GeomAPI_Shape.h
20#ifndef GeomAPI_Shape_H_
21#define GeomAPI_Shape_H_
23#include "GeomAPI_Dir.h"
24
25#include <GeomAPI_Interface.h>
26#include <memory>
27#include <list>
28#include <string>
29class GeomAPI_Pnt;
30class GeomAPI_Vertex;
31class GeomAPI_Edge;
32class GeomAPI_Wire;
33class GeomAPI_Face;
34class GeomAPI_Shell;
35class GeomAPI_Solid;
36class GeomAPI_Trsf;
37
43{
44public:
46 enum ShapeType {
47 COMPOUND, COMPSOLID, SOLID, SHELL,
48 FACE, WIRE, EDGE, VERTEX,
49 SHAPE
50 };
51
54 FORWARD,
55 REVERSED,
56 INTERNAL,
57 EXTERNAL
58 };
59
60 public:
62 GEOMAPI_EXPORT
64
67 GEOMAPI_EXPORT std::shared_ptr<GeomAPI_Shape> emptyCopied() const;
68
70 GEOMAPI_EXPORT
71 bool isNull() const;
72
74 GEOMAPI_EXPORT
75 virtual bool isEqual(const std::shared_ptr<GeomAPI_Shape> theShape) const;
76
78 GEOMAPI_EXPORT
79 virtual bool isSame(const std::shared_ptr<GeomAPI_Shape> theShape) const;
80
82 GEOMAPI_EXPORT
83 virtual bool isSameGeometry(const std::shared_ptr<GeomAPI_Shape> theShape) const;
84
86 GEOMAPI_EXPORT
87 virtual bool isVertex() const;
88
90 GEOMAPI_EXPORT
91 virtual bool isEdge() const;
92
94 GEOMAPI_EXPORT
95 virtual bool isWire() const;
96
98 GEOMAPI_EXPORT
99 virtual bool isFace() const;
100
102 GEOMAPI_EXPORT
103 virtual bool isShell() const;
104
106 GEOMAPI_EXPORT
107 virtual bool isCompound() const;
108
110 GEOMAPI_EXPORT
111 virtual bool isCompoundOfSolids() const;
112
115 GEOMAPI_EXPORT
116 virtual bool isCollectionOfSolids() const;
117
119 GEOMAPI_EXPORT
120 virtual bool isConnectedTopology() const;
121
123 GEOMAPI_EXPORT
124 virtual bool isSolid() const;
125
127 GEOMAPI_EXPORT
128 virtual bool isCompSolid() const;
129
131 GEOMAPI_EXPORT
132 virtual bool isPlanar() const;
133
135 GEOMAPI_EXPORT
136 std::shared_ptr<GeomAPI_Vertex> vertex() const;
137
139 GEOMAPI_EXPORT
140 std::shared_ptr<GeomAPI_Edge> edge() const;
141
143 GEOMAPI_EXPORT
144 std::shared_ptr<GeomAPI_Wire> wire() const;
145
147 GEOMAPI_EXPORT
148 std::shared_ptr<GeomAPI_Face> face() const;
149
151 GEOMAPI_EXPORT
152 std::shared_ptr<GeomAPI_Shell> shell() const;
153
155 GEOMAPI_EXPORT
156 std::shared_ptr<GeomAPI_Solid> solid() const;
157
162 GEOMAPI_EXPORT
163 std::list< std::shared_ptr<GeomAPI_Shape> > subShapes(const ShapeType theSubShapeType,
164 const bool theOnlyUnique = false) const;
165
167 GEOMAPI_EXPORT
168 virtual ShapeType shapeType() const;
169
171 GEOMAPI_EXPORT static ShapeType shapeTypeByStr(std::string theType);
172
174 GEOMAPI_EXPORT
175 virtual std::string shapeTypeStr() const;
176
178 GEOMAPI_EXPORT virtual Orientation orientation() const;
179
181 GEOMAPI_EXPORT virtual void setOrientation(const Orientation theOrientation);
182
184 GEOMAPI_EXPORT virtual void reverse();
185
189 GEOMAPI_EXPORT virtual bool isSubShape(const std::shared_ptr<GeomAPI_Shape> theShape,
190 const bool theCheckOrientation = true) const;
191
194 GEOMAPI_EXPORT
195 bool computeSize(double& theXmin, double& theYmin, double& theZmin,
196 double& theXmax, double& theYmax, double& theZmax) const;
197
199 GEOMAPI_EXPORT
200 virtual std::shared_ptr<GeomAPI_Pnt> middlePoint() const;
201
203 GEOMAPI_EXPORT
204 std::string getShapeStream(const bool theWithTriangulation = true) const;
205
207 GEOMAPI_EXPORT
208 std::shared_ptr<GeomAPI_Shape> intersect(const std::shared_ptr<GeomAPI_Shape> theShape) const;
209
211 GEOMAPI_EXPORT
212 bool isIntersect(const std::shared_ptr<GeomAPI_Shape> theShape) const;
213
215 GEOMAPI_EXPORT
216 void translate(const std::shared_ptr<GeomAPI_Dir> theDir, const double theOffset);
217
219 GEOMAPI_EXPORT
220 void move(const std::shared_ptr<GeomAPI_Trsf> theTransformation);
221
223 // If shapes are of different type then it will return SHAPE type
224 GEOMAPI_EXPORT ShapeType typeOfCompoundShapes() const;
225
238 GEOMAPI_EXPORT bool isSelfIntersected(const int theLevelOfCheck = 9) const;
