SalomeApp_DoubleSpinBox Class Reference
#include <SalomeApp_DoubleSpinBox.h>
Inheritance diagram for SalomeApp_DoubleSpinBox:
Signals
void textChanged (const QString &)
 SalomeApp_DoubleSpinBox (QWidget *=0)
 SalomeApp_DoubleSpinBox (double, double, double=1, QWidget *=0)
 SalomeApp_DoubleSpinBox (double, double, double, int, int, QWidget *=0, bool=true, bool=true)
virtual ~SalomeApp_DoubleSpinBox ()
virtual void stepBy (int)
 Perform steps increment/decrement steps. More...
virtual double valueFromText (const QString &) const
 Interpret text entered by the user as a value. More...
virtual QString textFromValue (double) const
 This function is used by the spin box whenever it needs to display the given value. More...
virtual QValidator::State validate (QString &, int &) const
 This function is used to determine whether input is valid. More...
virtual bool isValid (QString &msg, bool=false)
virtual void setDefaultValue (const double)
 This function is used to set a default value for this spinbox. More...
virtual void setRange (double, double)
 This function is used to set minimum and maximum values for this spinbox. More...
virtual void setValue (double)
 This function is used to set a current value for this spinbox. More...
virtual void setText (const QString &)
 This function is used to set a text for this spinbox. More...
void setAcceptNames (const bool)
 Enables or disables variable names in the spin box. By default, variable names are enabled. More...
bool isAcceptNames () const
 Returns true if the spin box accepts variable names. More...
void setShowTipOnValidate (const bool)
 Enables or disables tooltips in case of invalid or intermediate-state input. Tooltips are enabled by default. More...
bool isShowTipOnValidate () const
 Returns true if tooltip should be shown in case of invalid or intermediate-state input. More...
- Public Member Functions inherited from QtxDoubleSpinBox
 QtxDoubleSpinBox (QWidget *=0)
 QtxDoubleSpinBox (double, double, double=1, QWidget *=0)
 QtxDoubleSpinBox (double, double, double, int, int, QWidget *=0)
virtual ~QtxDoubleSpinBox ()
bool isCleared () const
 Check if spin box is in the "cleared" state. More...
virtual void setCleared (const bool)
 Change "cleared" status of the spin box. More...
int getPrecision () const
 Get precision value of the spin box. More...
void setPrecision (const int)
 Set precision of the spin box. More...
Protected Slots
void onEditingFinished ()
 This function is called when editing is finished. More...
void onTextChanged (const QString &)
 This function is called when value is changed. More...
- Protected Slots inherited from QtxDoubleSpinBox
virtual void onTextChanged (const QString &)
 Called when user enters the text in the spin box. More...
State isValid (const QString &, double &) const
double defaultValue () const
 This function return a default acceptable value (commonly, 0.0). More...
virtual bool checkRange (const double) const
 This function is used to check that string value lies within predefined range. More...
SearchState findVariable (const QString &, double &) const
 This function is used to determine whether input is a variable name and to get its value. More...
virtual void showValidationToolTip (const QValidator::State state) const
virtual void keyPressEvent (QKeyEvent *)
 This function is called when the spinbox recieves key press event. More...
virtual void showEvent (QShowEvent *)
 This function is called when the spinbox recieves show event. More...
- Protected Member Functions inherited from QtxDoubleSpinBox
QString removeTrailingZeroes (const QString &) const
 Return source string with removed leading and trailing zeros. More...
Private Types
enum  State { Invalid = 0 , NoVariable , Incompatible , Acceptable }
enum  SearchState { NotFound = 0 , IncorrectType , Found }
void connectSignalsAndSlots ()
 Connect signals and slots. More...
double myDefaultValue
bool myIsRangeSet
double myMinimum
double myMaximum
QString myCorrectValue
QString myTextValue
bool myAcceptNames
bool myShowTip
◆ SearchState
NotFound
IncorrectType
Found
◆ State
Invalid
NoVariable
Incompatible
Acceptable
◆ SalomeApp_DoubleSpinBox() [1/3]
SalomeApp_DoubleSpinBox::SalomeApp_DoubleSpinBox ( QWidget *  parent = 0)
Constructs a spin box with 0.0 as minimum value and 99.99 as maximum value, a step value of 1.0 and a precision of 2 decimal places. The value is initially set to 0.00.
parentparent object
References connectSignalsAndSlots().
◆ SalomeApp_DoubleSpinBox() [2/3]
SalomeApp_DoubleSpinBox::SalomeApp_DoubleSpinBox ( double  min,
double  max,
double  step = 1,
Constructs a spin box with specified minimum, maximum and step value. The precision is set to 2 decimal places. The value is initially set to the minimum value.
minspin box minimum possible value
maxspin box maximum possible value
stepspin box increment/decrement value
parentparent object
◆ SalomeApp_DoubleSpinBox() [3/3]
double  max,
double  step,
int  prec,
int  dec,
QWidget *  parent = 0,
bool  acceptNames = true,
bool  showTip = true
parentparent object
acceptNamesif true, enables variable names in the spin box
showTipif true, makes the widget show a tooltip when invalid text is entered by the user
◆ ~SalomeApp_DoubleSpinBox()
SalomeApp_DoubleSpinBox::~SalomeApp_DoubleSpinBox ( )
◆ checkRange()
bool SalomeApp_DoubleSpinBox::checkRange ( const double  value) const
check status
References myIsRangeSet, myMaximum, and myMinimum.
