VTKViewer_PolyDataMapper Class Reference
OpenGL Point Sprites PolyData Mapper. More...
#include <VTKViewer_PolyDataMapper.h>
Inheritance diagram for VTKViewer_PolyDataMapper:
struct  Locations
enum  ExtensionsState { ES_None = 0 , ES_Error , ES_Ok }
 vtkTypeMacro (VTKViewer_PolyDataMapper, vtkOpenGLPolyDataMapper) void SetMarkerEnabled(bool)
 Set point marker enabled. More...
void SetBallEnabled (bool)
 Set point ball enabled. More...
bool GetBallEnabled ()
void SetBallScale (double)
 Set ball scale factor. More...
double GetBallScale ()
void SetMarkerStd (VTK::MarkerType, VTK::MarkerScale)
 Set standard point marker. More...
void SetMarkerTexture (int, VTK::MarkerTexture)
 Set custom point marker. More...
VTK::MarkerType GetMarkerType ()
 Get type of the point marker. More...
VTK::MarkerScale GetMarkerScale ()
 Get scale of the point marker. More...
int GetMarkerTexture ()
 Get texture identifier of the point marker. More...
virtual void RenderPiece (vtkRenderer *, vtkActor *)
 Implement superclass render method. More...
virtual int Draw (vtkRenderer *, vtkActor *)
 Draw method for OpenGL. More...
static VTKViewer_PolyDataMapper * New ()
 VTKViewer_PolyDataMapper ()
 ~VTKViewer_PolyDataMapper ()
int InitExtensions ()
 Initializing OpenGL extensions. More...
void InitPointSprites ()
 Activate Point Sprites. More...
void CleanupPointSprites ()
 Deactivate Point Sprites. More...
void InitTextures ()
 Initializing textures for Point Sprites. More...
int InitShader ()
 Initializing of the Vertex Shader. More...
void InternalDraw (vtkRenderer *, vtkActor *)
Private Types
typedef std::map< int, vtkSmartPointer< vtkImageData > > ImageDataMap
int ExtensionsInitialized
GLuint PointSpriteTexture
vtkSmartPointer< vtkImageData > ImageData
VTKViewer_OpenGLHelper OpenGLHelper
GLhandleARB PointProgram
struct VTKViewer_PolyDataMapper::Locations myLocations
bool MarkerEnabled
bool BallEnabled
double BallScale
VTK::MarkerType MarkerType
VTK::MarkerScale MarkerScale
int MarkerId
ImageDataMap StandardTextures
ImageDataMap CustomTextures
ImageDataMap SpecialTextures
VTKViewer_PolyDataMapper is a class that maps polygonal data (i.e., vtkPolyData) to graphics primitives. It is performing the mapping to the rendering/graphics hardware/software. It is now possible to set a memory limit for the pipeline in the mapper. If the total estimated memory usage of the pipeline is larger than this limit, the mapper will divide the data into pieces and render each in a for loop.
◆ ImageDataMap
typedef std::map< int, vtkSmartPointer<vtkImageData> > VTKViewer_PolyDataMapper::ImageDataMap
◆ ExtensionsState
ES_None
ES_Error
ES_Ok
◆ VTKViewer_PolyDataMapper()
◆ ~VTKViewer_PolyDataMapper()
VTKViewer_PolyDataMapper::~VTKViewer_PolyDataMapper ( )
◆ CleanupPointSprites()
void VTKViewer_PolyDataMapper::CleanupPointSprites ( )
References GL_POINT_SPRITE_ARB, and GL_VERTEX_PROGRAM_POINT_SIZE_ARB.
◆ Draw()
int VTKViewer_PolyDataMapper::Draw ( vtkRenderer *  ren,
vtkActor *  act
References ImageData, InternalDraw(), MarkerEnabled, MarkerType, and VTK::MT_NONE.
◆ GetBallEnabled()
bool VTKViewer_PolyDataMapper::GetBallEnabled ( )
References BallEnabled.
