SALOME_ModuleCatalog_Acomponent_impl.hxx
23// SALOME ModuleCatalog : implementation of ModuleCatalog server which parsers xml description of modules
24// File : SALOME_ModuleCatalog_Acomponent_impl.hxx
25// Author : Estelle Deville
26// Module : SALOME
27// $Header$
28//
29#ifndef ACOMPONENT_IMPL_H
30#define ACOMPONENT_IMPL_H
31
33
34#include <SALOMEconfig.h>
35
36#include CORBA_SERVER_HEADER(SALOME_ModuleCatalog)
37
38#ifdef WIN32
39#pragma warning(disable:4275) // Disable warning interface non dll
40//#pragma warning(disable:4290) // Warning Exception ...
41#endif
42
43class MODULECATALOG_EXPORT SALOME_ModuleCatalog_AcomponentImpl: public POA_SALOME_ModuleCatalog::Acomponent
44{
45public:
48
51
53
56 virtual SALOME_ModuleCatalog::ListOfInterfaces* GetInterfaceList() ;
57
59
64 GetInterface(const char* interfacename);
65
67
72 GetServiceList(const char* interfacename);
73
74
76
83 GetService(const char* interfacename,
84 const char* servicename);
85
87
92 GetDefaultService(const char* interfacename);
93
95
99 virtual char* GetPathPrefix(const char* machinename);
100
102
105 virtual char* constraint();
106
108
111 virtual char* componentname();
112
114
117 virtual char* componentusername();
118
120
123 virtual SALOME_ModuleCatalog::ComponentType component_type() ;
124
126
129 virtual char* component_icone();
130
132
135 virtual SALOME_ModuleCatalog::ImplType implementation_type();
136
138
141 virtual char* implementation_name();
142
143private :
144
146
148
154
156
162
164
170
172
178
179};
180
181
182#endif // ACOMPONENT_IMPL_H
#define MODULECATALOG_EXPORT
Definition: SALOME_ModuleCatalog.hxx:37
Definition: SALOME_ModuleCatalog_Acomponent_impl.hxx:44
SALOME_ModuleCatalog::ComponentDef _Component
Definition: SALOME_ModuleCatalog_Acomponent_impl.hxx:145
SALOME_ModuleCatalog_AcomponentImpl(SALOME_ModuleCatalog::ComponentDef &C)
standard constructor
const char * duplicate(const char *const str)
This function can be changed by strdup() if strdup() is ANSI.
Definition: duplicate.cxx:42
ImplType
Component implementation type.
Definition: SALOME_ModuleCatalog.idl:156
ComponentType
This enumeration contains a current set of definitions of the components integrated into SALOME appli...
Definition: SALOME_ModuleCatalog.idl:42
sequence< string > ListOfServices
List of services.
Definition: SALOME_ModuleCatalog.idl:132
sequence< string > ListOfInterfaces
List of interface names.
Definition: SALOME_ModuleCatalog.idl:142
C
Definition: TestModuleCatalog.py:54
Description of a component.
Definition: SALOME_ModuleCatalog.idl:165
This struct contains fields defining each interface.
Definition: SALOME_ModuleCatalog.idl:135
This struct contains fields defining each service.
Definition: SALOME_ModuleCatalog.idl:120
struct to define datastream ports
Definition: SALOME_ModuleCatalog.idl:67
This struct contains fields defining the parameter of the service.
Definition: SALOME_ModuleCatalog.idl:53
