Style_Salome Class Reference
SALOME style class. More...
#include <Style_Salome.h>
Inheritance diagram for Style_Salome:
virtual ~Style_Salome ()
virtual void polish (QApplication *)
 Initialize the appearance of the application. More...
virtual void polish (QWidget *)
 Initializes the appearance of the given widget. More...
virtual void unpolish (QWidget *)
 Uninitialize the given widget's appearance. More...
virtual void drawComplexControl (ComplexControl, const QStyleOptionComplex *, QPainter *, const QWidget *=0) const
 Draws the given control using the provided painter with the style options specified by opt. More...
virtual void drawControl (ControlElement, const QStyleOption *, QPainter *, const QWidget *) const
 Draws the given element with the provided painter with the style options specified by opt. More...
virtual void drawPrimitive (PrimitiveElement, const QStyleOption *, QPainter *, const QWidget *=0) const
 Draws the given primitive element with the provided painter using the style options specified by opt. More...
virtual int pixelMetric (PixelMetric, const QStyleOption *=0, const QWidget *=0) const
 Returns the value of the given pixel metric. More...
virtual QSize sizeFromContents (ContentsType, const QStyleOption *, const QSize &, const QWidget *=0) const
 Returns the size of the element described by the specified option opt and type ct, based on the provided contentsSize. More...
virtual QPixmap standardPixmap (StandardPixmap, const QStyleOption *, const QWidget *=0) const
 Returns a pixmap for the given standardPixmap. More...
virtual int styleHint (StyleHint, const QStyleOption *=0, const QWidget *=0, QStyleHintReturn *=0) const
 Returns an integer representing the specified style hint for the given widget w described by the provided style option opt. More...
virtual QRect subControlRect (ComplexControl, const QStyleOptionComplex *, SubControl, const QWidget *=0) const
 Get the rectangle containing the specified subcontrol sc of the given complex control cc (with the style specified by option opt). The rectangle is defined in screen coordinates. More...
virtual QRect subElementRect (SubElement, const QStyleOption *, const QWidget *=0) const
 Returns the sub-area for the given element se as described in the provided style option opt. The returned rectangle is defined in screen coordinates. More...
static void initialize (QtxResourceMgr *=0, const QString &=QString())
 Initialize SALOME style. More...
static void apply ()
 Set SALOME style to the application. More...
static void restore ()
 Restore original style to the application. More...
static bool isActive ()
 Check if the SALOME style is currently set to application. More...
static Style_Model * model ()
 Get style model. More...
static void update ()
 Update style from resources. More...
Protected Slots
QIcon standardIconImplementation (StandardPixmap, const QStyleOption *=0, const QWidget *=0) const
 Returns an icon for the given standardIcon. More...
 Style_Salome ()
void updatePaletteColors ()
 Update palette colors from style model. More...
void updateAllWidgets (QApplication *)
 Update all widgets with the current style properties. More...
bool hasHover () const
 Check if any widget effect is currently used. More...
void drawHoverRect (QPainter *, const QRect &, const QColor &, const double, const int, const bool) const
 Draw rectangle for the hovered widget. More...
void drawHandle (QPainter *, const QRect &, bool, bool=true) const
 Draw widget handle. More...
void drawBackground (QPainter *, const QRect &, const QColor &, const bool, const bool=false, const bool=true) const
 Draw background. More...
void drawBorder (QPainter *, const QRect &, bool) const
 Draw border. More...
QString titleText (const QString &, const int, const int, QFont &) const
 Get corrected title text. More...
Static Private Attributes
static Style_Model * myModel = 0
SALOME style class.
To set SALOME style to the application, use static function Style_Salome::apply(). Static function restore() can be used then to restore initial application style.
