SALOME_TestModuleCatalog::AddComponent Interface Reference
import"SALOME_TestModuleCatalog.idl";
Inheritance diagram for SALOME_TestModuleCatalog::AddComponent:
Adder Addition ()
double Add (in double x, in double y, out double z)
long Sigma (in long n)
double LastResult ()
void ping ()
 Determines whether the server has already been loaded or not. More...
boolean isSSLMode () raises (SALOME::SALOME_Exception)
void destroy ()
 Remove component instance from container. More...
Container GetContainerRef ()
 Returns the container that the Component refers to. More...
void setProperties (in FieldsDict dico)
 Set component instance properties. More...
FieldsDict getProperties ()
 Get component instance properties. More...
void SetOption (in string optionName, in string value)
 Set an option value. More...
string GetOption (in string optionName)
 Return an option value. More...
void Names (in string aGraphName, in string aNodeName)
 Set name of a node in a graph (for SUPERVISOR use) More...
boolean Kill_impl ()
 Kill the component (if you can) More...
boolean Stop_impl ()
 Stop the component (if you can) More...
boolean Suspend_impl ()
 Suspend the component. More...
boolean Resume_impl ()
 Resume the component. More...
long CpuUsed_impl ()
 Get the cpu used. More...
TMPFile DumpPython (in boolean isPublished, in boolean isMultiFile, out boolean isValidScript)
 Get a python dump. More...
Engines::Salome_file getInputFileToService (in string service_name, in string Salome_file_name) raises (SALOME::SALOME_Exception)
 Returns a CORBA Ref of a input Salome_file managed by a service. More...
void checkInputFilesToService (in string service_name) raises (SALOME::SALOME_Exception)
 Check service input files (transfer them if needed) More...
Engines::Salome_file setInputFileToService (in string service_name, in string Salome_file_name) raises (SALOME::SALOME_Exception)
 This method adds a input Salome_file to a service of the component. More...
Engines::Salome_file getOutputFileToService (in string service_name, in string Salome_file_name) raises (SALOME::SALOME_Exception)
 Returns a CORBA Ref of a output Salome_file managed by a service. More...
void checkOutputFilesToService (in string service_name) raises (SALOME::SALOME_Exception)
 Check service output files (transfer them if needed) More...
Engines::Salome_file setOutputFileToService (in string service_name, in string Salome_file_name) raises (SALOME::SALOME_Exception)
 This method adds an output Salome_file to a service of the component. More...
boolean hasObjectInfo ()
 Indicate if the component instance provides custom information about its objects. More...
string getObjectInfo (in string entry)
 Get custom information about the given object. More...
string getVersion ()
 Get version of the component. More...
Data Fields
readonly attribute string instanceName
 The name of the instance of the Component. More...
readonly attribute string interfaceName
 The name of the interface of the Component. More...
◆ Add()
double SALOME_TestModuleCatalog::AddComponent::Add ( in double  x,
in double  y,
out double  z
◆ Addition()
Adder SALOME_TestModuleCatalog::AddComponent::Addition ( )
◆ checkInputFilesToService()
void Engines::EngineComponent::checkInputFilesToService ( in string  service_name)
This method is used before the activation of the service. It calls recvFiles() on all the input Salome_file files of the service.
Before each recvFiles(), it uses the callback method named configureSalome_file. This method allows the user to configure the files managed by the Salome_file.
By default, there is no files managed when a Salome_file is created, but the supervisor set some files managed by the Salome_file from the information contained into the schema file.
service_nameservice's name.
Exceptions
containsinformation about files that are not in a good state.
◆ checkOutputFilesToService()
void Engines::EngineComponent::checkOutputFilesToService ( in string  service_name)
This method is used at the end of the service. It calls recvFiles() on all the output Salome_file files of the service.
Exceptions
◆ CpuUsed_impl()
long Engines::EngineComponent::CpuUsed_impl ( )
◆ destroy()
void Engines::EngineComponent::destroy ( )
Deactivates the Component. – TO BE USED BY CONTAINER ONLY (Container housekeeping) – use remove_impl from Container instead !
