KERNEL_PY.kernel.enumerate.Enumerate Class Reference
This class emulates a C-like enum for python. More...
def __init__ (self, keys, offset=0)
 Canonical constructor. More...
def contains (self, key)
 Return true if this enumerate contains the specified key string. More...
def isValid (self, value)
 Returns true if the specified integer value is defined as an identifier in this enumerate. More...
def listkeys (self)
 Returns the list of keys in this enumerate. More...
def listvalues (self)
 Returns the list of values specified to initiate this enumerate. More...
def keyOf (self, value)
 Returns the symbolic key string associated to the specified identifier value. More...
 _dict_keynumbers
 _dict_numberkeys
It is initialized with a list of strings to be used as the enum symbolic keys. The enum values are automatically generated as sequencing integer starting at the specified offset value.
This class emulates a C-like enum for python. It is initialized with a list
◆ __init__()
def KERNEL_PY.kernel.enumerate.Enumerate.__init__ (   self,
  keys,
  offset = 0
keysa list of string to be used as the enum symbolic keys. The enum values are automatically generated as a sequence of integers starting at the specified offset value.
@keys a list of string to be used as the enum symbolic keys. The enum values
offset value.
◆ contains()
def KERNEL_PY.kernel.enumerate.Enumerate.contains (   self,
  key
keya key string to test
@key a key string to test
References enumerate.Enumerate._dict_keynumbers, and KERNEL_PY.kernel.enumerate.Enumerate._dict_keynumbers.
◆ isValid()
def KERNEL_PY.kernel.enumerate.Enumerate.isValid (   self,
  value
valuea value to test
in this enumerate.
@value a value to test
References enumerate.Enumerate._dict_numberkeys, and KERNEL_PY.kernel.enumerate.Enumerate._dict_numberkeys.
Referenced by enumerate.Enumerate.keyOf(), and KERNEL_PY.kernel.enumerate.Enumerate.keyOf().
◆ keyOf()
def KERNEL_PY.kernel.enumerate.Enumerate.keyOf (   self,
  value
valuean integer value whose associated key string is requested.
value.
@param value : an integer value whose associated key string is requested.
References enumerate.Enumerate._dict_numberkeys, KERNEL_PY.kernel.enumerate.Enumerate._dict_numberkeys, enumerate.Enumerate.isValid(), and KERNEL_PY.kernel.enumerate.Enumerate.isValid().
◆ listkeys()
def KERNEL_PY.kernel.enumerate.Enumerate.listkeys (   self)
◆ listvalues()
def KERNEL_PY.kernel.enumerate.Enumerate.listvalues (   self)
◆ _dict_keynumbers
◆ _dict_numberkeys
