Style_PrefDlg Class Reference
SALOME style prefences dialog box class. More...
#include <Style_PrefDlg.h>
Inheritance diagram for Style_PrefDlg:
class  PaletteEditor
 SALOME style palette editor widget. More...
Signals
void styleChanged ()
- Signals inherited from QtxDialog
void dlgButton (int)
 Emitted when the user button is clicked. More...
void dlgParamChanged ()
 This signal can be used in successor classes to signalize about some dialog parameter changing. More...
void dlgHelp ()
 Emitted when the "Help" button is clicked. More...
void dlgApply ()
 Emitted when the "Apply" button is clicked. More...
void dlgOk ()
 Emitted when the "OK" button is clicked. More...
void dlgNo ()
 Emitted when the "No" button is clicked. More...
void dlgYes ()
 Emitted when the "Yes" button is clicked. More...
void dlgClose ()
 Emitted when the "Close" button is clicked. More...
void dlgCancel ()
 Emitted when the "Cancel" button is clicked. More...
 Style_PrefDlg (QWidget *=0)
 ~Style_PrefDlg ()
void accept ()
 Called when "OK" button is clicked. More...
bool eventFilter (QObject *, QEvent *)
 Process key press event. More...
- Public Member Functions inherited from QtxDialog
 QtxDialog (QWidget *=0, bool=false, bool=false, const int=Standard, Qt::WindowFlags=0)
virtual ~QtxDialog ()
void setDialogFlags (const int)
 Set specified dialog box flags. More...
void clearDialogFlags (const int)
 Clear specified the dialog flags. More...
bool testDialogFlags (const int) const
 Test specified dialog flags. More...
void setButtonFlags (const int)
 Add specified control button(s) to the dialog box. More...
void clearButtonFlags (const int)
 Remove specified control button(s) from the dialog box. More...
bool testButtonFlags (const int) const
 Test specified buttons. More...
int buttonPosition (const int) const
 Get specified control button position. More...
void setButtonPosition (const int, const int=-1)
 Set the specified control button(s) position. More...
void setPlacePosition (const int, const int)
 Set button position for all buttons in specified area. More...
int placePolicy (const int) const
 Get buttons layouting policy for the specified area. More...
void setPlacePolicy (const int, const int)
 set buttons layouting policy for the specified area. More...
void setButtonPlace (const int, const int)
 Move specified button(s) into specified area. More...
QString buttonText (const int)
 Get specified button's text. More...
void setButtonText (const int, const QString &text)
 Set specified button's text. More...
void setButtonFocus (const int)
 Sets the keyboard focus to the specified button. More...
bool hasButtonFocus (const int) const
 Check if specified button has keyboard focus. More...
bool isButtonEnabled (const int) const
 Get "enabled" status of the specified button(s). More...
void setButtonEnabled (const bool, const int)
 Enable/disable specified button(s). More...
bool isBorderEnabled (const int) const
 Check if border is enabled. More...
void setBorderEnabled (const bool, const int)
 Show/hide border for the specified button area. More...
void removeButton (const int)
 Remove user button. More...
int insertButton (const QString &, const int=BottomArea)
 Add user button to the dialog box. More...
QIntList userButtonIds () const
 Get all user button IDs. More...
QAbstractButton * userButton (const int) const
 Get user button by the specified id. More...
uint setAlignment (uint align)
 Sets alignment policy. More...
Private Types
enum  { Current , Default , Global , User }
enum  { TypeRole = Qt::UserRole + 123 , NameRole }
Private Slots
void onApply ()
 Called when "Apply" button is pressed. More...
void onHelp ()
 Called when "Help" button is pressed. More...
void onStyleChanged ()
 Called when user selects any theme item in the themes list. More...
void onLinesType ()
 Called when lines type is changed. More...
void onChanged ()
 Called when any style parameter is changed by the user. More...
void onItemChanged (QListWidgetItem *)
 Called when user theme is renamed by the user. More...
void onEffectChanged (QAbstractButton *)
 Called when widget effect is changed. More...
