GeomAPI_Pnt.h
20#ifndef GeomAPI_Pnt_H_
21#define GeomAPI_Pnt_H_
23#include <GeomAPI_Interface.h>
24#include <memory>
26class GeomAPI_Ax1;
27class GeomAPI_XYZ;
28class GeomAPI_Pnt2d;
29class GeomAPI_Dir;
30class GeomAPI_Pln;
31
38{
39 public:
41 GEOMAPI_EXPORT
42 GeomAPI_Pnt(const double theX, const double theY, const double theZ);
44 GEOMAPI_EXPORT
45 GeomAPI_Pnt(const std::shared_ptr<GeomAPI_XYZ>& theCoords);
46
48 GEOMAPI_EXPORT
49 double x() const;
51 GEOMAPI_EXPORT
52 double y() const;
54 GEOMAPI_EXPORT
55 double z() const;
56
58 GEOMAPI_EXPORT
59 void setX(const double theX);
61 GEOMAPI_EXPORT
62 void setY(const double theY);
64 GEOMAPI_EXPORT
65 void setZ(const double theZ);
66
68 GEOMAPI_EXPORT
69 const std::shared_ptr<GeomAPI_XYZ> xyz();
70
72 GEOMAPI_EXPORT
73 double distance(const std::shared_ptr<GeomAPI_Pnt>& theOther) const;
74
76 GEOMAPI_EXPORT
77 bool isEqual(const std::shared_ptr<GeomAPI_Pnt>& theOther) const;
78
83 GEOMAPI_EXPORT
84 bool isLess(const std::shared_ptr<GeomAPI_Pnt>& theOther,
85 const double theTolerance = 1.e-7) const;
86
88 GEOMAPI_EXPORT
89 std::shared_ptr<GeomAPI_Pnt2d> to2D(const std::shared_ptr<GeomAPI_Pnt>& theOrigin,
90 const std::shared_ptr<GeomAPI_Dir>& theDirX,
91 const std::shared_ptr<GeomAPI_Dir>& theDirY);
92
94 GEOMAPI_EXPORT
95 std::shared_ptr<GeomAPI_Pnt2d> to2D(const std::shared_ptr<GeomAPI_Pln>& thePln) const;
96
98 GEOMAPI_EXPORT
99 void translate(const std::shared_ptr<GeomAPI_Dir>& theDir, double theDist);
100
102 GEOMAPI_EXPORT void rotate(const std::shared_ptr<GeomAPI_Ax1>& theAxis, double theAngle);
103};
104
106typedef std::shared_ptr<GeomAPI_Pnt> GeomPointPtr;
107
108#endif
The class represents an axis in 3D space.
Definition: GeomAPI_Ax1.h:31
3D direction defined by three normalized coordinates
Definition: GeomAPI_Dir.h:34
\Plane in 3D place, defined by normal, center and x-direction.
Definition: GeomAPI_Pln.h:38
Definition: GeomAPI_Pnt.h:38
GEOMAPI_EXPORT void setY(const double theY)
sets Y coordinate
Definition: GeomAPI_Pnt.cpp:63
GEOMAPI_EXPORT double z() const
returns Z coordinate
Definition: GeomAPI_Pnt.cpp:53
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_XYZ > xyz()
returns coordinates of the point
Definition: GeomAPI_Pnt.cpp:73
GEOMAPI_EXPORT bool isLess(const std::shared_ptr< GeomAPI_Pnt > &theOther, const double theTolerance=1.e-7) const
Returns true, if the current point is less than theOther.
Definition: GeomAPI_Pnt.cpp:88
GEOMAPI_EXPORT void setZ(const double theZ)
sets Z coordinate
Definition: GeomAPI_Pnt.cpp:68
GEOMAPI_EXPORT void rotate(const std::shared_ptr< GeomAPI_Ax1 > &theAxis, double theAngle)
Rotates the point along axis for the given angle (in degrees)
Definition: GeomAPI_Pnt.cpp:133
GEOMAPI_EXPORT void setX(const double theX)
sets X coordinate
Definition: GeomAPI_Pnt.cpp:58
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt2d > to2D(const std::shared_ptr< GeomAPI_Pnt > &theOrigin, const std::shared_ptr< GeomAPI_Dir > &theDirX, const std::shared_ptr< GeomAPI_Dir > &theDirY)
Projects a point to the plane defined by the origin and 2 axes vectors in this plane.
Definition: GeomAPI_Pnt.cpp:103
GEOMAPI_EXPORT double y() const
returns Y coordinate
Definition: GeomAPI_Pnt.cpp:48
GEOMAPI_EXPORT bool isEqual(const std::shared_ptr< GeomAPI_Pnt > &theOther) const
Returns whether the distance between two points is less then precision confusion.
Definition: GeomAPI_Pnt.cpp:83
GEOMAPI_EXPORT double x() const
returns X coordinate
Definition: GeomAPI_Pnt.cpp:43
GEOMAPI_EXPORT GeomAPI_Pnt(const double theX, const double theY, const double theZ)
Creation of point by coordinates.
Definition: GeomAPI_Pnt.cpp:33
GEOMAPI_EXPORT void translate(const std::shared_ptr< GeomAPI_Dir > &theDir, double theDist)
Translates the point along direction theDir on distance theDist.
Definition: GeomAPI_Pnt.cpp:115
GEOMAPI_EXPORT double distance(const std::shared_ptr< GeomAPI_Pnt > &theOther) const
Distance between two points.
Definition: GeomAPI_Pnt.cpp:78
3 coordinates: they may represent vector or point or something else
Definition: GeomAPI_XYZ.h:32
