GeomAPI_Angle2d.h
20#ifndef GeomAPI_Angle2d_H_
21#define GeomAPI_Angle2d_H_
23#include <GeomAPI_Interface.h>
24
25class GeomAPI_Lin2d;
26class GeomAPI_Pnt2d;
27
32{
33public:
35 GEOMAPI_EXPORT
36 GeomAPI_Angle2d(const std::shared_ptr<GeomAPI_Pnt2d>& theStartLine1,
37 const std::shared_ptr<GeomAPI_Pnt2d>& theEndLine1,
38 const std::shared_ptr<GeomAPI_Pnt2d>& theStartLine2,
39 const std::shared_ptr<GeomAPI_Pnt2d>& theEndLine2);
41 GEOMAPI_EXPORT
42 GeomAPI_Angle2d(const std::shared_ptr<GeomAPI_Lin2d>& theLine1, bool theReversed1,
43 const std::shared_ptr<GeomAPI_Lin2d>& theLine2, bool theReversed2);
45 GEOMAPI_EXPORT
46 GeomAPI_Angle2d(const std::shared_ptr<GeomAPI_Pnt2d>& theCenter,
47 const std::shared_ptr<GeomAPI_Pnt2d>& thePoint1,
48 const std::shared_ptr<GeomAPI_Pnt2d>& thePoint2);
49
51 GEOMAPI_EXPORT std::shared_ptr<GeomAPI_Pnt2d> center();
53 GEOMAPI_EXPORT std::shared_ptr<GeomAPI_Pnt2d> firstPoint();
55 GEOMAPI_EXPORT std::shared_ptr<GeomAPI_Pnt2d> secondPoint();
56
58 GEOMAPI_EXPORT double angleDegree();
60 GEOMAPI_EXPORT double angleRadian();
61
65 GEOMAPI_EXPORT bool isReversed(int theIndex);
66};
67
68#endif
69
Build an angle in plane.
Definition: GeomAPI_Angle2d.h:32
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > firstPoint()
Returns point on the first edge.
Definition: GeomAPI_Angle2d.cpp:125
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > center()
Returns central point of the angle.
Definition: GeomAPI_Angle2d.cpp:119
Returns value of the angle in degrees.
Definition: GeomAPI_Angle2d.cpp:137
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > secondPoint()
Returns point on the second edge.
Definition: GeomAPI_Angle2d.cpp:131
Returns true if the line is reversed during angle calculation.
Definition: GeomAPI_Angle2d.cpp:150
Returns value of the angle in radians.
Definition: GeomAPI_Angle2d.cpp:142
GEOMAPI_EXPORT GeomAPI_Angle2d(const std::shared_ptr< GeomAPI_Pnt2d > &theStartLine1, const std::shared_ptr< GeomAPI_Pnt2d > &theEndLine1, const std::shared_ptr< GeomAPI_Pnt2d > &theStartLine2, const std::shared_ptr< GeomAPI_Pnt2d > &theEndLine2)
Creation of an angle defined by two lines' start, end points.
Definition: GeomAPI_Angle2d.cpp:98
Line in 2D.
Definition: GeomAPI_Lin2d.h:35
