIdType GetNodeVtkId (vtkIdType theObjID)
 Maps object index of a node to corresponding VTK index. More...
virtual vtkIdType GetElemObjId (vtkIdType theVtkID)
 Maps VTK index of a cell to corresponding object index. More...
virtual vtkCell * GetElemCell (vtkIdType theObjID)
 Get corresponding #vtkCell for given object index. More...
virtual int GetObjDimension (const vtkIdType theObjId)
 Get dimension of corresponding mesh element. More...
virtual void SetMapper (vtkMapper *theMapper)
 To insert some additional filters and then sets the given #vtkMapper. More...
virtual vtkDataSet * GetInput ()
 Allows to get initial #vtkDataSet. More...
virtual void SetTransform (VTKViewer_Transform *theTransform)
 Apply view transformation. More...
virtual vtkMTimeType GetMTime ()
 To calculatate last modified time. More...
virtual void SetRepresentation (int theMode)
 Set representation (VTK_SURFACE, VTK_POINTS, VTK_WIREFRAME and so on) More...
virtual int GetRepresentation ()
 Get current representation mode. More...
virtual int getDisplayMode ()
 Get current display mode (obsolete) More...
virtual void setDisplayMode (int theMode)
 Set display mode (obsolete) More...
void SetInfinitive (bool theIsInfinite)
 Set infinive flag. More...
virtual bool IsInfinitive ()
 Get infinive flag. More...
virtual double * GetBounds ()
 To calcualte current bounding box. More...
void GetBounds (double bounds[6])
virtual bool IsSetCamera () const
virtual bool IsResizable () const
virtual void SetSize (const double)
virtual void SetCamera (vtkCamera *)
void SetResolveCoincidentTopology (bool theIsResolve)
 Set ResolveCoincidentTopology flag. More...
void SetPolygonOffsetParameters (double factor, double units)
 Set ResolveCoincidentTopology parameters. More...
void GetPolygonOffsetParameters (double &factor, double &units)
 Get current ResolveCoincidentTopology parameters. More...
virtual void Render (vtkRenderer *, vtkMapper *)
virtual double GetShrinkFactor ()
 Get current shrink factor. More...
virtual bool IsShrunkable ()
 Is the actor is shrunkable. More...
virtual bool IsShrunk ()
 Is the actor is shrunk. More...
virtual void SetShrink ()
 Insert shrink filter into pipeline. More...
virtual void UnShrink ()
 Remove shrink filter from pipeline. More...
virtual void AddToRender (vtkRenderer *theRendere)
 To publish the actor an all its internal devices. More...
virtual void RemoveFromRender (vtkRenderer *theRendere)
 To remove the actor an all its internal devices. More...
virtual void GetChildActors (vtkActorCollection *)
 Used to obtain all dependent actors. More...
virtual void EnableSelection (bool)
 Is notified on enabling/disabling selection. More...
virtual bool hasHighlight ()
 Ask, if the descendant of the VTKViewer_Actor will implement its own highlight or not. More...
virtual bool isHighlighted ()
 Ask, if the VTKViewer_Actor is already highlighted. More...
virtual bool isPreselected ()
 Ask, if the VTKViewer_Actor is already preselected. More...
virtual void SetPreSelected (bool thePreselect=false)
 Set preselection mode. More...
virtual void highlight (bool theHighlight)
 Just to update visibility of the highlight devices. More...
void SetPreviewProperty (vtkProperty *theProperty)
virtual void SetQuadraticArcMode (bool theFlag)
 Setting for displaying quadratic elements. More...
virtual bool GetQuadraticArcMode () const
virtual void SetQuadraticArcAngle (double theMaxAngle)
virtual double GetQuadraticArcAngle () const
virtual vtkDataSet * GetHighlightedDataSet ()
 Return pointer to the dataset, which used to calculation of the bounding box of the actor. More...
static VTKViewer_Actor * New ()
static void GetDefaultPolygonOffsetParameters (double &factor, double &units)
 Get default ResolveCoincidentTopology parameters. More...
void InitPipeLine (vtkMapper *theMapper)
 VTKViewer_Actor ()
 ~VTKViewer_Actor ()
bool myIsResolveCoincidentTopology
double myPolygonOffsetFactor
double myPolygonOffsetUnits
std::string myName
double myOpacity
int myDisplayMode
bool myIsInfinite
bool myStoreMapping
VTKViewer_GeometryFilter * myGeomFilter
VTKViewer_TransformFilter * myTransformFilter
std::vector< vtkPassThrough * > myPassFilter
int myRepresentation
vtkProperty * myProperty
vtkProperty * PreviewProperty
bool myIsPreselected
bool myIsHighlighted
◆ VTKViewer_Actor()
VTKViewer_Actor::VTKViewer_Actor ( )
◆ ~VTKViewer_Actor()
VTKViewer_Actor::~VTKViewer_Actor ( )
◆ AddToRender()
void VTKViewer_Actor::AddToRender ( vtkRenderer *  theRenderer)
Reimplemented in SALOME_Actor.
