SALOME_LifeCycleCORBA.hxx
23// File : SALOME_LifeCycleCORBA.hxx
24// Author : Paul RASCLE, EDF - MARC TAJCHMAN, CEA
25// Module : SALOME
26
27#ifndef _SALOME_LIFECYCLECORBA_HXX_
28#define _SALOME_LIFECYCLECORBA_HXX_
30#include <stdlib.h>
31#ifndef WIN32
32#include <unistd.h>
33#endif
34#include <string>
35
36#include <SALOMEconfig.h>
37#include <Utils_SALOME_Exception.hxx>
38#include CORBA_CLIENT_HEADER(SALOME_ContainerManager)
39#include CORBA_CLIENT_HEADER(SALOME_Component)
40#include <iostream>
41
42#ifdef WIN32
43# if defined LIFECYCLECORBA_EXPORTS || defined SalomeLifeCycleCORBA_EXPORTS
44# define LIFECYCLECORBA_EXPORT __declspec( dllexport )
45# else
46# define LIFECYCLECORBA_EXPORT __declspec( dllimport )
47# endif
48#else
49# define LIFECYCLECORBA_EXPORT
50#endif
51
52
54
56{
57public :
60};
61
63{
64public:
66 virtual ~SALOME_LifeCycleCORBA();
67
68 Engines::EngineComponent_ptr
69 FindComponent(const Engines::ContainerParameters& params,
70 const char *componentName);
71
72 Engines::EngineComponent_ptr
73 LoadComponent(const Engines::ContainerParameters& params,
74 const char *componentName);
75
76 Engines::EngineComponent_ptr
77 FindOrLoad_Component(const Engines::ContainerParameters& params,
78 const char *componentName);
79
80 Engines::EngineComponent_ptr
81 FindOrLoad_Component(const char *containerName,
82 const char *componentName);
83
84 // Parallel extension
85 Engines::EngineComponent_ptr
86 Load_ParallelComponent(const Engines::ContainerParameters& params,
87 const char *componentName);
88
89 bool isKnownComponentClass(const char *componentName);
90
91 int NbProc(const Engines::ContainerParameters& params);
92
93 static void preSet(Engines::ResourceParameters& outparams);
94 static void preSet(Engines::ContainerParameters& outparams);
95
96 Engines::ContainerManager_ptr getContainerManager();
97 Engines::ResourcesManager_ptr getResourcesManager();
98 SALOME_NamingService_Abstract * namingService();
99 CORBA::ORB_ptr orb();
100 void copyFile(const char* hostSrc, const char* fileSrc, const char* hostDest, const char* fileDest);
101
102 void shutdownServers(bool shutdownLauncher=true);
103 static void killOmniNames();
104
105protected:
106
112 Engines::EngineComponent_ptr
113 _FindComponent(const Engines::ContainerParameters& params,
114 const char *componentName,
115 const Engines::ResourceList& listOfResources);
116
117 Engines::EngineComponent_ptr
118 _LoadComponent(const Engines::ContainerParameters& params,
119 const char *componentName);
120
123 Engines::ContainerManager_var _ContManager;
124 Engines::ResourcesManager_var _ResManager;
125
126} ;
127
129{
130public:
132};
133
134#endif
#define LIFECYCLECORBA_EXPORT
Definition: SALOME_LifeCycleCORBA.hxx:49
Definition: SALOME_LifeCycleCORBA.hxx:56
Definition: SALOME_LifeCycleCORBA.hxx:129
A class to manage life cycle of SALOME components.
Definition: SALOME_LifeCycleCORBA.hxx:63
SALOME_NamingService_Abstract * _NSnew
Definition: SALOME_LifeCycleCORBA.hxx:122
Definition: SALOME_LifeCycleCORBA.hxx:121
Definition: SALOME_LifeCycleCORBA.hxx:123
Definition: SALOME_LifeCycleCORBA.hxx:124
Definition: SALOME_NamingService_Abstract.hxx:46
sequence< string > ResourceList
Type to transmit list of resources.
Definition: SALOME_ResourcesManager.idl:35
Definition: SALOME_KernelServices.cxx:123
containerName
Definition: SALOME_ContainerPy.py:383
def killOmniNames(port)
Definition: salome_utils.py:556
orb
Definition: salome.py:122
Type to describe required properties of a container.
Definition: SALOME_ContainerManager.idl:38
Type to describe required properties of a resource.
Definition: SALOME_ResourcesManager.idl:42
