data_short_port_uses.hxx
23// File : data_short_port_uses.hxx
24// Author : André RIBES (EDF)
25// Module : KERNEL
26//
27#ifndef _DATA_SHORT_PORT_USES_HXX_
28#define _DATA_SHORT_PORT_USES_HXX_
30#include "uses_port.hxx"
31#include "SALOME_Ports.hh"
32
38 public virtual uses_port
39{
40 public :
42 virtual ~data_short_port_uses();
43
50 virtual const char * get_repository_id();
51
58 virtual void put(CORBA::Short data);
59
67 virtual void uses_port_changed(Engines::DSC::uses_port * new_uses_port,
68 const Engines::DSC::Message /*message*/);
69
70 private :
72};
73
74#endif
75
This class a port that sends a CORBA short with the basic port policy.
Definition: data_short_port_uses.hxx:39
Definition: data_short_port_uses.cxx:30
Engines::DSC::uses_port * _my_ports
Definition: data_short_port_uses.hxx:71
Definition: data_short_port_uses.cxx:34
This method is used by the component to get port's CORBA repository id.
Definition: data_short_port_uses.cxx:37
This method is used by the component to send a short value to all the provides ports connected.
Definition: data_short_port_uses.cxx:42
virtual void uses_port_changed(Engines::DSC::uses_port *new_uses_port, const Engines::DSC::Message)
This method is a callback for be aware of modification of the port's connections.
Definition: data_short_port_uses.cxx:58
This class implements a DSC_User uses C++ port.
Definition: uses_port.hxx:44
Message
This enumeration is used when the connection of a port (uses or provides) is changed.
Definition: DSC_Engines.idl:79
sequence< Ports::Port > uses_port
a uses port
Definition: DSC_Engines.idl:73