239
240public:
243 {
244 public:
246 GEOMAPI_EXPORT
247 bool operator ()(const std::shared_ptr<GeomAPI_Shape>& theShape1,
248 const std::shared_ptr<GeomAPI_Shape>& theShape2) const;
249 };
250
254 {
255 public:
257 GEOMAPI_EXPORT
258 bool operator ()(const std::shared_ptr<GeomAPI_Shape>& theShape1,
259 const std::shared_ptr<GeomAPI_Shape>& theShape2) const;
260 };
261
263 class Hash
264 {
265 public:
267 GEOMAPI_EXPORT
268 int operator ()(const std::shared_ptr<GeomAPI_Shape>& theShape) const;
269 };
270
272 class Equal
273 {
274 public:
276 GEOMAPI_EXPORT
277 bool operator ()(const std::shared_ptr<GeomAPI_Shape>& theShape1,
278 const std::shared_ptr<GeomAPI_Shape>& theShape2) const;
279 };
280};
281
283typedef std::list<std::shared_ptr<GeomAPI_Shape> > ListOfShape;
284
286typedef std::shared_ptr<GeomAPI_Shape> GeomShapePtr;
287
288#endif
Interface to the edge object.
Definition: GeomAPI_Edge.h:38
Interface to the face object.
Definition: GeomAPI_Face.h:36
Definition: GeomAPI_Pnt.h:38
Compare addresses of shapes with respect to orientation of shapes.
Definition: GeomAPI_Shape.h:254
GEOMAPI_EXPORT bool operator()(const std::shared_ptr< GeomAPI_Shape > &theShape1, const std::shared_ptr< GeomAPI_Shape > &theShape2) const
Return true if the address of the first shape is less than the address of the second.
Definition: GeomAPI_Shape.cpp:825
Compare addresses of shapes.
Definition: GeomAPI_Shape.h:243
Definition: GeomAPI_Shape.cpp:806
Definition: GeomAPI_Shape.h:273
Return true if the address of the shapes are equal.
Definition: GeomAPI_Shape.cpp:856
Hash code for the shape.
Definition: GeomAPI_Shape.h:264
GEOMAPI_EXPORT int operator()(const std::shared_ptr< GeomAPI_Shape > &theShape) const
Return Hash value according to the address of the shape.
Definition: GeomAPI_Shape.cpp:846
virtual GEOMAPI_EXPORT bool isSubShape(const std::shared_ptr< GeomAPI_Shape > theShape, const bool theCheckOrientation=true) const
Definition: GeomAPI_Shape.cpp:627
virtual GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Pnt > middlePoint() const
Return middle point on the shape.
Definition: GeomAPI_Shape.cpp:675
static GEOMAPI_EXPORT ShapeType shapeTypeByStr(std::string theType)
Returns the type enumeration by the string-type.
Definition: GeomAPI_Shape.cpp:529
GEOMAPI_EXPORT bool isSelfIntersected(const int theLevelOfCheck=9) const
Returns true if shape have self-intersections.
Definition: GeomAPI_Shape.cpp:790
virtual GEOMAPI_EXPORT bool isSame(const std::shared_ptr< GeomAPI_Shape > theShape) const
Returns whether the shapes are same.
Definition: GeomAPI_Shape.cpp:96
ShapeType
Shape type enum.
Definition: GeomAPI_Shape.h:46
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shape > emptyCopied() const
Definition: GeomAPI_Shape.cpp:72
GEOMAPI_EXPORT std::string getShapeStream(const bool theWithTriangulation=true) const
Returns the shape as BRep stream.
Definition: GeomAPI_Shape.cpp:711
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Face > face() const
Returns face or empty shape.
Definition: GeomAPI_Shape.cpp:415
virtual GEOMAPI_EXPORT bool isPlanar() const
Returns whether the shape is planar.
Definition: GeomAPI_Shape.cpp:293
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Solid > solid() const
Returns solid or empty shape.
Definition: GeomAPI_Shape.cpp:437
virtual GEOMAPI_EXPORT bool isEdge() const
Returns whether the shape is an edge.
Definition: GeomAPI_Shape.cpp:122
virtual GEOMAPI_EXPORT bool isConnectedTopology() const
Returns whether the shape is a compound where all elements are topologically connected.
Definition: GeomAPI_Shape.cpp:225
virtual GEOMAPI_EXPORT std::string shapeTypeStr() const
Definition: GeomAPI_Shape.cpp:552
virtual GEOMAPI_EXPORT ShapeType shapeType() const
Returns the shape type.
