ModelAPI_Events.h
20#ifndef MODELAPI_EVENTS_H_
21#define MODELAPI_EVENTS_H_
23#include <ModelAPI.h>
24#include <ModelAPI_Object.h>
26#include <ModelAPI_Attribute.h>
27#include <Events_MessageGroup.h>
28#include <Events_Loop.h>
30#include <memory>
31#include <string>
32#include <set>
33#include <map>
34
35
38class GeomAPI_Pnt2d;
39class GeomAPI_Shape;
40
41#if defined __GNUC__ || defined __clang__
42#define MAYBE_UNUSED __attribute__((unused))
43#else
44#define MAYBE_UNUSED
45#endif
46
48MAYBE_UNUSED static const char * EVENT_OBJECT_CREATED = "ObjectCreated";
50MAYBE_UNUSED static const char * EVENT_OBJECT_UPDATED = "ObjectUpdated";
52MAYBE_UNUSED static const char * EVENT_OBJECT_DELETED = "ObjectDeleted";
54MAYBE_UNUSED static const char * EVENT_OBJECT_RENAMED = "ObjectRenamed";
56MAYBE_UNUSED static const char * EVENT_OBJECT_MOVED = "ObjectsMoved";
58MAYBE_UNUSED static const char * EVENT_OBJECT_TO_REDISPLAY = "ObjectsToRedisplay";
60MAYBE_UNUSED static const char * EVENT_PLUGIN_LOADED = "PluginLoaded";
62MAYBE_UNUSED static const char * EVENT_DOCUMENT_CHANGED = "CurrentDocumentChanged";
64MAYBE_UNUSED static const char * EVENT_DOCUMENTS_CLOSED = "AllDocumentsClosed";
65
68MAYBE_UNUSED static const char * EVENT_ORDER_UPDATED = "OrderUpdated";
70MAYBE_UNUSED static const char * EVENT_UPDATE_SELECTION = "UpdateSelection";
71
73MAYBE_UNUSED static const char * EVENT_FEATURE_STATE_REQUEST = "FeatureStateRequest";
75MAYBE_UNUSED static const char * EVENT_FEATURE_STATE_RESPONSE = "FeatureStateResponse";
76
78MAYBE_UNUSED static const char * EVENT_UPDATE_VIEWER_BLOCKED = "UpdateViewerBlocked";
80MAYBE_UNUSED static const char * EVENT_UPDATE_VIEWER_UNBLOCKED = "UpdateViewerUnblocked";
81
83MAYBE_UNUSED static const char * EVENT_EMPTY_AIS_PRESENTATION = "EmptyAISPresentation";
85MAYBE_UNUSED static const char * EVENT_EMPTY_OPERATION_PRESENTATION = "EmptyOperationPresentation";
87MAYBE_UNUSED static const char * EVENT_PREVIEW_BLOCKED = "PreviewBlocked";
89MAYBE_UNUSED static const char * EVENT_PREVIEW_REQUESTED = "PreviewRequested";
91MAYBE_UNUSED static const char * EVENT_AUTOMATIC_RECOMPUTATION_DISABLE
92 = "DisableAutomaticRecomputation";
94MAYBE_UNUSED static const char * EVENT_AUTOMATIC_RECOMPUTATION_ENABLE
95 = "EnableAutomaticRecomputation";
96
98MAYBE_UNUSED static const char * EVENT_SOLVER_FAILED = "SolverFailed";
100MAYBE_UNUSED static const char * EVENT_SOLVER_REPAIRED = "SolverRepaired";
101
103MAYBE_UNUSED static const char * EVENT_SKETCH_FULLY_CONSTRAINED = "SketchFullyConstrainted";
105MAYBE_UNUSED static const char * EVENT_SKETCH_UNDER_CONSTRAINED = "SketchUnderConstrainted";
107MAYBE_UNUSED static const char * EVENT_SKETCH_OVER_CONSTRAINED = "SketchOverConstrainted";
108
110MAYBE_UNUSED static const char * EVENT_STABILITY_CHANGED = "StabilityChanged";
111
113MAYBE_UNUSED static const char * EVENT_SKETCH_PREPARED = "SketchPrepared";
114
116MAYBE_UNUSED static const char * EVENT_GET_DOF_OBJECTS = "GetDoFObjects";
117
119MAYBE_UNUSED static const char * EVENT_DOF_OBJECTS = "DoFObjects";
120
122MAYBE_UNUSED static const char * EVENT_VISUAL_ATTRIBUTES = "UpdateVisualAttributes";
123
125MAYBE_UNUSED static const char * EVENT_OPERATION_SHAPES_FAILED = "OperationShapesFailed";
