data_short_port_uses Class Reference
This class a port that sends a CORBA short with the basic port policy. More...
#include <data_short_port_uses.hxx>
Inheritance diagram for data_short_port_uses:
 data_short_port_uses ()
virtual ~data_short_port_uses ()
virtual const char * get_repository_id ()
 This method is used by the component to get port's CORBA repository id. More...
virtual void put (CORBA::Short data)
 This method is used by the component to send a short value to all the provides ports connected. More...
virtual void uses_port_changed (Engines::DSC::uses_port *new_uses_port, const Engines::DSC::Message)
 This method is a callback for be aware of modification of the port's connections. More...
virtual Ports::PortProperties_ptr get_port_properties ()
 This is used to get the property object of the port. More...
PortProperties_i * default_properties
Engines::DSC::uses_port * _my_ports
◆ data_short_port_uses()
data_short_port_uses::data_short_port_uses ( )
References _my_ports.
◆ ~data_short_port_uses()
data_short_port_uses::~data_short_port_uses ( )
◆ get_port_properties()
Ports::PortProperties_ptr base_port::get_port_properties ( )
property's CORBA reference.
References base_port::default_properties.
◆ get_repository_id()
const char * data_short_port_uses::get_repository_id ( )
Implements uses_port.
◆ put()
void data_short_port_uses::put ( CORBA::Short  data)
datathe short sended.
References _my_ports, and salome_instance::port.
◆ uses_port_changed()
void data_short_port_uses::uses_port_changed ( Engines::DSC::uses_port *  new_uses_port,
new_uses_portthe new uses port's sequence.
messagemessage associated to the modification.
◆ _my_ports
Engines::DSC::uses_port* data_short_port_uses::_my_ports
◆ default_properties
PortProperties_i* base_port::default_properties
