Collaboration diagram for pyscript_utils:
def pyscript_utils.create_input_dict (deterministic_dict, parametric_input)
 This function returns a dictionary containing the input values to be used in the computation code. More...
def pyscript_utils.create_normal_parametric_output (output_dict, parametric_input)
 This function returns a dictionary describing the output of the computation code in parametric studies. More...
def pyscript_utils.create_error_parametric_output (error_message)
 This function returns a dictionary describing the output of the computation code in parametric studies in case of error. More...
def KERNEL_PY.kernel.parametric.pyscript_utils.create_input_dict (deterministic_dict, parametric_input)
def KERNEL_PY.kernel.parametric.pyscript_utils.create_normal_parametric_output (output_dict, parametric_input)
def KERNEL_PY.kernel.parametric.pyscript_utils.create_error_parametric_output (error_message)
This module provides utility functions for the computation codes intended for use in parametric studies. The computation codes must be implemented as a Python script or function to use these functions. If the computation code is implemented as a SALOME component, use module salome.kernel.parametric.compo_utils instead.
◆ create_error_parametric_output() [1/2]
def pyscript_utils.create_error_parametric_output (   error_message)
error_message(string) the error message.
a dictionary describing the error.
◆ create_error_parametric_output() [2/2]
def KERNEL_PY.kernel.parametric.pyscript_utils.create_error_parametric_output (   error_message)
:type  error_message: string
:param error_message: the error message.
:return: a dictionary describing the error.
◆ create_input_dict() [1/2]
def pyscript_utils.create_input_dict (   deterministic_dict,
  parametric_input
deterministic_dict(dict) dictionary containing the fixed values (i.e. non-parametric). This dictionary can be empty if all variables are parametric.
parametric_input(dict) dictionary containing the description and values of the parametric variables.
a dictionary containing the input values for the computation code.
◆ create_input_dict() [2/2]
def KERNEL_PY.kernel.parametric.pyscript_utils.create_input_dict (   deterministic_dict,
  parametric_input
:type  deterministic_dict: dict
:param deterministic_dict: dictionary containing the fixed values (i.e.
:type  parametric_input: dict
:param parametric_input: dictionary containing the description and values
:return: a dictionary containing the input values for the computation code.
◆ create_normal_parametric_output() [1/2]
def pyscript_utils.create_normal_parametric_output (   output_dict,
  parametric_input
output_dict(dict) dictionary containing the output values of the computation code (the keys are the variable names, the values are the variable values).
a dictionary containing the representation of the output of the computation code.
◆ create_normal_parametric_output() [2/2]
def KERNEL_PY.kernel.parametric.pyscript_utils.create_normal_parametric_output (   output_dict,
  parametric_input
:type  output_dict: dict
:param output_dict: dictionary containing the output values of the
:return: a dictionary containing the representation of the output of the
         computation code.