126
127MAYBE_UNUSED static const char * EVENT_CHECK_CONSTRAINTS = "CheckConstrains";
128
129MAYBE_UNUSED static const char * EVENT_REMOVE_CONSTRAINTS = "RemoveConstrains";
130
132MAYBE_UNUSED static const char * EVENT_FEATURE_LICENSE_VALID = "FeaturesLicenseValid";
133
135MAYBE_UNUSED static const char * EVENT_CREATE_PART_ON_START = "CreatePartOnStart";
136
137
140{
141 protected:
143 ModelAPI_ObjectUpdatedMessage(const Events_ID theID, const void* theSender = 0);
146
147 public:
149 virtual const std::set<ObjectPtr>& objects() const = 0;
150
152 virtual std::shared_ptr<Events_MessageGroup> newEmpty() = 0;
153
155 virtual void Join(const std::shared_ptr<Events_MessageGroup>& theJoined) = 0;
156};
157
160{
161protected:
163 ModelAPI_ObjectDeletedMessage(const Events_ID theID, const void* theSender = 0);
166
167public:
169 virtual const std::list<std::pair<std::shared_ptr<ModelAPI_Document>, std::string> >&
170 groups() const = 0;
171
173 virtual std::shared_ptr<Events_MessageGroup> newEmpty() = 0;
174
176 virtual const Events_ID messageId() = 0;
177
179 virtual void Join(const std::shared_ptr<Events_MessageGroup>& theJoined) = 0;
180};
181
183class MODELAPI_EXPORT ModelAPI_OrderUpdatedMessage : public Events_Message
184{
185protected:
187 ModelAPI_OrderUpdatedMessage(const Events_ID theID, const void* theSender = 0);
190
191public:
193 virtual std::shared_ptr<ModelAPI_Feature> reordered() = 0;
194
196 virtual const Events_ID messageId() = 0;
197};
198
200class MODELAPI_EXPORT ModelAPI_EventCreator
201{
202public:
203 virtual ~ModelAPI_EventCreator() {}
204
206 virtual void sendUpdated(const ObjectPtr& theObject, const Events_ID& theEvent,
207 const bool isGroupped = true) const = 0;
209 virtual void sendUpdated(const std::list<ObjectPtr>& theObjects, const Events_ID& theEvent,
210 const bool isGroupped = true) const = 0;
212 virtual void sendDeleted(const std::shared_ptr<ModelAPI_Document>& theDoc,
213 const std::string& theGroup) const = 0;
215 virtual void sendReordered(const std::shared_ptr<ModelAPI_Feature>& theReordered) const = 0;
216
218 static const ModelAPI_EventCreator* get();
219
221 static void set(const ModelAPI_EventCreator* theCreator);
222};
223
226{
227public:
229 MODELAPI_EXPORT ModelAPI_FeatureStateMessage(const Events_ID theID, const void* theSender = 0);
231 MODELAPI_EXPORT virtual ~ModelAPI_FeatureStateMessage();
232
234 MODELAPI_EXPORT std::shared_ptr<ModelAPI_Feature> feature() const;
236 MODELAPI_EXPORT void setFeature(std::shared_ptr<ModelAPI_Feature>& theFeature);
237 // For response
239 MODELAPI_EXPORT bool hasState(const std::string& theFeatureId) const;
241 MODELAPI_EXPORT bool state(const std::string& theFeatureId, bool theDefault = false) const;
243 MODELAPI_EXPORT void setState(const std::string& theFeatureId, bool theValue);
245 MODELAPI_EXPORT std::list<std::string> features() const;
246
247 private:
249 std::shared_ptr<ModelAPI_Feature> myCurrentFeature;
251 std::map<std::string, bool> myFeatureState;
252};
253
256{
257 DocumentPtr myDocument;
258
259 public:
261 MODELAPI_EXPORT ModelAPI_DocumentCreatedMessage(const Events_ID theID, const void* theSender = 0);