The usual way to use SALOME style is as following:
Style_Salome::initialize( resourceMgr() ); // initialize SALOME style from resources
if ( needSalomeStyle ) Style_Salome::apply(); // set SALOME style to the application
static void apply()
Definition: Style_Salome.cxx:244
static void initialize(QtxResourceMgr *=0, const QString &=QString())
Definition: Style_Salome.cxx:235
Style_PrefDlg class can be then used to change style properties, select one of the predefined style themes or even create user themes:
Style_PrefDlg dlg( desktop() );
dlg.exec();
SALOME style prefences dialog box class.
Definition: Style_PrefDlg.h:49
◆ Style_Salome()
Style_Salome::Style_Salome ( )
Use Style_Salome::apply() static function to set SALOME style to the application.
◆ ~Style_Salome()
Style_Salome::~Style_Salome ( )
◆ apply()
void Style_Salome::apply ( )
See also
initialize(), restore()
References isActive(), model(), Style_Salome(), Style_Model::update(), and update().
◆ drawBackground()
void Style_Salome::drawBackground ( QPainter *  p,
const QRect &  r,
const QColor &  bgCol,
const bool  fill,
const bool  grad = false,
const bool  horiz = true
Draw background.
ppainter
rrectangle
bgColbackground color
fill'fill rectangle' flag
grad'draw gradient' flag
horix'draw horizontal item' flag (usefull for gradient background)
References BUT_PERCENT_ON, Style_Model::color(), Style_Model::Horizontal, Style_Model::Inclined, Style_Model::Lines, and model().
◆ drawBorder()
void Style_Salome::drawBorder ( QPainter *  p,
const QRect &  r,
bool  horiz
Draw border.
ppainter
rrectangle
horiz'draw horizontal item' flag
References Style_Model::color(), model(), Style_Model::TabBorderBottom, and Style_Model::TabBorderTop.
◆ drawComplexControl()
◆ drawControl()
void Style_Salome::drawControl ( ControlElement  ce,
const QStyleOption *  opt,
QPainter *  p,
const QWidget *  w
◆ drawHandle()
void Style_Salome::drawHandle ( QPainter *  p,
const QRect &  r,
bool  horiz,
bool  isRect = true
Draw widget handle.
ppainter
rrectangle
horizif true draw horizontal handle, otherwise draw vertical handle
isRectif true surrounding rectangle is also drawn
References Style_Model::handleDelta(), hole_xpm, Horizontal, model(), and Vertical.
◆ drawHoverRect()
void Style_Salome::drawHoverRect ( QPainter *  p,
const QRect &  r,
const double  rad,
const int  type,
const bool  border
ppainter
rrectangle
radcorners rounding radius
typeshadow type
borderif true border is colored with specific color
References Style_Model::AutoRaiseEffect, Style_Model::BorderTop, BUT_PERCENT_ON, Style_Model::color(), hasHover(), HIGH_WDG_MARGIN, Style_Model::HighlightBorder, Style_Model::HighlightEffect, Style_Tools::highlightRect(), Style_Model::HighlightWidget, model(), and Style_Model::widgetEffect().
◆ drawPrimitive()
◆ hasHover()
bool Style_Salome::hasHover ( ) const
true if any widget effect is currently used
References model(), Style_Model::NoEffect, and Style_Model::widgetEffect().
◆ initialize()
void Style_Salome::initialize ( QtxResourceMgr *  resMgr = 0,
const QString &  section = QString()
This method should be called at the very beginning of the application which uses SALOME style. The method initializes style properties from the current settings.
If the parameter resMgr is not 0, the style is initialized from the resources manager.
The parameter section allows customizing of the resources file section used to store style's properties. By default "Theme" section name is used.
resMgrresources manager
sectionresources file section name
See also
apply(), restore()
References Style_Model::fromResources(), and model().
◆ isActive()
bool Style_Salome::isActive ( )
true if SALOME style is set to the applcation or false otherwise
◆ model()
Style_Model * Style_Salome::model ( )
Get style model.
style model
References myModel.
