VTKViewer_GeometryFilter Class Reference
This class used same as vtkGeometryFilter. See documentation on VTK for more information. More...
#include <VTKViewer_GeometryFilter.h>
Inheritance diagram for VTKViewer_GeometryFilter:
typedef std::vector< vtkIdType > TVectorId
typedef std::vector< TVectorId > TMapOfVectorId
int GetInside ()
 Return value of myShowInside. More...
int GetAppendCoincident3D () const
 Return value of myAppendCoincident3D. More...
void SetAppendCoincident3D (int theFlag)
 Sets myAppendCoincident3D flag. If this flag is true, filter append to the result data set coincident 3D elements. More...
void SetWireframeMode (int theIsWireframeMode)
 Sets myIsWireframeMode flag. myIsWireframeMode is changed, call this->Modified(). More...
int GetWireframeMode ()
 Return value of myIsWireframeMode. More...
void SetStoreMapping (int theStoreMapping)
 Sets myStoreMapping flag and call this->Modified() More...
int GetStoreMapping ()
 Return value of myStoreMapping. More...
virtual vtkIdType GetNodeObjId (vtkIdType theVtkID)
 Return input value theVtkID. More...
virtual vtkIdType GetElemObjId (vtkIdType theVtkID)
 Return object ID by VTK ID cell. More...
virtual void SetQuadraticArcMode (bool theFlag)
virtual bool GetQuadraticArcMode () const
virtual void SetQuadraticArcAngle (double theMaxAngle)
virtual double GetQuadraticArcAngle () const
static VTKViewer_GeometryFilter * New ()
static void InsertId (const vtkIdType theCellId, const vtkIdType theCellType, TVectorId &, TMapOfVectorId &theDimension2VTK2ObjIds)
 VTKViewer_GeometryFilter ()
 Constructor which sets myShowInside = 0 and myStoreMapping = 0. More...
 ~VTKViewer_GeometryFilter ()
int RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
int UnstructuredGridExecute (vtkDataSet *, vtkPolyData *, vtkInformation *)
 Filter calculation method for data object type is VTK_UNSTRUCTURED_GRID. More...
void BuildArcedPolygon (vtkIdType cellId, vtkUnstructuredGrid *input, vtkPolyData *output, TMapOfVectorId &theDimension2VTK2ObjIds, bool triangulate=false)
void FillVTK2ObjIds (vtkPolyData *output)
 fill myVTK2ObjIds to get the correspondence between vtk ids (displayed edges and faces computed in vtkGeometryFilter::UnstructuredGridExecute) and original cell ids (mesh cells) More...
bool delegateToVtk = false
TVectorId myVTK2ObjIds
int myShowInside
int myStoreMapping
int myIsWireframeMode
int myAppendCoincident3D
double myMaxArcAngle
bool myIsBuildArc
◆ TMapOfVectorId
◆ TVectorId
typedef std::vector<vtkIdType> VTKViewer_GeometryFilter::TVectorId
◆ VTKViewer_GeometryFilter()
VTKViewer_GeometryFilter::VTKViewer_GeometryFilter ( )
◆ ~VTKViewer_GeometryFilter()
VTKViewer_GeometryFilter::~VTKViewer_GeometryFilter ( )
◆ BuildArcedPolygon()
void VTKViewer_GeometryFilter::BuildArcedPolygon ( vtkIdType  cellId,
vtkUnstructuredGrid *  input,
vtkPolyData *  output,
TMapOfVectorId &  theDimension2VTK2ObjIds,
bool  triangulate = false
◆ FillVTK2ObjIds()
void VTKViewer_GeometryFilter::FillVTK2ObjIds ( vtkPolyData *  output)
References myVTK2ObjIds.
◆ GetAppendCoincident3D()
int VTKViewer_GeometryFilter::GetAppendCoincident3D ( ) const
References myAppendCoincident3D.
◆ GetElemObjId()
vtkIdType VTKViewer_GeometryFilter::GetElemObjId ( vtkIdType  theVtkID)
myVTK2ObjIds[theVtkID]
◆ GetInside()
int VTKViewer_GeometryFilter::GetInside ( )
myShowInside
References myShowInside.
◆ GetNodeObjId()
vtkIdType VTKViewer_GeometryFilter::GetNodeObjId ( vtkIdType  theVtkID)
theVtkID
◆ GetQuadraticArcAngle()
double VTKViewer_GeometryFilter::GetQuadraticArcAngle ( ) const
References myMaxArcAngle.
◆ GetQuadraticArcMode()
bool VTKViewer_GeometryFilter::GetQuadraticArcMode ( ) const
References myIsBuildArc.
◆ GetStoreMapping()
int VTKViewer_GeometryFilter::GetStoreMapping ( )
myStoreMapping
References myStoreMapping.
◆ GetWireframeMode()
int VTKViewer_GeometryFilter::GetWireframeMode ( )
myIsWireframeMode
References myIsWireframeMode.
◆ InsertId()
void VTKViewer_GeometryFilter::InsertId ( const vtkIdType  theCellId,
TVectorId &  ,
◆ New()
static VTKViewer_GeometryFilter * VTKViewer_GeometryFilter::New ( )
◆ RequestData()
int VTKViewer_GeometryFilter::RequestData ( vtkInformation *  request,
vtkInformationVector **  inputVector,
vtkInformationVector *  outputVector
overrideprotected
◆ SetAppendCoincident3D()
void VTKViewer_GeometryFilter::SetAppendCoincident3D ( int  theFlag)
◆ SetQuadraticArcAngle()
void VTKViewer_GeometryFilter::SetQuadraticArcAngle ( double  theMaxAngle)
◆ SetQuadraticArcMode()
void VTKViewer_GeometryFilter::SetQuadraticArcMode ( bool  theFlag)
◆ SetStoreMapping()
void VTKViewer_GeometryFilter::SetStoreMapping ( int  theStoreMapping)
theStoreMapping- used for changing value of myStoreMapping variable.
◆ SetWireframeMode()
void VTKViewer_GeometryFilter::SetWireframeMode ( int  theIsWireframeMode)
theIsWireframeMode- used for changing value of myIsWireframeMode variable.
◆ UnstructuredGridExecute()
void VTKViewer_GeometryFilter::UnstructuredGridExecute ( vtkDataSet *  dataSetInput,
vtkInformation *
◆ delegateToVtk
bool VTKViewer_GeometryFilter::delegateToVtk = false
◆ myAppendCoincident3D
int VTKViewer_GeometryFilter::myAppendCoincident3D
◆ myIsBuildArc
bool VTKViewer_GeometryFilter::myIsBuildArc
◆ myIsWireframeMode
int VTKViewer_GeometryFilter::myIsWireframeMode
◆ myMaxArcAngle
double VTKViewer_GeometryFilter::myMaxArcAngle
◆ myShowInside
int VTKViewer_GeometryFilter::myShowInside
◆ myStoreMapping
int VTKViewer_GeometryFilter::myStoreMapping
◆ myVTK2ObjIds
TVectorId VTKViewer_GeometryFilter::myVTK2ObjIds