263 MODELAPI_EXPORT virtual ~ModelAPI_DocumentCreatedMessage();
265 MODELAPI_EXPORT static Events_ID eventId()
266 {
267 static const char * MY_DOCUMENT_CREATED_EVENT_ID("DocumentCreated");
268 return Events_Loop::eventByName(MY_DOCUMENT_CREATED_EVENT_ID);
269 }
270
272 MODELAPI_EXPORT DocumentPtr document() const;
274 MODELAPI_EXPORT void setDocument(DocumentPtr theDocument);
275};
276
279{
280 AttributePtr myAttribute;
281
282 public:
284 MODELAPI_EXPORT static Events_ID& eventId()
285 {
286 static const char * MY_ATTRIBUTE_EVALUATION_EVENT_ID("AttributeEvaluationRequest");
287 static Events_ID anId = Events_Loop::eventByName(MY_ATTRIBUTE_EVALUATION_EVENT_ID);
288 return anId;
289 }
290
292 MODELAPI_EXPORT static void send(AttributePtr theAttribute, const void* theSender)
293 {
294 std::shared_ptr<ModelAPI_AttributeEvalMessage> aMessage =
295 std::shared_ptr<ModelAPI_AttributeEvalMessage>(
296 new ModelAPI_AttributeEvalMessage(eventId(), theSender));
297 aMessage->setAttribute(theAttribute);
298 Events_Loop::loop()->send(aMessage);
299 }
300
302 MODELAPI_EXPORT ModelAPI_AttributeEvalMessage(const Events_ID theID, const void* theSender = 0);
304 MODELAPI_EXPORT virtual ~ModelAPI_AttributeEvalMessage();
305
307 MODELAPI_EXPORT AttributePtr attribute() const;
309 MODELAPI_EXPORT void setAttribute(AttributePtr theAttribute);
310};
311
314{
315 FeaturePtr myParam;
316 bool myIsProcessed;
318 std::list<std::shared_ptr<ModelAPI_ResultParameter> > myParamsList;
319 double myResult;
320 std::string myError;
321
322 public:
324 MODELAPI_EXPORT static Events_ID& eventId()
325 {
326 static const char * MY_PARAMETER_EVALUATION_EVENT_ID("ParameterEvaluationRequest");
327 static Events_ID anId = Events_Loop::eventByName(MY_PARAMETER_EVALUATION_EVENT_ID);
328 return anId;
329 }
330
333 MODELAPI_EXPORT static std::shared_ptr<ModelAPI_ParameterEvalMessage>
334 send(FeaturePtr theParameter, const void* theSender)
335 {
336 std::shared_ptr<ModelAPI_ParameterEvalMessage> aMessage =
337 std::shared_ptr<ModelAPI_ParameterEvalMessage>(
338 new ModelAPI_ParameterEvalMessage(eventId(), theSender));
339 aMessage->setParameter(theParameter);
340 Events_Loop::loop()->send(aMessage);
341 return aMessage;
342 }
343
345 MODELAPI_EXPORT ModelAPI_ParameterEvalMessage(const Events_ID theID, const void* theSender = 0);
347 MODELAPI_EXPORT virtual ~ModelAPI_ParameterEvalMessage();
348
350 MODELAPI_EXPORT FeaturePtr parameter() const;
352 MODELAPI_EXPORT void setParameter(FeaturePtr theParam);
354 MODELAPI_EXPORT void setResults(
355 const std::list<std::shared_ptr<ModelAPI_ResultParameter> >& theParamsList,
356 const double theResult, const std::string& theError);
358 MODELAPI_EXPORT bool isProcessed();
360 MODELAPI_EXPORT const std::list<std::shared_ptr<ModelAPI_ResultParameter> >& params() const;
362 MODELAPI_EXPORT const double& result() const;
364 MODELAPI_EXPORT const std::string& error() const;
365};
366
368{
369 std::string myFilename;
370 std::string myError;
371
372public:
374 MODELAPI_EXPORT static Events_ID& eventId()
375 {
376 static const char* MY_PARAMETER_EVALUATION_EVENT_ID("ImportParametersMessage");
377 static Events_ID anId = Events_Loop::eventByName(MY_PARAMETER_EVALUATION_EVENT_ID);