◆ pixelMetric()
int Style_Salome::pixelMetric ( PixelMetric  metric,
const QStyleOption *  opt = 0,
const QWidget *  w = 0
metricmetric type
optstyle option
wwidget
metric value
References checkDebugLevel(), model(), and Style_Model::sliderSize().
◆ polish() [1/2]
void Style_Salome::polish ( QApplication *  app)
Performs late initialization of the given application object.
appapplication object
References checkDebugLevel(), model(), updateAllWidgets(), and updatePaletteColors().
◆ polish() [2/2]
void Style_Salome::polish ( QWidget *  w)
This function is called for every widget at some point after it has been fully created but just before it is shown for the very first time.
wwidget object
References checkDebugLevel(), and hasHover().
◆ restore()
void Style_Salome::restore ( )
See also
initialize(), apply()
References isActive(), model(), and Style_Model::restore().
◆ sizeFromContents()
QSize Style_Salome::sizeFromContents ( ContentsType  ct,
const QSize &  contentsSize,
ctcontents type
optstyle option
contentsSizecontents size
wwidget (optional)
size of the element
References checkDebugLevel(), DELTA_H_TAB, Style_Model::EditRadius, Style_Tools::getMaxRect(), model(), Style_Model::sliderSize(), and Style_Model::widgetRounding().
◆ standardIconImplementation
QIcon Style_Salome::standardIconImplementation ( StandardPixmap  standardIcon,
protectedslot
standardIconstandard icon type
optstyle option
wwidget (optional)
standard icon
References checkDebugLevel().
◆ standardPixmap()
QPixmap Style_Salome::standardPixmap ( StandardPixmap  stPixmap,
stPixmapstandard pixmap type
optstyle option
wwidget (optional)
standard pixmap
References checkDebugLevel(), cross_xpm, maximize_xpm, minimize_xpm, and normal_xpm.
◆ styleHint()
int Style_Salome::styleHint ( StyleHint  hint,
const QWidget *  w = 0,
QStyleHintReturn *  returnData = 0
hinthint type
optstyle option
wwidget (optional)
returnData(currently not used)
style hint value
References checkDebugLevel(), Style_Model::color(), Style_Model::GridLine, and model().
◆ subControlRect()
QRect Style_Salome::subControlRect ( ComplexControl  cc,
const QStyleOptionComplex *  opt,
SubControl  sc,
const QWidget *  wid = 0
cccomplex control type
optstyle option
scsubcontrol type
widwidget (optional)
subcontrol rectangle
References Style_Model::ButtonRadius, checkDebugLevel(), DELTA_SLIDER, Style_Model::EditRadius, Style_Tools::getMaxRect(), Horizontal, model(), SHADOW, and Style_Model::widgetRounding().
◆ subElementRect()
QRect Style_Salome::subElementRect ( SubElement  se,
sesubelement type
optstyle option
subelement rectangle
References checkDebugLevel(), Style_Model::EditRadius, Style_Tools::getMaxRect(), hasHover(), model(), SHADOW, and Style_Model::widgetRounding().
◆ titleText()
QString Style_Salome::titleText ( const QString &  txt,
const int  W,
const int  H,
QFont &  f
txtoriginal text
Wpossible width
Hpossible height
fused font
◆ unpolish()
void Style_Salome::unpolish ( QWidget *  w)
This function is the counterpart to polish(). It is called for every polished widget whenever the style is dynamically changed; the former style has to unpolish its settings before the new style can polish them again.
wwidget object
◆ update()
void Style_Salome::update ( )
◆ updateAllWidgets()
void Style_Salome::updateAllWidgets ( QApplication *  app)
References polish().
◆ updatePaletteColors()
void Style_Salome::updatePaletteColors ( )
References Style_Model::color(), model(), Style_Model::NColorRoles, and Style_Model::WindowText.
◆ myModel
Style_Model * Style_Salome::myModel = 0
staticprivate