Style_ResourceMgr * resourceMgr ()
 Get SALOME themes resource manager. More...
void fromModel (Style_Model *)
 Initialize dialog box fields from SALOME style model. More...
void toModel (Style_Model *) const
 Save values from dialog box fields to SALOME style model. More...
QString findUniqueName (const QString &, QListWidgetItem *=0, bool=false)
 Find unique name for the theme name. More...
Style_ResourceMgr * myResMgr
QCheckBox * myStyleCheck
QListWidget * myStylesList
QTabWidget * myStylesTab
PaletteEditor * myPaletteEditor
QtxFontEdit * myFontEdit
QComboBox * myLinesCombo
QSlider * myLinesTransparency
QtxDoubleSpinBox * myEditRound
QtxDoubleSpinBox * myButtonRound
QtxDoubleSpinBox * myFrameRound
QtxDoubleSpinBox * mySliderRound
QCheckBox * myAntiAliasing
QSpinBox * myHorHandleDelta
QSpinBox * myVerHandleDelta
QSpinBox * mySplitterLength
QSpinBox * mySliderSize
QRadioButton * myEffectNone
QRadioButton * myEffectHighlight
QRadioButton * myEffectAutoRaise
QRadioButton * myCurrentEffect
- Public Types inherited from QtxDialog
enum  PlacePolicy { Position , Expand , Uniform }
 Buttons alignment type. More...
enum  ButtonArea { TopArea , BottomArea , LeftArea , RightArea }
 Buttons area. More...
enum  ButtonPosition {
  Left , Right , Center , Top = Left ,
  Bottom = Right
 Button position. More...
enum  ButtonFlags {
  None = 0x00000000 , OK = 0x00000001 , Apply = 0x00000002 , Cancel = 0x00000004 ,
  Yes = 0x00000008 , No = 0x00000010 , Close = 0x00000020 , Help = 0x00000040 ,
  OKCancel = OK | Cancel , YesNo = Yes | No , Standard = OK | Cancel | Help , All = Standard | YesNo | Apply | Close
 Button ID flags. More...
enum  DialogFlags { Accept = 0x000001 , Reject = 0x000002 , AlignOnce = 0x000004 , SetFocus = 0x000008 }
 Dialog box flags. More...
- Public Slots inherited from QtxDialog
void update ()
 Update dialog box. More...
virtual void setVisible (bool)
 Show/hide dialog box, set keyboard focus to the dialog. More...
- Static Public Member Functions inherited from QtxDialog
static void setUnits (QLabel *, const QString &)
 Set measure units to the specified label. More...
- Protected Types inherited from QtxDialog
typedef QMap< int, QAbstractButton * > ButtonMap
 button map More...
- Protected Slots inherited from QtxDialog
virtual void accept ()
 Accept the dialog box. More...
virtual void reject ()
 Reject the dialog box. More...
- Protected Member Functions inherited from QtxDialog
QFrame * mainFrame () const
 Get dialog box main frame widget. More...
virtual bool acceptData () const
 Check if data entered by the user is valid. More...
virtual bool rejectData () const
 Check if dialog box can be cancelled. More...
virtual QAbstractButton * createButton (QWidget *)
 Create new user button. More...
QAbstractButton * button (const int) const
 Get button by the specified ID. More...
ButtonMap buttons (const int=All) const
 Get buttons by the specified IDs. More...
int buttonId (const QAbstractButton *) const
 Get specified button's identifier. More...
int buttonPosition (QAbstractButton *) const
 Get position of specified button. More...
virtual void showEvent (QShowEvent *)
 Align this dialog according to the parent widget and alignment policy before the dialog box is shown. More...
virtual void hideEvent (QHideEvent *)
 Process all existing events when dialog box is hidden. More...
virtual void closeEvent (QCloseEvent *)
 Called when user closes dialog box. More...
virtual void childEvent (QChildEvent *)
 Update dialog box layout when the size grip is added. More...
virtual void keyPressEvent (QKeyEvent *)
 Process key pressing event. More...
The dialog box lists all SALOME style themes available via the application and allows user to create own schemas.
