GeomAPI_Angle2d Class Reference
Build an angle in plane. More...
#include <GeomAPI_Angle2d.h>
Inheritance diagram for GeomAPI_Angle2d:
GEOMAPI_EXPORT GeomAPI_Angle2d (const std::shared_ptr< GeomAPI_Pnt2d > &theStartLine1, const std::shared_ptr< GeomAPI_Pnt2d > &theEndLine1, const std::shared_ptr< GeomAPI_Pnt2d > &theStartLine2, const std::shared_ptr< GeomAPI_Pnt2d > &theEndLine2)
 Creation of an angle defined by two lines' start, end points. More...
GEOMAPI_EXPORT GeomAPI_Angle2d (const std::shared_ptr< GeomAPI_Lin2d > &theLine1, bool theReversed1, const std::shared_ptr< GeomAPI_Lin2d > &theLine2, bool theReversed2)
 Creation of an angle defined by two lines taking into account their orientation. More...
GEOMAPI_EXPORT GeomAPI_Angle2d (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint1, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint2)
 Creation of an angle defined by three points. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > center ()
 Returns central point of the angle. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > firstPoint ()
 Returns point on the first edge. More...
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > secondPoint ()
 Returns point on the second edge. More...
GEOMAPI_EXPORT double angleDegree ()
 Returns value of the angle in degrees. More...
GEOMAPI_EXPORT double angleRadian ()
 Returns value of the angle in radians. More...
GEOMAPI_EXPORT bool isReversed (int theIndex)
 Returns true if the line is reversed during angle calculation. More...
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
◆ GeomAPI_Angle2d() [1/3]
GeomAPI_Angle2d::GeomAPI_Angle2d ( const std::shared_ptr< GeomAPI_Pnt2d > &  theStartLine1,
const std::shared_ptr< GeomAPI_Pnt2d > &  theEndLine1,
const std::shared_ptr< GeomAPI_Pnt2d > &  theStartLine2,
const std::shared_ptr< GeomAPI_Pnt2d > &  theEndLine2
◆ GeomAPI_Angle2d() [2/3]
GeomAPI_Angle2d::GeomAPI_Angle2d ( const std::shared_ptr< GeomAPI_Lin2d > &  theLine1,
bool  theReversed1,
const std::shared_ptr< GeomAPI_Lin2d > &  theLine2,
bool  theReversed2
◆ GeomAPI_Angle2d() [3/3]
GeomAPI_Angle2d::GeomAPI_Angle2d ( const std::shared_ptr< GeomAPI_Pnt2d > &  theCenter,
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint1,
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint2
◆ center()
std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Angle2d::center ( )
◆ firstPoint()
std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Angle2d::firstPoint ( )
◆ secondPoint()
std::shared_ptr< GeomAPI_Pnt2d > GeomAPI_Angle2d::secondPoint ( )
◆ angleDegree()
double GeomAPI_Angle2d::angleDegree ( )
◆ angleRadian()
double GeomAPI_Angle2d::angleRadian ( )
◆ isReversed()
bool GeomAPI_Angle2d::isReversed ( int  theIndex)
If theIndex = 0, the result corresponds to the first line, if theIndex = 1, the to the second line
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