378 return anId;
379 }
380
383 MODELAPI_EXPORT static std::shared_ptr<ModelAPI_ImportParametersMessage>
384 send(std::string theParameter, const void* theSender)
385 {
386 std::shared_ptr<ModelAPI_ImportParametersMessage> aMessage =
387 std::shared_ptr<ModelAPI_ImportParametersMessage>(
388 new ModelAPI_ImportParametersMessage(eventId(), theSender));
389 aMessage->setFilename(theParameter);
390 Events_Loop::loop()->send(aMessage);
391 return aMessage;
392 }
393
395 MODELAPI_EXPORT ModelAPI_ImportParametersMessage(const Events_ID theID,
396 const void* theSender = 0);
398 MODELAPI_EXPORT virtual ~ModelAPI_ImportParametersMessage();
399
401 MODELAPI_EXPORT std::string filename() const;
403 MODELAPI_EXPORT void setFilename(std::string theFilename);
404};
405
407{
408 FeaturePtr myParam;
409 bool myIsProcessed;
410 std::string myError;
412 std::list<std::shared_ptr<ModelAPI_ResultParameter> > myParamsList;
413
414 public:
416 MODELAPI_EXPORT static Events_ID& eventId()
417 {
418 static const char * MY_BUILD_EVALUATION_EVENT_ID("BuildEvaluationRequest");
419 static Events_ID anId = Events_Loop::eventByName(MY_BUILD_EVALUATION_EVENT_ID);
420 return anId;
421 }
422
425 MODELAPI_EXPORT static std::shared_ptr<ModelAPI_BuildEvalMessage>
426 send(FeaturePtr theParameter, const void* theSender)
427 {
428 std::shared_ptr<ModelAPI_BuildEvalMessage> aMessage =
429 std::shared_ptr<ModelAPI_BuildEvalMessage>(
430 new ModelAPI_BuildEvalMessage(eventId(), theSender));
431 aMessage->setParameter(theParameter);
432 Events_Loop::loop()->send(aMessage);
433 return aMessage;
434 }
435
437 MODELAPI_EXPORT ModelAPI_BuildEvalMessage(const Events_ID theID, const void* theSender = 0);
439 MODELAPI_EXPORT virtual ~ModelAPI_BuildEvalMessage();
440
442 MODELAPI_EXPORT FeaturePtr parameter() const;
444 MODELAPI_EXPORT void setParameter(FeaturePtr theParam);
446 MODELAPI_EXPORT void setResults(
447 const std::list<std::shared_ptr<ModelAPI_ResultParameter> >& theParamsList,
448 const std::string& theError);
450 MODELAPI_EXPORT const std::list<std::shared_ptr<ModelAPI_ResultParameter> >& params() const;
452 MODELAPI_EXPORT bool isProcessed();
453
455 MODELAPI_EXPORT const std::string& error() const;
456};
457
460{
461 std::wstring myExpression;
462 std::wstring myParamName;
463 std::list<std::pair<int, int> > myPositions;
464
465public:
467 MODELAPI_EXPORT static Events_ID& eventId()
468 {
469 static const char * MY_COMPUTE_POSITIOND_EVENT_ID("ComputePositionsRequest");
470 static Events_ID anId = Events_Loop::eventByName(MY_COMPUTE_POSITIOND_EVENT_ID);
471 return anId;
472 }
473
476 MODELAPI_EXPORT static std::shared_ptr<ModelAPI_ComputePositionsMessage>
477 send(const std::wstring& theExpression, const std::wstring& theParameter, const void* theSender)
478 {
479 std::shared_ptr<ModelAPI_ComputePositionsMessage> aMessage =
480 std::shared_ptr<ModelAPI_ComputePositionsMessage>(
481 new ModelAPI_ComputePositionsMessage(eventId(), theSender));
482 aMessage->set(theExpression, theParameter);
483 Events_Loop::loop()->send(aMessage);
484 return aMessage;
485 }
486
488 MODELAPI_EXPORT ModelAPI_ComputePositionsMessage(
489 const Events_ID theID, const void* theSender = 0);
