SalomeApp_ListView Class Reference
#include <SalomeApp_ListView.h>
Inheritance diagram for SalomeApp_ListView:
 SalomeApp_ListView (QWidget *parent)
virtual ~SalomeApp_ListView ()
virtual void updateViewer ()
virtual void updateSelected ()
virtual QString popupClientType () const
virtual void contextMenuPopup (QMenu *)
void enableEditing (bool theFlag)
bool isEnableEditing ()
void accept ()
void clear ()
bool eventFilter (QObject *object, QEvent *event)
QRect tip (QPoint aPos, QString &aText, QRect &dspRect, QFont &dspFnt) const
- Public Member Functions inherited from SUIT_PopupClient
 SUIT_PopupClient ()
virtual ~SUIT_PopupClient ()
bool connectPopupRequest (QObject *reciever, const char *slot)
bool disconnectPopupRequest (QObject *reciever, const char *slot)
virtual QString popupClientType () const =0
Protected Slots
virtual void onSelectionChanged ()
void onEditOk ()
void onEditCancel ()
void onHeaderSizeChange (int, int, int)
void resizeEvent (QResizeEvent *e)
void viewportPaintEvent (QPaintEvent *e)
virtual UpdateType finishEditing (bool ok)
bool isMouseEnabled ()
void enableMouse (bool enable)
- Protected Member Functions inherited from SUIT_PopupClient
void contextMenuRequest (QContextMenuEvent *e)
SalomeApp_EntityEdit * myEdit
SalomeApp_ListViewItem * myEditedItem
bool myEditingEnabled
bool myMouseEnabled
parent class for Data Viewer and Properties Viewer
◆ SalomeApp_ListView()
SalomeApp_ListView::SalomeApp_ListView ( QWidget *  parent)
◆ ~SalomeApp_ListView()
SalomeApp_ListView::~SalomeApp_ListView ( )
Destructor
References myEdit, and myEditedItem.
◆ accept()
void SalomeApp_ListView::accept ( )
Calls finishEditing(true)...
References finishEditing().
◆ clear()
void SalomeApp_ListView::clear ( )
Clears view
◆ contextMenuPopup()
void SalomeApp_ListView::contextMenuPopup ( QMenu *  aPopup)
Fills popup menu with items
Reimplemented from SUIT_PopupClient.
◆ enableEditing()
void SalomeApp_ListView::enableEditing ( bool  theFlag)
Setting editing of items availbale/not available
References myEdit, myEditedItem, and myEditingEnabled.
◆ enableMouse()
void SalomeApp_ListView::enableMouse ( bool  enable)
Enables/disables mouse events (excluding MouseMove)
References myMouseEnabled.
◆ eventFilter()
bool SalomeApp_ListView::eventFilter ( QObject *  object,
QEvent *  event
Event filter
References isMouseEnabled().
◆ finishEditing()
◆ isEnableEditing()
bool SalomeApp_ListView::isEnableEditing ( )
Says if editing is enabled
References myEditingEnabled.
◆ isMouseEnabled()
bool SalomeApp_ListView::isMouseEnabled ( )
true if mouse events are enabled
◆ onEditCancel
void SalomeApp_ListView::onEditCancel ( )
protectedslot
Called when user cancels item editing
◆ onEditOk
void SalomeApp_ListView::onEditOk ( )
protectedslot
Called when user finishes in editing of item
◆ onHeaderSizeChange
void SalomeApp_ListView::onHeaderSizeChange ( int  ,
int  ,
int
protectedslot
Slot, called when columns sizes are changed
◆ onSelectionChanged
void SalomeApp_ListView::onSelectionChanged ( )
protectedvirtualslot
◆ popupClientType()
QString SalomeApp_ListView::popupClientType ( ) const
Returns popup client type
Implements SUIT_PopupClient.
◆ resizeEvent()
void SalomeApp_ListView::resizeEvent ( QResizeEvent *  e)
Called when Data Viewer is resized
◆ tip()
QRect SalomeApp_ListView::tip ( QPoint  aPos,
QString &  aText,
QRect &  dspRect,
QFont &  dspFnt
current tooltip for list view
validrect in success
References SalomeApp_ListViewItem::itemRect(), SalomeApp_ListViewItem::textRect(), SalomeApp_ListViewItem::tipRect(), and SalomeApp_ListViewItem::tipText().
◆ updateSelected()
void SalomeApp_ListView::updateSelected ( )
Updates currently selected item(s)
References SalomeApp_ListViewItem::updateAllLevels().
◆ updateViewer()
void SalomeApp_ListView::updateViewer ( )
Updates all data viewer
◆ viewportPaintEvent()
void SalomeApp_ListView::viewportPaintEvent ( QPaintEvent *  e)
Handler for paint event
References computeEditGeometry(), myEdit, and myEditedItem.
◆ myEdit
SalomeApp_EntityEdit* SalomeApp_ListView::myEdit
◆ myEditedItem
SalomeApp_ListViewItem* SalomeApp_ListView::myEditedItem
◆ myEditingEnabled
bool SalomeApp_ListView::myEditingEnabled
◆ myMouseEnabled
bool SalomeApp_ListView::myMouseEnabled
