__init__.py File Reference
class  KERNEL_PY.SessionContextManager
class  KERNEL_PY.LogManagerLaunchMonitoringFileCtxMgr
class  KERNEL_PY.Barrier
class  KERNEL_PY.LockGuardCM
class  KERNEL_PY.ContainerLauncherCM
namespace  KERNEL_PY
namespace  salome
 Module salome gives access to Salome resources.
def KERNEL_PY.extend_path (pname)
def KERNEL_PY.standalone ()
def KERNEL_PY.withServers ()
def KERNEL_PY.salome_init (path=None, embedded=False, iorfakensfile=None, forced=False)
def KERNEL_PY.salome_init_without_session_common (path=None, embedded=False)
def KERNEL_PY.salome_init_without_session (path=None, embedded=False, iorfakensfile=None)
def KERNEL_PY.salome_init_without_session_attached (path=None, embedded=False)
def KERNEL_PY.salome_init_with_session (path=None, embedded=False)
def KERNEL_PY.salome_close ()
def KERNEL_PY.salome_NS ()
def KERNEL_PY.salome_walk_on_containers (ns, root)
def KERNEL_PY.salome_shutdown_containers_with_session ()
def KERNEL_PY.retrieve_containers_in_ns ()
def KERNEL_PY.get_all_containers ()
def KERNEL_PY.salome_shutdown_containers_without_session ()
def KERNEL_PY.salome_shutdown_containers ()
def KERNEL_PY.ContainerManagerSetOverrideEnvForContainersSimple (self, env)
def KERNEL_PY.LogManagerNaiveFetch (self)
def KERNEL_PY.LogManagerFetch (self, clearMemory=False)
def KERNEL_PY.LogManagerDumpInFile (self, fileName, clearMemory=False)
def KERNEL_PY.LogManagerLaunchMonitoringDumpFile (self, intervalInMs, outFileName)
def KERNEL_PY.LogManagerDumpIORInFile (self, iorFileName)
def KERNEL_PY.LogManagerLoadFromFile (fileName)
def KERNEL_PY.LogManagerLoadFromIORFile (iorFile)
def KERNEL_PY.LogManagerFinalFetchBeforeDying (self)
def KERNEL_PY.LogManagerGetLatestMonitoringDumpFile (self)
Variables
string KERNEL_PY.ROOT_PYTHONPACKAGE_NAME = "salome"
string KERNEL_PY.MATCH_ENDING_PATTERN = "site-packages" + os.path.sep + "salome"
 KERNEL_PY.flags = None
 KERNEL_PY.orb
 KERNEL_PY.lcc
 KERNEL_PY.naming_service
 KERNEL_PY.cm
 KERNEL_PY.sg
 KERNEL_PY.esm
 KERNEL_PY.dsm
 KERNEL_PY.logm
 KERNEL_PY.modulcat
 KERNEL_PY.rm
 KERNEL_PY.lm
 KERNEL_PY.myStudy
 KERNEL_PY.myStudyName
bool KERNEL_PY.salome_initial = True
string KERNEL_PY.CM_NAME_IN_NS = "/ContainerManager"
string KERNEL_PY.RM_NAME_IN_NS = "/ResourcesManager"
string KERNEL_PY.DSM_NAME_IN_NS = "/DataServerManager"
string KERNEL_PY.ESM_NAME_IN_NS = "/ExternalServers"
string KERNEL_PY.LOGM_NAME_IN_NS = "/LogManager"
string KERNEL_PY.LAUNCHER_NAME_IN_NS = "/SalomeLauncher"
 KERNEL_PY.__all__ = dir()
