ModelAPI_AttributeSelection.h
20#ifndef ModelAPI_AttributeSelection_H_
21#define ModelAPI_AttributeSelection_H_
23#include "ModelAPI_Attribute.h"
24#include <ModelAPI_Result.h>
26class GeomAPI_Edge;
27class GeomAPI_Pnt;
28
35{
36 public:
43 };
44
51 virtual bool setValue(
52 const ObjectPtr& theContext, const std::shared_ptr<GeomAPI_Shape>& theSubShape,
53 const bool theTemporarily = false) = 0;
54
57 virtual void setValueCenter(
58 const ObjectPtr& theContext, const std::shared_ptr<GeomAPI_Edge>& theEdge,
59 const CenterType theCenterType,
60 const bool theTemporarily = false) = 0;
61
63 virtual void selectValue(
64 const std::shared_ptr<ModelAPI_AttributeSelection>& theSource) = 0;
65
67 virtual void removeTemporaryValues() = 0;
68
70 virtual std::shared_ptr<GeomAPI_Shape> value() = 0;
71
73 virtual ResultPtr context() = 0;
74
76 virtual std::shared_ptr<ModelAPI_Feature> contextFeature() = 0;
78 virtual std::shared_ptr<ModelAPI_Object> contextObject() = 0;
79
82 virtual bool update() = 0;
83
85 static std::string typeId()
86 {
87 return "Selection";
88 }
89
91 MODELAPI_EXPORT virtual std::string attributeType();
92
95 virtual std::wstring namingName(const std::wstring& theDefaultValue = L"") = 0;
96
98 virtual void setId(int theID) = 0;
99
101 virtual void selectSubShape(const std::string& theType, const std::wstring& theSubShapeName) = 0;
102
104 virtual void selectSubShape(const std::string& theType,
105 const std::shared_ptr<GeomAPI_Pnt>& thePoint,
106 const bool theIsIgnoreGroups = false) = 0;
107
109 virtual void selectSubShape(const std::string& theType,
110 const std::wstring& theContextName, const int theIndex) = 0;
111
113 virtual bool isInvalid() = 0;
114
116 virtual bool isGeometricalSelection() const = 0;
117
119 MODELAPI_EXPORT virtual ~ModelAPI_AttributeSelection();
120
122 MODELAPI_EXPORT virtual std::wstring contextName(const ResultPtr& theContext) const = 0;
123
125 MODELAPI_EXPORT virtual void combineGeometrical() = 0;
126
130 MODELAPI_EXPORT virtual void updateInHistory(bool& theRemove) = 0;
131
132 protected:
134 MODELAPI_EXPORT ModelAPI_AttributeSelection();
135};
136
138typedef std::shared_ptr<ModelAPI_AttributeSelection> AttributeSelectionPtr;
139
140#endif
Interface to the edge object.
Definition: GeomAPI_Edge.h:38
Definition: GeomAPI_Pnt.h:38
virtual void selectSubShape(const std::string &theType, const std::shared_ptr< GeomAPI_Pnt > &thePoint, const bool theIsIgnoreGroups=false)=0
Selects sub-shape by its inner point.
virtual void selectSubShape(const std::string &theType, const std::wstring &theContextName, const int theIndex)=0
Selects sub-shape by weak naming index.
virtual void removeTemporaryValues()=0
Reset temporary stored values.
virtual bool update()=0
Updates the selection due to the changes in the referenced objects.
virtual void setValueCenter(const ObjectPtr &theContext, const std::shared_ptr< GeomAPI_Edge > &theEdge, const CenterType theCenterType, const bool theTemporarily=false)=0
Same as SetValue, but it takes an edge (on circular or elliptic curve) and stores the vertex of the c...
Returns the type of this class of attributes, not static method.
Definition: ModelAPI_AttributeSelection.cpp:23
virtual std::shared_ptr< GeomAPI_Shape > value()=0
Returns the selected subshape.
CenterType
Type of the center of the circular of elliptic edge.
Definition: ModelAPI_AttributeSelection.h:38
@ NOT_CENTER
this is not a center
Definition: ModelAPI_AttributeSelection.h:39
@ CIRCLE_CENTER
center of the circle
Definition: ModelAPI_AttributeSelection.h:40
@ ELLIPSE_SECOND_FOCUS
second focus point of the ellipse
Definition: ModelAPI_AttributeSelection.h:42
@ ELLIPSE_FIRST_FOCUS
first focus point of the ellipse
Definition: ModelAPI_AttributeSelection.h:41
virtual void combineGeometrical()=0
Makes the current local selection becomes all sub-shapes with same base geometry.
virtual void setId(int theID)=0
Defines an id of the selection.
Definition: ModelAPI_AttributeSelection.cpp:32
Returns the type of this class of attributes.
Definition: ModelAPI_AttributeSelection.h:85
virtual ResultPtr context()=0
Returns the context of the selection (the whole shape owner)
virtual std::shared_ptr< ModelAPI_Object > contextObject()=0
Returns the context of the selection : result or feature.
virtual void updateInHistory(bool &theRemove)=0
Updates the arguments of selection if something was affected by creation or reorder of features upper...
virtual bool setValue(const ObjectPtr &theContext, const std::shared_ptr< GeomAPI_Shape > &theSubShape, const bool theTemporarily=false)=0
Defines the result and its selected sub-shape.
virtual std::wstring namingName(const std::wstring &theDefaultValue=L"")=0
Returns a textual string of the selection.
virtual void selectSubShape(const std::string &theType, const std::wstring &theSubShapeName)=0
Selects sub-shape by the textual Name.
To virtually destroy the fields of successors.
Definition: ModelAPI_AttributeSelection.cpp:28
virtual std::shared_ptr< ModelAPI_Feature > contextFeature()=0
Returns the context of the selection if the whole feature was selected.
virtual std::wstring contextName(const ResultPtr &theContext) const =0
Returns the name by context. Adds the part name if the context is located in other document.
virtual bool isGeometricalSelection() const =0
Returns true if is geometrical selection.
virtual void selectValue(const std::shared_ptr< ModelAPI_AttributeSelection > &theSource)=0
Makes this selection attribute selects the same as in theSource selection.
virtual bool isInvalid()=0
Returns true if recompute of selection become impossible.
