SalomeApp_IntSpinBox Class Reference
#include <SalomeApp_IntSpinBox.h>
Inheritance diagram for SalomeApp_IntSpinBox:
Signals
void textChanged (const QString &)
 SalomeApp_IntSpinBox (QWidget *=0)
 SalomeApp_IntSpinBox (int, int, int=1, QWidget *=0, bool=true, bool=true)
virtual ~SalomeApp_IntSpinBox ()
virtual void stepBy (int)
 Perform steps increment/decrement steps. More...
virtual int valueFromText (const QString &) const
 Interpret text entered by the user as a value. More...
virtual QString textFromValue (int) const
 This function is used by the spin box whenever it needs to display the given value. More...
virtual QValidator::State validate (QString &, int &) const
 This function is used to determine whether input is valid. More...
virtual bool isValid (QString &msg, bool=false)
virtual void setDefaultValue (const int)
 This function is used to set a default value for this spinbox. More...
virtual void setValue (int)
 This function is used to set a current value for this spinbox. More...
virtual void setText (const QString &)
 This function is used to set a text for this spinbox. More...
void setAcceptNames (const bool)
 Enables or disables variable names in the spin box. By default, variable names are enabled. More...
bool isAcceptNames () const
 Returns true if the spin box accepts variable names. More...
void setShowTipOnValidate (const bool)
 Enables or disables tooltips in case of invalid or intermediate-state input. Tooltips are enabled by default. More...
bool isShowTipOnValidate () const
 Returns true if tooltip should be shown in case of invalid or intermediate-state input. More...
- Public Member Functions inherited from QtxIntSpinBox
 QtxIntSpinBox (QWidget *=0)
 QtxIntSpinBox (int, int, int=1, QWidget *=0)
virtual ~QtxIntSpinBox ()
bool isCleared () const
 Check if spin box is in the "cleared" state. More...
virtual void setCleared (const bool)
 Change "cleared" status of the spin box. More...
Protected Slots
void onEditingFinished ()
 This function is called when editing is finished. More...
void onTextChanged (const QString &)
 This function is called when value is changed. More...
- Protected Slots inherited from QtxIntSpinBox
virtual void onTextChanged (const QString &)
 Called when user enters the text in the spin box. More...
State isValid (const QString &, int &) const
int defaultValue () const
 This function return a default acceptable value (commonly, 0). More...
bool checkRange (const int) const
 This function is used to check that string value lies within predefined range. More...
SearchState findVariable (const QString &, int &) const
 This function is used to determine whether input is a variable name and to get its value. More...
virtual void keyPressEvent (QKeyEvent *)
 This function is called when the spinbox recieves key press event. More...
virtual void showEvent (QShowEvent *)
 This function is called when the spinbox recieves show event. More...
 Convert value to the text. More...
Private Types
enum  State { Invalid = 0 , NoVariable , Incompatible , Acceptable }
enum  SearchState { NotFound = 0 , IncorrectType , Found }
void connectSignalsAndSlots ()
 Connect signals and slots. More...
int myDefaultValue
QString myCorrectValue
QString myTextValue
bool myAcceptNames
bool myShowTip
◆ SearchState
NotFound
IncorrectType
Found
◆ State
Invalid
NoVariable
Incompatible
Acceptable
◆ SalomeApp_IntSpinBox() [1/2]
SalomeApp_IntSpinBox::SalomeApp_IntSpinBox ( QWidget *  parent = 0)
Constructs a spin box with 0 as minimum value and 99 as maximum value, a step value of 1. The value is initially set to 0.
parentparent object
References connectSignalsAndSlots().
◆ SalomeApp_IntSpinBox() [2/2]
SalomeApp_IntSpinBox::SalomeApp_IntSpinBox ( int  min,
int  max,
int  step = 1,
QWidget *  parent = 0,
bool  acceptNames = true,
bool  showTip = true
Constructs a spin box with specified minimum, maximum and step value. The value is initially set to the minimum value.
minspin box minimum possible value
maxspin box maximum possible value
stepspin box increment/decrement value
parentparent object
acceptNamesif true, enables variable names in the spin box
showTipif true, makes the widget show a tooltip when invalid text is entered by the user
◆ ~SalomeApp_IntSpinBox()
SalomeApp_IntSpinBox::~SalomeApp_IntSpinBox ( )
◆ checkRange()
bool SalomeApp_IntSpinBox::checkRange ( const int  value) const
check status
◆ connectSignalsAndSlots()
void SalomeApp_IntSpinBox::connectSignalsAndSlots ( )
References onEditingFinished(), onTextChanged(), and textChanged().
