Template class for event which calls the function with two arguments and returning result. More...
#include <SALOME_Event.h>
Public Types | |
| typedef TRes | TResult |
| typedef TResult(TObject::* | TAction) (TArg, TArg1) |
| TMemFun2ArgEvent (TObject *theObject, TAction theAction, TArg theArg, TArg1 theArg1, TResult theResult=TResult()) | |
| virtual void | Execute () |
| This method should be redefined in the successor classes to do real work. More... | |
Public Member Functions inherited from SALOME_Event | |
| SALOME_Event () | |
| Constructor. More... | |
| virtual | ~SALOME_Event () |
| Destructor. More... | |
| void | ExecutePostedEvent () |
| This method should be called by the main GUI thread in order to execute the code specific for this event and finally to inform the calling thread that the event has been processed waking it up with help of the semaphore . More... | |
| virtual void | Execute ()=0 |
| void | process () |
| Post the event and wait for its completion. process() should be called from a secondary thread only. More... | |
Public Attributes | |
| TResult | myResult |
Private Attributes | |
| TObject * | myObject |
| TAction | myAction |
| TStoreArg | myArg |
| TStoreArg1 | myArg1 |
Additional Inherited Members | |
Static Public Member Functions inherited from SALOME_Event | |
| static bool | IsSessionThread () |
| Check if the processing is in the main application thread. More... | |
Protected Member Functions inherited from SALOME_Event | |
| void | processed () |
| Use this method to signal that this event has been processed. More... | |
Static Protected Member Functions inherited from SALOME_Event | |
| static void | GetSessionThread () |
| Initialize event mechanism. More... | |
| typedef TResult(TObject::* TMemFun2ArgEvent< TObject, TRes, TArg, TArg1, TStoreArg, TStoreArg1 >::TAction) (TArg, TArg1) |
| typedef TRes TMemFun2ArgEvent< TObject, TRes, TArg, TArg1, TStoreArg, TStoreArg1 >::TResult |
inline |
inlinevirtual |
Implements SALOME_Event.
References TMemFun2ArgEvent< TObject, TRes, TArg, TArg1, TStoreArg, TStoreArg1 >::myAction, TMemFun2ArgEvent< TObject, TRes, TArg, TArg1, TStoreArg, TStoreArg1 >::myArg, TMemFun2ArgEvent< TObject, TRes, TArg, TArg1, TStoreArg, TStoreArg1 >::myArg1, TMemFun2ArgEvent< TObject, TRes, TArg, TArg1, TStoreArg, TStoreArg1 >::myObject, and TMemFun2ArgEvent< TObject, TRes, TArg, TArg1, TStoreArg, TStoreArg1 >::myResult.
private |
private |
private |
private |
| TResult TMemFun2ArgEvent< TObject, TRes, TArg, TArg1, TStoreArg, TStoreArg1 >::myResult |
