KERNEL_PY.kernel.logger.Logger Class Reference
This class formats and displays log messages in Salome environment. More...
Inheritance diagram for KERNEL_PY.kernel.logger.Logger:
def __init__ (self, keyword="KEY", level=salome.kernel.logconfig.loggingLevel, color=None, sourceFileName=None)
def showDebug (self)
 Log all messages, including DEBUG level messages (equivalent to setLevel(logging.DEBUG)). More...
def setLogFile (self, logFilename)
 Define a log file to record the log messages (in addition to the standard output). More...
def setColor (self, color)
 Set the color of log messages on color-capable terminals. More...
def closeLogFile (self)
 Close the log file. More...
def hideDebug (self)
 Hide DEBUG level messages (equivalent to setLevel(logging.INFO)). More...
 _baseFormatString
 _baseFormatter
 _stdoutStream
 _stdoutHandler
 _fileHandler
It inherits logging.Logger class defined in logging module from Python library, so all methods from logging.Logger can be used here. The format of the traces is: LEVEL[keyword] : Message
,where LEVEL is the level of the message (DEBUG, INFO, etc.), keyword is the name of the logger, and Message is the message to log.
When creating a new Logger object, the parameter keyword defines the name of the logger, level defines the logging level (default is logging.DEBUG if KERNEL module is configured with –enable-debug option or logging.WARNING otherwise), and color defines the color of the log messages for this logger (log messages will appear in color only when displayed on color - capable ASCII terminals). See module salome.kernel.termcolor for the color constants.
By default, log messages will be displayed only on standard output. They can also be recorded in a file (see method setLogFile()). For now, the CORBA-based logging facility can not be used through this class.
A source filename sourceFileName can be defined. If this argument is specified, then the keyword is modified to the basename of the sourceFileName
Basic usage::
from salome.kernel.logger import Logger
log = Logger("Test")
log.debug("Debug message")
log.info("Information message")
log.warning("Warning message")
log.error("Error message")
log.critical("Fatal error message")
Definition: SALOME_Logger_Server.hxx:61
This class formats and displays log messages in Salome environment. It
inherits :class:`Logger<logging.Logger>` class defined in :mod:`logging`
module from Python library, so all methods from :class:`logging.Logger`
LEVEL    [keyword] : Message
where `LEVEL` is the level of the message (`DEBUG`, `INFO`, etc.),
`keyword` is the name of the logger, and `Message` is the message to log.
When creating a new Logger object, the parameter `keyword` defines the
name of the logger, `level` defines the logging level (default is
:const:`logging.DEBUG` if KERNEL module is configured with --enable-debug
option or :const:`logging.WARNING` otherwise), and `color` defines the color
only when displayed on color-capable ASCII terminals). See module
:mod:`salome.kernel.termcolor` for the color constants.
can also be recorded in a file (see method :meth:`setLogFile`). For now,
A source filename `sourceFileName` can be defined. If this argument is
specified, then the `keyword` is modified to the basename of the `sourceFileName`
Basic usage::
◆ __init__()
def KERNEL_PY.kernel.logger.Logger.__init__ (   self,
  keyword = "KEY",
  level = salome.kernel.logconfig.loggingLevel,
  color = None,
  sourceFileName = None
◆ closeLogFile()
def KERNEL_PY.kernel.logger.Logger.closeLogFile (   self)
◆ hideDebug()
def KERNEL_PY.kernel.logger.Logger.hideDebug (   self)
Hide DEBUG level messages (equivalent to ``setLevel(logging.INFO)``).
◆ setColor()
def KERNEL_PY.kernel.logger.Logger.setColor (   self,
  color
If color is None, the default color will be used.
Set the color of log messages on color-capable terminals. If `color`
is :const:`None`, the default color will be used.
References logger.Logger._baseFormatString, KERNEL_PY.kernel.logger.Logger._baseFormatString, logger.Logger._baseFormatter, KERNEL_PY.kernel.logger.Logger._baseFormatter, logger.Logger._stdoutHandler, KERNEL_PY.kernel.logger.Logger._stdoutHandler, logger.Logger._stdoutStream, KERNEL_PY.kernel.logger.Logger._stdoutStream, termcolor.canDisplayColor(), and termcolor.getControlSequence().
◆ setLogFile()
def KERNEL_PY.kernel.logger.Logger.setLogFile (   self,
  logFilename
standard output).
References logger.Logger._baseFormatter, KERNEL_PY.kernel.logger.Logger._baseFormatter, logger.Logger._fileHandler, KERNEL_PY.kernel.logger.Logger._fileHandler, logger.Logger.closeLogFile(), and KERNEL_PY.kernel.logger.Logger.closeLogFile().
◆ showDebug()
def KERNEL_PY.kernel.logger.Logger.showDebug (   self)
``setLevel(logging.DEBUG)``).
◆ _baseFormatString
◆ _baseFormatter
◆ _fileHandler
◆ _stdoutHandler
◆ _stdoutStream