491 MODELAPI_EXPORT virtual ~ModelAPI_ComputePositionsMessage();
492
494 MODELAPI_EXPORT const std::wstring& expression() const;
496 MODELAPI_EXPORT const std::wstring& parameter() const;
498 MODELAPI_EXPORT void set(const std::wstring& theExpression, const std::wstring& theParameter);
500 MODELAPI_EXPORT void setPositions(const std::list<std::pair<int, int> >& thePositions);
502 MODELAPI_EXPORT const std::list<std::pair<int, int> >& positions() const;
503};
504
507{
508 ObjectPtr myObject;
509 std::wstring myOldName;
510 std::wstring myNewName;
511
512 public:
514 MODELAPI_EXPORT static Events_ID& eventId()
515 {
516 static const char * MY_OBJECT_RENAMED_EVENT_ID("ObjectRenamed");
517 static Events_ID anId = Events_Loop::eventByName(MY_OBJECT_RENAMED_EVENT_ID);
518 return anId;
519 }
520
522 MODELAPI_EXPORT static void send(ObjectPtr theObject,
523 const std::wstring& theOldName,
524 const std::wstring& theNewName,
525 const void* theSender);
526
528 MODELAPI_EXPORT ModelAPI_ObjectRenamedMessage(const Events_ID theID, const void* theSender = 0);
530 MODELAPI_EXPORT virtual ~ModelAPI_ObjectRenamedMessage();
531
533 MODELAPI_EXPORT ObjectPtr object() const;
535 MODELAPI_EXPORT void setObject(ObjectPtr theObject);
537 MODELAPI_EXPORT std::wstring oldName() const;
539 MODELAPI_EXPORT void setOldName(const std::wstring& theOldName);
541 MODELAPI_EXPORT std::wstring newName() const;
543 MODELAPI_EXPORT void setNewName(const std::wstring& theNewName);
544};
545
548{
549 ObjectPtr myObject;
550
551 public:
553 MODELAPI_EXPORT static Events_ID& eventId()
554 {
555 static const char * MY_EVENT_ID("ReplaceParameter");
556 static Events_ID anId = Events_Loop::eventByName(MY_EVENT_ID);
557 return anId;
558 }
559
561 MODELAPI_EXPORT static void send(ObjectPtr theObject,
562 const void* theSender);
563
565 MODELAPI_EXPORT
566 ModelAPI_ReplaceParameterMessage(const Events_ID theID, const void* theSender = 0);
568 MODELAPI_EXPORT virtual ~ModelAPI_ReplaceParameterMessage();
569
571 MODELAPI_EXPORT ObjectPtr object() const;
573 MODELAPI_EXPORT void setObject(ObjectPtr theObject);
574};
575
578{
579public:
581 MODELAPI_EXPORT ModelAPI_SolverFailedMessage(const Events_ID theID, const void* theSender = 0);
583 MODELAPI_EXPORT virtual ~ModelAPI_SolverFailedMessage();
584
586 MODELAPI_EXPORT void setObjects(const std::set<ObjectPtr>& theObjects);
588 MODELAPI_EXPORT const std::set<ObjectPtr>& objects() const;
589
591 void dof(const int theDOF) { myDOF = theDOF; }
593 const int& dof() const { return myDOF; }
594
595private:
596 std::set<ObjectPtr> myObjects;
597 int myDOF;
598};
599
603{
604 ObjectPtr myMovedObject;
605 AttributePtr myMovedAttribute;
606 int myMovedPointIndex;
607
608 std::shared_ptr<GeomAPI_Pnt2d> myOriginalPosition;
609 std::shared_ptr<GeomAPI_Pnt2d> myCurrentPosition;
610
611public:
612 MODELAPI_EXPORT ModelAPI_ObjectMovedMessage(const void* theSender = 0);
613
615 MODELAPI_EXPORT void setMovedObject(const ObjectPtr& theMovedObject);
619 MODELAPI_EXPORT void setMovedAttribute(const AttributePtr& theMovedAttribute,
620 const int thePointIndex = -1);
621
623 ObjectPtr movedObject() const
624 { return myMovedObject; }