◆ EnableSelection()
virtual void VTKViewer_Actor::EnableSelection ( bool  )
◆ GetBackMaterial()
vtkProperty * VTKViewer_Actor::GetBackMaterial ( )
◆ GetBounds() [1/2]
double * VTKViewer_Actor::GetBounds ( )
◆ GetBounds() [2/2]
void VTKViewer_Actor::GetBounds ( double  theBounds[6])
◆ GetChildActors()
void VTKViewer_Actor::GetChildActors ( vtkActorCollection *  )
◆ GetColor()
void VTKViewer_Actor::GetColor ( double &  r,
double &  g,
double &  b
Get current color.
Get color
◆ GetDefaultPolygonOffsetParameters()
void VTKViewer_Actor::GetDefaultPolygonOffsetParameters ( double &  factor,
double &  units
Get polygon offset parameters
factor,units- Opengl polygon offset parameters
◆ getDisplayMode()
int VTKViewer_Actor::getDisplayMode ( )
display mode
References myDisplayMode.
◆ GetElemCell()
vtkCell * VTKViewer_Actor::GetElemCell ( vtkIdType  theObjID)
References GetInput().
◆ GetElemObjId()
vtkIdType VTKViewer_Actor::GetElemObjId ( vtkIdType  theVtkID)
◆ GetFrontMaterial()
vtkProperty * VTKViewer_Actor::GetFrontMaterial ( )
◆ GetHighlightedDataSet()
vtkDataSet * VTKViewer_Actor::GetHighlightedDataSet ( )
Return pointer to the dataset, which used to calculation of the bounding box of the actor. By default it is the input dataset.
◆ GetInput()
vtkDataSet * VTKViewer_Actor::GetInput ( )
References myPassFilter.
◆ GetMTime()
vtkMTimeType VTKViewer_Actor::GetMTime ( )
References GetInput(), myPassFilter, and myTransformFilter.
◆ GetNodeCoord()
double * VTKViewer_Actor::GetNodeCoord ( vtkIdType  theObjID)
◆ GetNodeObjId()
vtkIdType VTKViewer_Actor::GetNodeObjId ( vtkIdType  theVtkID)
◆ GetNodeVtkId()
vtkIdType VTKViewer_Actor::GetNodeVtkId ( vtkIdType  theObjID)
◆ GetObjDimension()
int VTKViewer_Actor::GetObjDimension ( const vtkIdType  theObjId)
object dimension. Virtual method should be redifined by derived classes
References GetElemCell().
◆ GetOpacity()
double VTKViewer_Actor::GetOpacity ( )
References myOpacity.
◆ GetPolygonOffsetParameters()
void VTKViewer_Actor::GetPolygonOffsetParameters ( double &  factor,
double &  units
References myPolygonOffsetFactor, and myPolygonOffsetUnits.
◆ GetQuadraticArcAngle()
double VTKViewer_Actor::GetQuadraticArcAngle ( ) const
Return Max angle of the representation 2D quadratic element as arked polygon
References VTKViewer_GeometryFilter::GetQuadraticArcAngle(), and myGeomFilter.
◆ GetQuadraticArcMode()
bool VTKViewer_Actor::GetQuadraticArcMode ( ) const
Return true if 2D quadratic element displayed as arked polygon
References VTKViewer_GeometryFilter::GetQuadraticArcMode(), and myGeomFilter.
◆ GetRepresentation()
int VTKViewer_Actor::GetRepresentation ( )
References myRepresentation.
◆ GetShrinkFactor()
double VTKViewer_Actor::GetShrinkFactor ( )
shrink factor
◆ hasHighlight()
bool VTKViewer_Actor::hasHighlight ( )
true if the descendant of the VTKViewer_Actor will implement its own highlight or not
◆ highlight()
void VTKViewer_Actor::highlight ( bool  theIsHighlight)
References myIsHighlighted.
◆ InitPipeLine()
void VTKViewer_Actor::InitPipeLine ( vtkMapper *  theMapper)
◆ isHighlighted()
bool VTKViewer_Actor::isHighlighted ( )
true if the VTKViewer_Actor is already highlighted
◆ IsInfinitive()
bool VTKViewer_Actor::IsInfinitive ( )
Get infinive flag.
infinive flag
References GetBounds(), and myIsInfinite.
◆ isPreselected()
bool VTKViewer_Actor::isPreselected ( )
true if the VTKViewer_Actor is already preselected
References myIsPreselected.
◆ IsResizable()
bool VTKViewer_Actor::IsResizable ( ) const
◆ IsSetCamera()
bool VTKViewer_Actor::IsSetCamera ( ) const
◆ IsShrunk()
bool VTKViewer_Actor::IsShrunk ( )
true if the actor is shrunk
◆ IsShrunkable()
bool VTKViewer_Actor::IsShrunkable ( )
true if the actor is shrunkable
◆ New()
static VTKViewer_Actor * VTKViewer_Actor::New ( )
◆ RemoveFromRender()
void VTKViewer_Actor::RemoveFromRender ( vtkRenderer *  theRenderer)
◆ Render()
void VTKViewer_Actor::Render ( vtkRenderer *  ren,
vtkMapper *  m
◆ SetCamera()
void VTKViewer_Actor::SetCamera ( vtkCamera *  )
◆ SetColor() [1/2]
void VTKViewer_Actor::SetColor ( const double  theRGB[3])
Change color.
