Data Structures | |
| class | salome_test_driver.TimeoutException |
Namespaces | |
| namespace | salome_test_driver |
Functions | |
| def | salome_test_driver.runTest (command) |
| def | salome_test_driver.processResult (res, out, err) |
| def | salome_test_driver.installHook (hook=None) |
| def | salome_test_driver.timeoutHandler (signum, frame) |
Variables | |
| salome_test_driver.timeout_delay = sys.argv[1] | |
| salome_test_driver.args = sys.argv[2:] | |
| salome_test_driver.index = args.index('--hook') | |
| salome_test_driver.hook = args.pop(index) | |
| salome_test_driver._ | |
| salome_test_driver.ext | |
| list | salome_test_driver.test_and_args = [sys.executable] + args |
| salome_test_driver.timeout_sec = abs(int(timeout_delay)-10) | |
| salome_test_driver.timer = Timer(timeout_sec, timeoutHandler) | |
| int | salome_test_driver.res = 1 |
| salome_test_driver.salome_instance = SalomeInstance.start(shutdown_servers=True) | |
| salome_test_driver.port = salome_instance.get_port() | |
| salome_test_driver.out | |
| salome_test_driver.err | |