◆ anonymous enum
anonymous enum
Current
Default
Global
User
◆ anonymous enum
anonymous enum
TypeRole
NameRole
◆ Style_PrefDlg()
◆ ~Style_PrefDlg()
Style_PrefDlg::~Style_PrefDlg ( )
◆ accept()
void Style_PrefDlg::accept ( )
Reimplemented from QtxDialog.
References QtxDialog::accept(), and onApply().
◆ eventFilter()
bool Style_PrefDlg::eventFilter ( QObject *  o,
QEvent *  e
ekey event
References myStylesList, NameRole, QtxResourceMgr::remove(), resourceMgr(), QtxResourceMgr::save(), TypeRole, and User.
◆ findUniqueName()
QString Style_PrefDlg::findUniqueName ( const QString &  name,
QListWidgetItem *  item = 0,
bool  addSuffix = false
nametheme name template
itemif not 0, used to be ignored when browsing through items list
addSuffixif true, the integrer suffix is always added to the theme name (otherwise suffix is added only if item name is not unique)
new unique theme name
References myStylesList.
◆ fromModel()
◆ onApply
void Style_PrefDlg::onApply ( )
privateslot
◆ onChanged
void Style_PrefDlg::onChanged ( )
privateslot
◆ onEffectChanged
void Style_PrefDlg::onEffectChanged ( QAbstractButton *  rb)
privateslot
References myCurrentEffect, and styleChanged().
◆ onHelp
void Style_PrefDlg::onHelp ( )
privateslot
◆ onItemChanged
void Style_PrefDlg::onItemChanged ( QListWidgetItem *  item)
privateslot
References findUniqueName(), myStylesList, and onChanged().
◆ onLinesType
void Style_PrefDlg::onLinesType ( )
privateslot
References myLinesCombo, myLinesTransparency, Style_Model::NoLines, and styleChanged().
◆ onStyleChanged
void Style_PrefDlg::onStyleChanged ( )
privateslot
References Current, Default, fromModel(), Style_Model::fromResources(), Global, Style_Salome::model(), myStylesList, NameRole, onLinesType(), resourceMgr(), TypeRole, and User.
◆ resourceMgr()
Style_ResourceMgr * Style_PrefDlg::resourceMgr ( )
References myResMgr.
◆ styleChanged
void Style_PrefDlg::styleChanged ( )
signal
◆ toModel()
◆ myAntiAliasing
QCheckBox* Style_PrefDlg::myAntiAliasing
◆ myButtonRound
QtxDoubleSpinBox* Style_PrefDlg::myButtonRound
◆ myCurrentEffect
QRadioButton* Style_PrefDlg::myCurrentEffect
◆ myEditRound
QtxDoubleSpinBox* Style_PrefDlg::myEditRound
◆ myEffectAutoRaise
QRadioButton* Style_PrefDlg::myEffectAutoRaise
◆ myEffectHighlight
QRadioButton* Style_PrefDlg::myEffectHighlight
◆ myEffectNone
QRadioButton* Style_PrefDlg::myEffectNone
◆ myFontEdit
QtxFontEdit* Style_PrefDlg::myFontEdit
◆ myFrameRound
QtxDoubleSpinBox* Style_PrefDlg::myFrameRound
◆ myHorHandleDelta
QSpinBox* Style_PrefDlg::myHorHandleDelta
◆ myLinesCombo
QComboBox* Style_PrefDlg::myLinesCombo
◆ myLinesTransparency
QSlider* Style_PrefDlg::myLinesTransparency
◆ myPaletteEditor
PaletteEditor* Style_PrefDlg::myPaletteEditor
◆ myResMgr
Style_ResourceMgr* Style_PrefDlg::myResMgr
◆ mySliderRound
QtxDoubleSpinBox* Style_PrefDlg::mySliderRound
◆ mySliderSize
QSpinBox* Style_PrefDlg::mySliderSize
◆ mySplitterLength
QSpinBox* Style_PrefDlg::mySplitterLength
◆ myStyleCheck
QCheckBox* Style_PrefDlg::myStyleCheck
◆ myStylesList
QListWidget* Style_PrefDlg::myStylesList
◆ myStylesTab
QTabWidget* Style_PrefDlg::myStylesTab
◆ myVerHandleDelta
QSpinBox* Style_PrefDlg::myVerHandleDelta
