GeomData_Point2D.h
20#ifndef GeomData_Point2D_H_
21#define GeomData_Point2D_H_
23#include "GeomData.h"
24#include "GeomDataAPI_Point2D.h"
26#include <TDF_Label.hxx>
27
36{
37 enum { NUM_COMPONENTS = 2 };
38 std::shared_ptr<ModelAPI_ExpressionDouble> myExpression[NUM_COMPONENTS];
39 public:
41 GEOMDATA_EXPORT virtual void setValue(const double theX, const double theY);
43 GEOMDATA_EXPORT virtual void setValue(const std::shared_ptr<GeomAPI_Pnt2d>& thePoint);
44
46 GEOMDATA_EXPORT virtual double x() const;
48 GEOMDATA_EXPORT virtual double y() const;
50 GEOMDATA_EXPORT virtual std::shared_ptr<GeomAPI_Pnt2d> pnt();
51
53 GEOMDATA_EXPORT virtual void setCalculatedValue(const double theX, const double theY);
54
56 GEOMDATA_EXPORT virtual void setText(const std::wstring& theX,
57 const std::wstring& theY);
58
60 GEOMDATA_EXPORT virtual std::wstring textX();
61 GEOMDATA_EXPORT virtual std::wstring textY();
62
64 GEOMDATA_EXPORT virtual void setExpressionInvalid(int, const bool theFlag);
65
67 GEOMDATA_EXPORT virtual bool expressionInvalid(int);
68
70 GEOMDATA_EXPORT virtual void setExpressionError(int theComponent, const std::string& theError);
71
73 GEOMDATA_EXPORT virtual std::string expressionError(int theComponent);
74
76 GEOMDATA_EXPORT virtual void setUsedParameters(int theComponent,
77 const std::set<std::wstring>& theUsedParameters);
78
80 GEOMDATA_EXPORT virtual std::set<std::wstring> usedParameters(int theComponent) const;
81
82 protected:
84 GEOMDATA_EXPORT GeomData_Point2D();
86 virtual void reinit();
87
89 virtual void reset();
90
91 friend class Model_Data;
92};
93
94#endif
Attribute that contains 2D point.
Definition: GeomData_Point2D.h:36
Returns the Y double value.
Definition: GeomData_Point2D.cpp:78
virtual std::shared_ptr< GeomAPI_Pnt2d > pnt()
Returns the 2D point.
Definition: GeomData_Point2D.cpp:83
Returns the text values.
Definition: GeomData_Point2D.cpp:103
virtual void setExpressionError(int theComponent, const std::string &theError)
Allows to set expression (text) error (by the parameters listener)
Definition: GeomData_Point2D.cpp:125
virtual void setUsedParameters(int theComponent, const std::set< std::wstring > &theUsedParameters)
Defines the used parameters.
Definition: GeomData_Point2D.cpp:138
virtual void setText(const std::wstring &theX, const std::wstring &theY)
Defines the text values.
Definition: GeomData_Point2D.cpp:89
Reinitializes the internal state of the attribute (may be needed on undo/redo, abort,...
Definition: GeomData_Point2D.cpp:36
Defines the calculated double value.
Definition: GeomData_Point2D.cpp:53
Returns an expression error.
Definition: GeomData_Point2D.cpp:132
Returns the text value for Y.
Definition: GeomData_Point2D.cpp:107
virtual std::set< std::wstring > usedParameters(int theComponent) const
Returns the used parameters.
Definition: GeomData_Point2D.cpp:145
Allows to set expression (text) as invalid (by the parameters listener)
Definition: GeomData_Point2D.cpp:112
Defines the double value.
Definition: GeomData_Point2D.cpp:62
Resets attribute to default state.
Definition: GeomData_Point2D.cpp:45
Returns true if text is invalid.
Definition: GeomData_Point2D.cpp:119
Returns the X double value.
Definition: GeomData_Point2D.cpp:73
GeomData_Point2D()
Initializes attributes.
Definition: GeomData_Point2D.cpp:31
Expression for calculated double values.
Definition: ModelAPI_Expression.h:101
General object of the application that allows to get/set attributes from the document and compute res...
Definition: Model_Data.h:62
