PVSERVER_ORB::PVSERVER_Gen Interface Reference
The main interface class for PVSERVER CORBA service. Instantiation of this class has to be done before access to any other PARAVIS interfaces. More...
import"PVSERVER_Gen.idl";
string GetIOR ()
 Returns IOR of the current object. More...
string FindOrStartPVServer (in long port)
boolean StopPVServer ()
void SetGUIConnected (in boolean isConnected)
boolean GetGUIConnected ()
◆ FindOrStartPVServer()
string PVSERVER_ORB::PVSERVER_Gen::FindOrStartPVServer ( in long  port)
If a pvserver is already started, returns its current URL, regardless of the provided parameters. If not, start a pvserver on the machine hosting the PARAVIS engine and on the given port. If port <= 0, a free port is automatically detected, starting from the usual 11111 pvserver port.
◆ GetGUIConnected()
boolean PVSERVER_ORB::PVSERVER_Gen::GetGUIConnected ( )
Indicates if the GUI process is already connected to the pvserver. This avoids multiple attempts to connect from a single thread (makes ParaView crash).
◆ GetIOR()
string PVSERVER_ORB::PVSERVER_Gen::GetIOR ( )
◆ SetGUIConnected()
void PVSERVER_ORB::PVSERVER_Gen::SetGUIConnected ( in boolean  isConnected)
◆ StopPVServer()
boolean PVSERVER_ORB::PVSERVER_Gen::StopPVServer ( )
Tries to stop the PVserver currently running (send KILL).
false if no server was running, true otherwise.
The documentation for this interface was generated from the following file:
