logger.Logger Class Reference
This class formats and displays log messages in Salome environment. More...
Inheritance diagram for logger.Logger:
def __init__ (self, keyword="KEY", level=salome.kernel.logconfig.loggingLevel, color=None, sourceFileName=None)
def showDebug (self)
 Log all messages, including DEBUG level messages (equivalent to setLevel(logging.DEBUG)). More...
def setLogFile (self, logFilename)
 Define a log file to record the log messages (in addition to the standard output). More...
def setColor (self, color)
 Set the color of log messages on color-capable terminals. More...
def closeLogFile (self)
 Close the log file. More...
def hideDebug (self)
 Hide DEBUG level messages (equivalent to setLevel(logging.INFO)). More...
 _baseFormatString
 _baseFormatter
 _stdoutStream
 _stdoutHandler
 _fileHandler
It inherits logging.Logger class defined in logging module from Python library, so all methods from logging.Logger can be used here. The format of the traces is: LEVEL[keyword] : Message
,where LEVEL is the level of the message (DEBUG, INFO, etc.), keyword is the name of the logger, and Message is the message to log.
When creating a new Logger object, the parameter keyword defines the name of the logger, level defines the logging level (default is logging.DEBUG if KERNEL module is configured with –enable-debug option or logging.WARNING otherwise), and color defines the color of the log messages for this logger (log messages will appear in color only when displayed on color - capable ASCII terminals). See module salome.kernel.termcolor for the color constants.
By default, log messages will be displayed only on standard output. They can also be recorded in a file (see method setLogFile()). For now, the CORBA-based logging facility can not be used through this class.
A source filename sourceFileName can be defined. If this argument is specified, then the keyword is modified to the basename of the sourceFileName
Basic usage::
from salome.kernel.logger import Logger
log = Logger("Test")
log.debug("Debug message")
log.info("Information message")
log.warning("Warning message")
log.error("Error message")
log.critical("Fatal error message")
Definition: SALOME_Logger_Server.hxx:61
◆ __init__()
def logger.Logger.__init__ (   self,
  keyword = "KEY",
  level = salome.kernel.logconfig.loggingLevel,
  color = None,
  sourceFileName = None
Reimplemented in logger.ExtLogger.
◆ closeLogFile()
def logger.Logger.closeLogFile (   self)
◆ hideDebug()
def logger.Logger.hideDebug (   self)
◆ setColor()
◆ setLogFile()
def logger.Logger.setLogFile (   self,
  logFilename
◆ showDebug()
def logger.Logger.showDebug (   self)
◆ _baseFormatString
logger.Logger._baseFormatString
◆ _baseFormatter
◆ _fileHandler
◆ _stdoutHandler
logger.Logger._stdoutHandler
◆ _stdoutStream
logger.Logger._stdoutStream