◆ GetBallScale()
double VTKViewer_PolyDataMapper::GetBallScale ( )
References BallScale.
◆ GetMarkerScale()
VTK::MarkerScale VTKViewer_PolyDataMapper::GetMarkerScale ( )
References MarkerScale.
◆ GetMarkerTexture()
int VTKViewer_PolyDataMapper::GetMarkerTexture ( )
References MarkerId.
◆ GetMarkerType()
VTK::MarkerType VTKViewer_PolyDataMapper::GetMarkerType ( )
References MarkerType.
◆ InitExtensions()
int VTKViewer_PolyDataMapper::InitExtensions ( )
◆ InitPointSprites()
void VTKViewer_PolyDataMapper::InitPointSprites ( )
References BallEnabled, GL_POINT_SPRITE_ARB, and GL_VERTEX_PROGRAM_POINT_SIZE_ARB.
◆ InitShader()
◆ InitTextures()
void VTKViewer_PolyDataMapper::InitTextures ( )
◆ InternalDraw()
◆ New()
static VTKViewer_PolyDataMapper * VTKViewer_PolyDataMapper::New ( )
◆ RenderPiece()
void VTKViewer_PolyDataMapper::RenderPiece ( vtkRenderer *  ren,
vtkActor *  act
◆ SetBallEnabled()
void VTKViewer_PolyDataMapper::SetBallEnabled ( bool  theBallEnabled)
References BallEnabled, BallTextureId, ImageData, VTK::MakeTexture(), and SpecialTextures.
◆ SetBallScale()
void VTKViewer_PolyDataMapper::SetBallScale ( double  theBallScale)
◆ SetMarkerStd()
void VTKViewer_PolyDataMapper::SetMarkerStd ( VTK::MarkerType  theMarkerType,
VTK::MarkerScale  theMarkerScale
◆ SetMarkerTexture()
void VTKViewer_PolyDataMapper::SetMarkerTexture ( int  theMarkerId,
VTK::MarkerTexture  theMarkerTexture
References CustomTextures, ImageData, VTK::MakeVTKImage(), MarkerId, MarkerType, and VTK::MT_USER.
◆ vtkTypeMacro()
VTKViewer_PolyDataMapper::vtkTypeMacro ( VTKViewer_PolyDataMapper  ,
◆ BallEnabled
bool VTKViewer_PolyDataMapper::BallEnabled
◆ BallScale
double VTKViewer_PolyDataMapper::BallScale
◆ CustomTextures
ImageDataMap VTKViewer_PolyDataMapper::CustomTextures
◆ ExtensionsInitialized
int VTKViewer_PolyDataMapper::ExtensionsInitialized
◆ ImageData
vtkSmartPointer<vtkImageData> VTKViewer_PolyDataMapper::ImageData
◆ MarkerEnabled
bool VTKViewer_PolyDataMapper::MarkerEnabled
◆ MarkerId
int VTKViewer_PolyDataMapper::MarkerId
◆ MarkerScale
VTK::MarkerScale VTKViewer_PolyDataMapper::MarkerScale
◆ MarkerType
VTK::MarkerType VTKViewer_PolyDataMapper::MarkerType
◆ myLocations
struct VTKViewer_PolyDataMapper::Locations VTKViewer_PolyDataMapper::myLocations
◆ OpenGLHelper
VTKViewer_OpenGLHelper VTKViewer_PolyDataMapper::OpenGLHelper
◆ PointProgram
GLhandleARB VTKViewer_PolyDataMapper::PointProgram
◆ PointSpriteTexture
GLuint VTKViewer_PolyDataMapper::PointSpriteTexture
◆ SpecialTextures
ImageDataMap VTKViewer_PolyDataMapper::SpecialTextures
◆ StandardTextures
ImageDataMap VTKViewer_PolyDataMapper::StandardTextures
