GeomAPI_Lin.h
20#ifndef GeomAPI_Lin_H_
21#define GeomAPI_Lin_H_
23#include <GeomAPI_Interface.h>
24#include <memory>
26class GeomAPI_Dir;
27class GeomAPI_Pnt;
28
35{
36 public:
38 GEOMAPI_EXPORT
39 GeomAPI_Lin(const double theStartX, const double theStartY, const double theStartZ,
40 const double theEndX, const double theEndY, const double theEndZ);
42 GEOMAPI_EXPORT
43 GeomAPI_Lin(const std::shared_ptr<GeomAPI_Pnt>& theStart,
44 const std::shared_ptr<GeomAPI_Pnt>& theEnd);
46 GEOMAPI_EXPORT
47 GeomAPI_Lin(const std::shared_ptr<GeomAPI_Pnt>& theOrigin,
48 const std::shared_ptr<GeomAPI_Dir>& theDirection);
49
51 GEOMAPI_EXPORT
52 std::shared_ptr<GeomAPI_Pnt> location();
53
55 GEOMAPI_EXPORT
56 std::shared_ptr<GeomAPI_Dir> direction();
57
59 GEOMAPI_EXPORT
60 double distance(const std::shared_ptr<GeomAPI_Pnt>& thePoint) const;
62 GEOMAPI_EXPORT
63 const std::shared_ptr<GeomAPI_Pnt> intersect(
64 const std::shared_ptr<GeomAPI_Lin>& theLine) const;
66 GEOMAPI_EXPORT
67 const std::shared_ptr<GeomAPI_Pnt> project(
68 const std::shared_ptr<GeomAPI_Pnt>& thePoint) const;
69
71 GEOMAPI_EXPORT
72 double projParam(const std::shared_ptr<GeomAPI_Pnt>& thePoint) const;
73
77 GEOMAPI_EXPORT
78 bool contains(const std::shared_ptr<GeomAPI_Pnt> thePoint,
79 const double theLinearTolerance = 1.e-7) const;
80
82 GEOMAPI_EXPORT
83 bool isParallel(const std::shared_ptr<GeomAPI_Lin> theLin) const;
84
86 GEOMAPI_EXPORT
87 bool isCoplanar(const std::shared_ptr<GeomAPI_Lin> theLin) const;
88};
89
91typedef std::shared_ptr<GeomAPI_Lin> GeomLinePtr;
92
93#endif
94
3D direction defined by three normalized coordinates
Definition: GeomAPI_Dir.h:34
Line in 3D.
Definition: GeomAPI_Lin.h:35
GEOMAPI_EXPORT bool isParallel(const std::shared_ptr< GeomAPI_Lin > theLin) const
Definition: GeomAPI_Lin.cpp:138
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt > project(const std::shared_ptr< GeomAPI_Pnt > &thePoint) const
Project point on line.
Definition: GeomAPI_Lin.cpp:118
GEOMAPI_EXPORT bool isCoplanar(const std::shared_ptr< GeomAPI_Lin > theLin) const
Definition: GeomAPI_Lin.cpp:144
GEOMAPI_EXPORT GeomAPI_Lin(const double theStartX, const double theStartY, const double theStartZ, const double theEndX, const double theEndY, const double theEndZ)
Creation of line defined by coordinates of start and end points.
Definition: GeomAPI_Lin.cpp:46
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_Pnt > intersect(const std::shared_ptr< GeomAPI_Lin > &theLine) const
Intersection of two lines.
Definition: GeomAPI_Lin.cpp:85
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Dir > direction()
Returns a line direction.
Definition: GeomAPI_Lin.cpp:74
GEOMAPI_EXPORT double projParam(const std::shared_ptr< GeomAPI_Pnt > &thePoint) const
Returns parameter of the point projection.
Definition: GeomAPI_Lin.cpp:109
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > location()
Returns point on the line (first point)
Definition: GeomAPI_Lin.cpp:68
GEOMAPI_EXPORT bool contains(const std::shared_ptr< GeomAPI_Pnt > thePoint, const double theLinearTolerance=1.e-7) const
Definition: GeomAPI_Lin.cpp:128
GEOMAPI_EXPORT double distance(const std::shared_ptr< GeomAPI_Pnt > &thePoint) const
Distance between two points.
Definition: GeomAPI_Lin.cpp:80
Definition: GeomAPI_Pnt.h:38
