SalomeApp_ListViewItem Class Reference
#include <SalomeApp_ListView.h>
Inheritance diagram for SalomeApp_ListViewItem:
 SalomeApp_ListViewItem (SalomeApp_ListView *)
 SalomeApp_ListViewItem (SalomeApp_ListView *, SalomeApp_ListViewItem *)
 SalomeApp_ListViewItem (SalomeApp_ListView *, const QStringList &, const bool=false)
 SalomeApp_ListViewItem (SalomeApp_ListViewItem *, const QStringList &, const bool=false)
 SalomeApp_ListViewItem (SalomeApp_ListView *, SalomeApp_ListViewItem *, const QString &, const bool=false)
 SalomeApp_ListViewItem (SalomeApp_ListViewItem *, SalomeApp_ListViewItem *, const QString &, const bool=false)
 SalomeApp_ListViewItem (SalomeApp_ListView *, SalomeApp_ListViewItem *, const QString &theName, const QString &theValue, const bool=false)
 SalomeApp_ListViewItem (SalomeApp_ListViewItem *, SalomeApp_ListViewItem *, const QString &, const QString &, const bool=false)
 ~SalomeApp_ListViewItem ()
QString fullName ()
void openAllLevels ()
virtual void updateAllLevels ()
bool isEditable () const
void setEditable (bool theEditable)
bool isAccepted () const
void setAccepted (bool theAccepted)
virtual QString getName () const
virtual UpdateType setName (const QString &theName)
virtual QString getValue () const
virtual UpdateType setValue (const QString &theValue)
SalomeApp_EntityEdit * startEditing ()
virtual void fillWidgetWithValues (SalomeApp_EntityEdit *theWidget)
virtual UpdateType finishEditing (SalomeApp_EntityEdit *theWidget)
virtual int getEditingType ()
virtual void setEditingType (const int)
virtual int getEditedColumn ()
virtual int getValueType ()
virtual void setValueType (const int)
virtual int getUserType ()
virtual void setUserType (const int)
virtual int getButtons ()
virtual void setButtons (const int)
QString tipText ()
QRect tipRect ()
QRect textRect (const int column) const
QRect itemRect (const int column) const
void init ()
int depth () const
bool myEditable
bool myAccepted
int myEditingType
int myValueType
int myButtons
int myUserType
◆ SalomeApp_ListViewItem() [1/8]
SalomeApp_ListViewItem::SalomeApp_ListViewItem ( SalomeApp_ListView *  parent)
Constructor
References init().
◆ SalomeApp_ListViewItem() [2/8]
SalomeApp_ListViewItem::SalomeApp_ListViewItem ( SalomeApp_ListView *  parent,
SalomeApp_ListViewItem *  after
Constructor
References init().
◆ SalomeApp_ListViewItem() [3/8]
const QStringList &  theStrings,
const bool  theEditable = false
Constructor
References init(), and setEditable().
◆ SalomeApp_ListViewItem() [4/8]
SalomeApp_ListViewItem::SalomeApp_ListViewItem ( SalomeApp_ListViewItem *  parent,
const QStringList &  theString,
Constructor
◆ SalomeApp_ListViewItem() [5/8]
SalomeApp_ListViewItem *  after,
const QString &  theName,
Constructor
◆ SalomeApp_ListViewItem() [6/8]
Constructor
◆ SalomeApp_ListViewItem() [7/8]
const QString &  theValue,
Constructor
◆ SalomeApp_ListViewItem() [8/8]
Constructor
◆ ~SalomeApp_ListViewItem()
SalomeApp_ListViewItem::~SalomeApp_ListViewItem ( )
Destructor
◆ depth()
int SalomeApp_ListViewItem::depth ( ) const
Returns the depth of this item
◆ fillWidgetWithValues()
void SalomeApp_ListViewItem::fillWidgetWithValues ( SalomeApp_EntityEdit *  theWidget)
Fills widget with initial values (list or single value)
References getEditedColumn(), and SalomeApp_EntityEdit::insertItem().