Definition: GeomAPI_Shape.cpp:488
Returns type of shapes in the compound.
Definition: GeomAPI_Shape.cpp:193
virtual GEOMAPI_EXPORT bool isCompoundOfSolids() const
Returns whether the shape is a compound of solids.
Definition: GeomAPI_Shape.cpp:178
virtual GEOMAPI_EXPORT bool isCompound() const
Returns whether the shape is a compound.
Definition: GeomAPI_Shape.cpp:146
GEOMAPI_EXPORT GeomAPI_Shape()
Creation of empty (null) shape.
virtual GEOMAPI_EXPORT bool isWire() const
Returns whether the shape is a wire.
Definition: GeomAPI_Shape.cpp:128
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shape > intersect(const std::shared_ptr< GeomAPI_Shape > theShape) const
Returns intersection of shapes.
Definition: GeomAPI_Shape.cpp:731
virtual GEOMAPI_EXPORT void setOrientation(const Orientation theOrientation)
Sets the shape orientation.
Definition: GeomAPI_Shape.cpp:612
virtual GEOMAPI_EXPORT bool isVertex() const
Returns whether the shape is a vertex.
Definition: GeomAPI_Shape.cpp:116
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Wire > wire() const
Returns wire or empty shape.
Definition: GeomAPI_Shape.cpp:404
GEOMAPI_EXPORT bool computeSize(double &theXmin, double &theYmin, double &theZmin, double &theXmax, double &theYmax, double &theZmax) const
Computes boundary dimensions of the shape Returns False if it is not possible.
Definition: GeomAPI_Shape.cpp:649
virtual GEOMAPI_EXPORT bool isSolid() const
Returns whether the shape is a solid.
Definition: GeomAPI_Shape.cpp:281
GEOMAPI_EXPORT void translate(const std::shared_ptr< GeomAPI_Dir > theDir, const double theOffset)
Translates the shape along the direction for the given offset.
Definition: GeomAPI_Shape.cpp:774
virtual GEOMAPI_EXPORT bool isShell() const
Returns whether the shape is a shell.
Definition: GeomAPI_Shape.cpp:140
GEOMAPI_EXPORT std::list< std::shared_ptr< GeomAPI_Shape > > subShapes(const ShapeType theSubShapeType, const bool theOnlyUnique=false) const
Returns list of sub-shapes of the given type.
Definition: GeomAPI_Shape.cpp:449
virtual GEOMAPI_EXPORT bool isFace() const
Returns whether the shape is a face.
Definition: GeomAPI_Shape.cpp:134
GEOMAPI_EXPORT bool isNull() const
Returns true if the underlied shape is null.
virtual GEOMAPI_EXPORT bool isEqual(const std::shared_ptr< GeomAPI_Shape > theShape) const
Returns whether the shapes are equal.
virtual GEOMAPI_EXPORT void reverse()
Reverse shape.
Definition: GeomAPI_Shape.cpp:622
virtual GEOMAPI_EXPORT bool isCompSolid() const
Returns whether the shape is a compsolid.
Definition: GeomAPI_Shape.cpp:287
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Edge > edge() const
Returns edge or empty shape.
Definition: GeomAPI_Shape.cpp:393
virtual GEOMAPI_EXPORT bool isCollectionOfSolids() const
Returns true, if the shape contains only solids, compsolids and compounds of solids and compsolids of...
Definition: GeomAPI_Shape.cpp:152
Orientation
Shape orientation.
Definition: GeomAPI_Shape.h:53
virtual GEOMAPI_EXPORT bool isSameGeometry(const std::shared_ptr< GeomAPI_Shape > theShape) const
Returns true if shapes have same underlying geometry.
Definition: GeomAPI_Shape.cpp:107
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Vertex > vertex() const
Returns vertex or empty shape.
Definition: GeomAPI_Shape.cpp:382
GEOMAPI_EXPORT std::shared_ptr< GeomAPI_Shell > shell() const
Returns shell or empty shape.
Definition: GeomAPI_Shape.cpp:426
GEOMAPI_EXPORT bool isIntersect(const std::shared_ptr< GeomAPI_Shape > theShape) const
Returns true if min distance between shapes < tolerance.
Definition: GeomAPI_Shape.cpp:756
GEOMAPI_EXPORT void move(const std::shared_ptr< GeomAPI_Trsf > theTransformation)
Moves the shape with the given transformation matrix.
Definition: GeomAPI_Shape.cpp:784
virtual GEOMAPI_EXPORT Orientation orientation() const
Definition: GeomAPI_Shape.cpp:599
Interface to the shell object.
Definition: GeomAPI_Shell.h:35
Interface to the solid object.
Definition: GeomAPI_Solid.h:35
Keep the transformation matrix coefficients.
Definition: GeomAPI_Trsf.h:36
Interface to the vertex object.
Definition: GeomAPI_Vertex.h:31
Interface to the wire object.
Definition: GeomAPI_Wire.h:31