◆ DumpPython()
TMPFile Engines::EngineComponent::DumpPython ( in boolean  isPublished,
Get a python dump.
Returns a python script, which is being played back reproduces the data model of component
◆ GetContainerRef()
Container Engines::EngineComponent::GetContainerRef ( )
◆ getInputFileToService()
Engines::Salome_file Engines::EngineComponent::getInputFileToService ( in string  service_name,
file_namename of the requested file.
CORBA Ref of the requested file.
Exceptions
containsinformation of what if the component cannot sends the file's reference.
◆ getObjectInfo()
string Engines::EngineComponent::getObjectInfo ( in string  entry)
This method is used to get the custom information about the given object. Should be redefined in the certain component in case of this component provides such information. It is worth using this method only if hasObjectInfo() method returns true.
entryobject's entry.
an information about the given object.
◆ GetOption()
string Engines::EngineComponent::GetOption ( in string  optionName)
This method is to get value of an option specific to a certain EngineComponent.
◆ getOutputFileToService()
Engines::Salome_file Engines::EngineComponent::getOutputFileToService ( in string  service_name,
Exceptions
◆ getProperties()
FieldsDict Engines::EngineComponent::getProperties ( )
returns a previously stored map (key=string,value=any) as a sequence. See setProperties(in FieldsDict dico).
◆ getVersion()
string Engines::EngineComponent::getVersion ( )
This method is supposed to be implemented in all derived classes; default implementation returns "unknown" string that means that no version information about the component is available.
The version of the component is stored to the study, as a part of general persistence mechanism; once stored, version information in the study cannot be changed.
string containing component's version, e.g. "1.0"
Referenced by SALOME_DriverPy.SALOME_DriverPy_i::Version().
◆ hasObjectInfo()
boolean Engines::EngineComponent::hasObjectInfo ( )
Returns true if the component provides custom information about its objects, false otherwise. Should be redefined in the certain component to return true in case of this component provides such information.
◆ isSSLMode()
boolean Engines::EngineComponent::isSSLMode ( )
◆ Kill_impl()
boolean Engines::EngineComponent::Kill_impl ( )
Returns True if the Component has been killed.
◆ LastResult()
double SALOME_TestModuleCatalog::AddComponent::LastResult ( )
◆ Names()
void Engines::EngineComponent::Names ( in string  aGraphName,
in string  aNodeName
This method is used by the SUPERVISOR component. It sets the names of the graph and of the node.
aGraphNameName of graph
aNodeNameName of node
◆ ping()
void Engines::EngineComponent::ping ( )
◆ Resume_impl()
boolean Engines::EngineComponent::Resume_impl ( )
Returns True if the activity of the Component has been resumed.
◆ setInputFileToService()
Engines::Salome_file Engines::EngineComponent::setInputFileToService ( in string  service_name,
Salome_file_namename of the Salome_file
a reference of the Salome_file
Exceptions
raisesan exception if there is already a Salome_file with this name for the service.
◆ SetOption()
void Engines::EngineComponent::SetOption ( in string  optionName,
in string  value
This method is to set an option specific to a certain EngineComponent.
◆ setOutputFileToService()
Engines::Salome_file Engines::EngineComponent::setOutputFileToService ( in string  service_name,
Exceptions
◆ setProperties()
void Engines::EngineComponent::setProperties ( in FieldsDict  dico)
Gives a sequence of (key=string,value=any) to the component. Base class component stores the sequence in a map. The map is cleared before. This map is for use by derived classes.
◆ Sigma()
long SALOME_TestModuleCatalog::AddComponent::Sigma ( in long  n)
◆ Stop_impl()
boolean Engines::EngineComponent::Stop_impl ( )
Returns True if the activity of the Component has been stopped. (It's action can't be resumed)
◆ Suspend_impl()
boolean Engines::EngineComponent::Suspend_impl ( )
Returns True if the activity of the Component has been suspended. (It's action can be resumed)
◆ instanceName
readonly attribute string Engines::EngineComponent::instanceName
◆ interfaceName
readonly attribute string Engines::EngineComponent::interfaceName