Change color
References SetColor().
◆ SetColor() [2/2]
void VTKViewer_Actor::SetColor ( double  r,
double  g,
double  b
Change color.
Change color
◆ setDisplayMode()
void VTKViewer_Actor::setDisplayMode ( int  theMode)
Change display mode
References GetRepresentation(), myDisplayMode, and SetRepresentation().
◆ SetInfinitive()
void VTKViewer_Actor::SetInfinitive ( bool  theIsInfinite)
Set infinive flag.
Infinitive means actor without size (point for example), which is not taken into account in calculation of boundaries of the scene
References myIsInfinite.
◆ SetMapper()
void VTKViewer_Actor::SetMapper ( vtkMapper *  theMapper)
References InitPipeLine().
◆ SetMaterial()
void VTKViewer_Actor::SetMaterial ( std::vector< vtkProperty * >  theProps)
Change material.
Change material
◆ setName()
void VTKViewer_Actor::setName ( const char *  theName)
Sets name
theName- new name
References myName.
◆ SetOpacity()
void VTKViewer_Actor::SetOpacity ( double  theOpacity)
Change opacity.
◆ SetPolygonOffsetParameters()
void VTKViewer_Actor::SetPolygonOffsetParameters ( double  factor,
double  units
Set polygon offset parameters
◆ SetPreSelected()
void VTKViewer_Actor::SetPreSelected ( bool  thePreselect = false)
◆ SetPreviewProperty()
void VTKViewer_Actor::SetPreviewProperty ( vtkProperty *  theProperty)
◆ SetQuadraticArcAngle()
void VTKViewer_Actor::SetQuadraticArcAngle ( double  theMaxAngle)
Set Max angle for representation 2D quadratic element as arked polygon
References myGeomFilter, and VTKViewer_GeometryFilter::SetQuadraticArcAngle().
◆ SetQuadraticArcMode()
void VTKViewer_Actor::SetQuadraticArcMode ( bool  theFlag)
On/Off representation 2D quadratic element as arked polygon
References myGeomFilter, and VTKViewer_GeometryFilter::SetQuadraticArcMode().
◆ SetRepresentation()
void VTKViewer_Actor::SetRepresentation ( int  theMode)
Set representation (VTK_SURFACE, VTK_POINTS, VTK_WIREFRAME and so on) param theMode - new mode
References VTKViewer::Representation::Insideframe, myGeomFilter, myProperty, myRepresentation, VTKViewer::Representation::Points, VTKViewer_GeometryFilter::SetWireframeMode(), VTKViewer::Representation::Surface, VTKViewer::Representation::SurfaceWithEdges, VTKViewer_POINT_SIZE, and VTKViewer::Representation::Wireframe.
◆ SetResolveCoincidentTopology()
void VTKViewer_Actor::SetResolveCoincidentTopology ( bool  theIsResolve)
theIsResolve- new flag value
References myIsResolveCoincidentTopology.
◆ SetShrink()
void VTKViewer_Actor::SetShrink ( )
◆ SetSize()
void VTKViewer_Actor::SetSize ( const double  )
◆ SetTransform()
void VTKViewer_Actor::SetTransform ( VTKViewer_Transform *  theTransform)
theTransform- view transformation
References myTransformFilter.
◆ UnShrink()
void VTKViewer_Actor::UnShrink ( )
◆ vtkTypeMacro()
VTKViewer_Actor::vtkTypeMacro ( VTKViewer_Actor  ,
vtkLODActor
Get its name.
◆ myDisplayMode
int VTKViewer_Actor::myDisplayMode
◆ myGeomFilter
VTKViewer_GeometryFilter* VTKViewer_Actor::myGeomFilter
◆ myIsHighlighted
bool VTKViewer_Actor::myIsHighlighted
◆ myIsInfinite
bool VTKViewer_Actor::myIsInfinite
◆ myIsPreselected
bool VTKViewer_Actor::myIsPreselected
◆ myIsResolveCoincidentTopology
bool VTKViewer_Actor::myIsResolveCoincidentTopology
◆ myName
std::string VTKViewer_Actor::myName
◆ myOpacity
double VTKViewer_Actor::myOpacity
◆ myPassFilter
std::vector<vtkPassThrough*> VTKViewer_Actor::myPassFilter
◆ myPolygonOffsetFactor
double VTKViewer_Actor::myPolygonOffsetFactor
◆ myPolygonOffsetUnits
double VTKViewer_Actor::myPolygonOffsetUnits
◆ myProperty
vtkProperty* VTKViewer_Actor::myProperty
◆ myRepresentation
int VTKViewer_Actor::myRepresentation
◆ myStoreMapping
bool VTKViewer_Actor::myStoreMapping
◆ myTransformFilter
VTKViewer_TransformFilter* VTKViewer_Actor::myTransformFilter
◆ PreviewProperty
vtkProperty* VTKViewer_Actor::PreviewProperty