◆ defaultValue()
int SalomeApp_IntSpinBox::defaultValue ( ) const
References myDefaultValue.
◆ findVariable()
SalomeApp_IntSpinBox::SearchState SalomeApp_IntSpinBox::findVariable ( const QString &  name,
int &  value
status of search operation
References _PTR(), Found, IncorrectType, NotFound, and SUIT_Session::session().
◆ isAcceptNames()
bool SalomeApp_IntSpinBox::isAcceptNames ( ) const
References myAcceptNames.
◆ isShowTipOnValidate()
bool SalomeApp_IntSpinBox::isShowTipOnValidate ( ) const
References myShowTip.
◆ isValid() [1/2]
SalomeApp_IntSpinBox::State SalomeApp_IntSpinBox::isValid ( const QString &  text,
int &  value
validating operation result
References Acceptable, checkRange(), findVariable(), Incompatible, IncorrectType, Invalid, NotFound, and NoVariable.
◆ isValid() [2/2]
bool SalomeApp_IntSpinBox::isValid ( QString &  msg,
bool  toCorrect = false
References Acceptable, Incompatible, Invalid, isValid(), myCorrectValue, NoVariable, and setText().
◆ keyPressEvent()
void SalomeApp_IntSpinBox::keyPressEvent ( QKeyEvent *  e)
◆ onEditingFinished
void SalomeApp_IntSpinBox::onEditingFinished ( )
protectedslot
References myTextValue, and setText().
◆ onTextChanged
void SalomeApp_IntSpinBox::onTextChanged ( const QString &  text)
protectedslot
References Acceptable, isValid(), myCorrectValue, and myTextValue.
◆ setAcceptNames()
void SalomeApp_IntSpinBox::setAcceptNames ( const bool  flag)
flagIf true, variable names are enabled.
◆ setDefaultValue()
void SalomeApp_IntSpinBox::setDefaultValue ( const int  value)
valuedefault value
◆ setShowTipOnValidate()
void SalomeApp_IntSpinBox::setShowTipOnValidate ( const bool  flag)
flagIf true, tooltips are enabled.
◆ setText()
void SalomeApp_IntSpinBox::setText ( const QString &  value)
valuecurrent value
◆ setValue()
void SalomeApp_IntSpinBox::setValue ( int  value)
valuecurrent value
References myCorrectValue, and myTextValue.
◆ showEvent()
void SalomeApp_IntSpinBox::showEvent ( QShowEvent *  )
◆ stepBy()
void SalomeApp_IntSpinBox::stepBy ( int  steps)
Re-implemented to handle cases when Notebook variable name is specified by the user as the widget text.
Otherwise, simply calls the base implementation.
stepsnumber of increment/decrement steps
Reimplemented from QtxIntSpinBox.
References QtxIntSpinBox::stepBy().
◆ textChanged
void SalomeApp_IntSpinBox::textChanged ( const QString &  )
signal
◆ textFromValue()
QString SalomeApp_IntSpinBox::textFromValue ( int  val) const
valspin box value
text representation of the value
See also
valueFromText()
References QtxIntSpinBox::textFromValue().
◆ validate()
QValidator::State SalomeApp_IntSpinBox::validate ( QString &  str,
int &  pos
strcurrently entered value
poscursor position in the string
References isAcceptNames(), isShowTipOnValidate(), and textFromValue().
◆ valueFromText()
int SalomeApp_IntSpinBox::valueFromText ( const QString &  text) const
texttext entered by the user
mapped value
See also
textFromValue()
References Acceptable, defaultValue(), and isValid().
◆ myAcceptNames
bool SalomeApp_IntSpinBox::myAcceptNames
◆ myCorrectValue
QString SalomeApp_IntSpinBox::myCorrectValue
◆ myDefaultValue
int SalomeApp_IntSpinBox::myDefaultValue
◆ myShowTip
bool SalomeApp_IntSpinBox::myShowTip
◆ myTextValue
QString SalomeApp_IntSpinBox::myTextValue