◆ connectSignalsAndSlots()
void SalomeApp_DoubleSpinBox::connectSignalsAndSlots ( )
References onEditingFinished(), onTextChanged(), and textChanged().
◆ defaultValue()
double SalomeApp_DoubleSpinBox::defaultValue ( ) const
References myDefaultValue, myMaximum, and myMinimum.
◆ findVariable()
SalomeApp_DoubleSpinBox::SearchState SalomeApp_DoubleSpinBox::findVariable ( const QString &  name,
double &  value
status of search operation
References _PTR(), Found, IncorrectType, NotFound, and SUIT_Session::session().
◆ isAcceptNames()
bool SalomeApp_DoubleSpinBox::isAcceptNames ( ) const
References myAcceptNames.
◆ isShowTipOnValidate()
bool SalomeApp_DoubleSpinBox::isShowTipOnValidate ( ) const
References myShowTip.
◆ isValid() [1/2]
SalomeApp_DoubleSpinBox::State SalomeApp_DoubleSpinBox::isValid ( const QString &  text,
double &  value
validating operation result
References Acceptable, checkRange(), findVariable(), Incompatible, IncorrectType, Invalid, NotFound, and NoVariable.
◆ isValid() [2/2]
bool SalomeApp_DoubleSpinBox::isValid ( QString &  msg,
bool  toCorrect = false
References Acceptable, Incompatible, Invalid, isValid(), myCorrectValue, NoVariable, and setText().
◆ keyPressEvent()
void SalomeApp_DoubleSpinBox::keyPressEvent ( QKeyEvent *  e)
◆ onEditingFinished
void SalomeApp_DoubleSpinBox::onEditingFinished ( )
protectedslot
References myTextValue, and setText().
◆ onTextChanged
void SalomeApp_DoubleSpinBox::onTextChanged ( const QString &  text)
protectedslot
References Acceptable, isValid(), myCorrectValue, and myTextValue.
◆ setAcceptNames()
void SalomeApp_DoubleSpinBox::setAcceptNames ( const bool  flag)
flagIf true, variable names are enabled.
◆ setDefaultValue()
void SalomeApp_DoubleSpinBox::setDefaultValue ( const double  value)
valuedefault value
References myDefaultValue.
◆ setRange()
void SalomeApp_DoubleSpinBox::setRange ( double  min,
double  max
minminimum value
maxmaximum value
◆ setShowTipOnValidate()
void SalomeApp_DoubleSpinBox::setShowTipOnValidate ( const bool  flag)
flagIf true, tooltips are enabled.
◆ setText()
void SalomeApp_DoubleSpinBox::setText ( const QString &  value)
valuecurrent value
◆ setValue()
void SalomeApp_DoubleSpinBox::setValue ( double  value)
valuecurrent value
References myCorrectValue, myTextValue, and QtxDoubleSpinBox::textFromValue().
◆ showEvent()
void SalomeApp_DoubleSpinBox::showEvent ( QShowEvent *  )
◆ showValidationToolTip()
void SalomeApp_DoubleSpinBox::showValidationToolTip ( const QValidator::State  state) const
◆ stepBy()
void SalomeApp_DoubleSpinBox::stepBy ( int  steps)
Re-implemented to handle cases when Notebook variable name is specified by the user as the widget text.
Otherwise, simply calls the base implementation.
stepsnumber of increment/decrement steps
Reimplemented from QtxDoubleSpinBox.
References QtxDoubleSpinBox::stepBy().
◆ textChanged
void SalomeApp_DoubleSpinBox::textChanged ( const QString &  )
signal
◆ textFromValue()
QString SalomeApp_DoubleSpinBox::textFromValue ( double  val) const
valspin box value
text representation of the value
See also
valueFromText()
References QtxDoubleSpinBox::textFromValue().
◆ validate()
QValidator::State SalomeApp_DoubleSpinBox::validate ( QString &  str,
int &  pos
strcurrently entered value
poscursor position in the string
References isAcceptNames(), isShowTipOnValidate(), showValidationToolTip(), and QtxDoubleSpinBox::validate().
◆ valueFromText()
double SalomeApp_DoubleSpinBox::valueFromText ( const QString &  text) const
texttext entered by the user
mapped value
See also
textFromValue()
References Acceptable, defaultValue(), and isValid().
◆ myAcceptNames
bool SalomeApp_DoubleSpinBox::myAcceptNames
◆ myCorrectValue
QString SalomeApp_DoubleSpinBox::myCorrectValue
◆ myDefaultValue
double SalomeApp_DoubleSpinBox::myDefaultValue
◆ myIsRangeSet
bool SalomeApp_DoubleSpinBox::myIsRangeSet
◆ myMaximum
double SalomeApp_DoubleSpinBox::myMaximum
◆ myMinimum
double SalomeApp_DoubleSpinBox::myMinimum
◆ myShowTip
bool SalomeApp_DoubleSpinBox::myShowTip
◆ myTextValue
QString SalomeApp_DoubleSpinBox::myTextValue