◆ finishEditing()
UpdateType SalomeApp_ListViewItem::finishEditing ( SalomeApp_EntityEdit *  theWidget)
Finishes editing of entity
References getEditedColumn(), SalomeApp_EntityEdit::getText(), setName(), setValue(), and utCancel.
◆ fullName()
QString SalomeApp_ListViewItem::fullName ( )
full path to the entity from the root
References getName().
◆ getButtons()
int SalomeApp_ListViewItem::getButtons ( )
buttons for editing widget (Apply (V), Cancel (X)) default is both buttons
References myButtons.
◆ getEditedColumn()
int SalomeApp_ListViewItem::getEditedColumn ( )
editedcolumn, default is last column negative value means there are no editable columns
◆ getEditingType()
int SalomeApp_ListViewItem::getEditingType ( )
typeof edit control (default is edit box)
  • 0 - edit box
  • 1 - combo box
  • 2 - editable combo box
References myEditingType.
◆ getName()
QString SalomeApp_ListViewItem::getName ( ) const
text in the first column
◆ getUserType()
int SalomeApp_ListViewItem::getUserType ( )
Sets type of edited value
References myUserType.
◆ getValue()
QString SalomeApp_ListViewItem::getValue ( ) const
text in the second column
◆ getValueType()
int SalomeApp_ListViewItem::getValueType ( )
typeof edited value (string, int, double) default is string
References myValueType.
◆ init()
void SalomeApp_ListViewItem::init ( )
◆ isAccepted()
bool SalomeApp_ListViewItem::isAccepted ( ) const
true if entitiy is accepted after editing
References myAccepted.
◆ isEditable()
bool SalomeApp_ListViewItem::isEditable ( ) const
true if entity is editable
References myEditable.
◆ itemRect()
QRect SalomeApp_ListViewItem::itemRect ( const int  column) const
Calculates rect of item data in viewport coordinates
References depth().
◆ openAllLevels()
void SalomeApp_ListViewItem::openAllLevels ( )
expands all entities beginning from this level
References openAllLevels().
◆ setAccepted()
void SalomeApp_ListViewItem::setAccepted ( bool  theAccepted)
Sets entitiy accepted or not after editing
◆ setButtons()
void SalomeApp_ListViewItem::setButtons ( const int  buttons)
Sets buttons for editing widget (Apply (V), Cancel (X))
◆ setEditable()
void SalomeApp_ListViewItem::setEditable ( bool  theEditable)
Sets editable flag fo the entity
◆ setEditingType()
void SalomeApp_ListViewItem::setEditingType ( const int  type)
typeof edit control (negative value means none)
  • 0 - edit box
  • 1 - combo box
◆ setName()
UpdateType SalomeApp_ListViewItem::setName ( const QString &  theName)
Sets text in the first column
References utCancel, and utNone.
◆ setUserType()
void SalomeApp_ListViewItem::setUserType ( const int  userType)
◆ setValue()
UpdateType SalomeApp_ListViewItem::setValue ( const QString &  theValue)
Sets text in the second column
◆ setValueType()
void SalomeApp_ListViewItem::setValueType ( const int  valueType)
◆ startEditing()
SalomeApp_EntityEdit * SalomeApp_ListViewItem::startEditing ( )
◆ textRect()
QRect SalomeApp_ListViewItem::textRect ( const int  column) const
Calculates rect of item text in viewport coordinates
References depth().
◆ tipRect()
QRect SalomeApp_ListViewItem::tipRect ( )
Calculates rectangle which should contain item's tip
References textRect(), and tipText().
◆ tipText()
QString SalomeApp_ListViewItem::tipText ( )
text for tooltip
References getName(), and getValue().
◆ updateAllLevels()
void SalomeApp_ListViewItem::updateAllLevels ( )
update all entites beginning from this level
References updateAllLevels().
◆ myAccepted
bool SalomeApp_ListViewItem::myAccepted
◆ myButtons
int SalomeApp_ListViewItem::myButtons
◆ myEditable
bool SalomeApp_ListViewItem::myEditable
◆ myEditingType
int SalomeApp_ListViewItem::myEditingType
◆ myUserType
int SalomeApp_ListViewItem::myUserType
◆ myValueType
int SalomeApp_ListViewItem::myValueType