626 AttributePtr movedAttribute() const
627 { return myMovedAttribute; }
629 int movedPointIndex() const
630 { return myMovedPointIndex; }
631
633 MODELAPI_EXPORT void setOriginalPosition(double theX, double theY);
635 MODELAPI_EXPORT void setOriginalPosition(const std::shared_ptr<GeomAPI_Pnt2d>& thePoint);
637 const std::shared_ptr<GeomAPI_Pnt2d>& originalPosition() const
638 { return myOriginalPosition; }
639
641 MODELAPI_EXPORT void setCurrentPosition(double theX, double theY);
643 MODELAPI_EXPORT void setCurrentPosition(const std::shared_ptr<GeomAPI_Pnt2d>& thePoint);
645 const std::shared_ptr<GeomAPI_Pnt2d>& currentPosition() const
646 { return myCurrentPosition; }
647};
648
651{
652public:
654 MODELAPI_EXPORT ModelAPI_ShapesFailedMessage(const Events_ID theID, const void* theSender = 0);
656 MODELAPI_EXPORT virtual ~ModelAPI_ShapesFailedMessage();
658 MODELAPI_EXPORT static Events_ID eventId()
659 {
660 return Events_Loop::eventByName(EVENT_OPERATION_SHAPES_FAILED);
661 }
662
664 MODELAPI_EXPORT void setShapes(const std::list< std::shared_ptr<GeomAPI_Shape> >& theVertices);
666 MODELAPI_EXPORT const std::list< std::shared_ptr<GeomAPI_Shape> >& shapes() const;
667
668private:
669 std::list< std::shared_ptr<GeomAPI_Shape> > myShapes;
670};
671
674{
675public:
677 MODELAPI_EXPORT ModelAPI_CheckConstraintsMessage(
678 const Events_ID theID, const void* theSender = 0);
680 MODELAPI_EXPORT virtual ~ModelAPI_CheckConstraintsMessage();
681
683 MODELAPI_EXPORT const std::set<ObjectPtr>& constraints() const;
684
686 MODELAPI_EXPORT void setConstraints(const std::set<ObjectPtr>& theConstraints);
687
688private:
689 std::set<ObjectPtr> myConstraints;
690};
691
692
695{
696public:
698 MODELAPI_EXPORT
699 ModelAPI_FeaturesLicenseValidMessage(const Events_ID theID, const void* theSender = 0);
701 MODELAPI_EXPORT virtual ~ModelAPI_FeaturesLicenseValidMessage();
703 MODELAPI_EXPORT static Events_ID eventId()
704 {
705 return Events_Loop::eventByName(EVENT_FEATURE_LICENSE_VALID);
706 }
707
709 MODELAPI_EXPORT void setFeatures(const std::set<std::string>& theFeatures);
711 MODELAPI_EXPORT const std::set<std::string>& features() const;
712
713private:
714 std::set<std::string> myFeatures;
715};
716
717#endif
Identifier of the event kind.
Definition: Events_Message.h:36
static EVENTS_EXPORT Events_Loop * loop()
! Returns the main object of the loop, one per application.
Definition: Events_Loop.cpp:26
EVENTS_EXPORT void send(const std::shared_ptr< Events_Message > &theMessage, bool isGroup=true)
Allows to send an event.
Definition: Events_Loop.cpp:66
static EVENTS_EXPORT Events_ID eventByName(const char *theName)
Returns the unique event by the given name.
Definition: Events_Loop.cpp:33
Message that allows to group messages and send them later as a group of messages.
Definition: Events_MessageGroup.h:34
Message for communication between sender and listener of event.
Definition: Events_Message.h:65
Message that attribute text should be evaluated in the attribute value.
Definition: ModelAPI_Events.h:279
virtual MODELAPI_EXPORT ~ModelAPI_AttributeEvalMessage()
The virtual destructor.
Definition: ModelAPI_Events.cpp:129
static MODELAPI_EXPORT void send(AttributePtr theAttribute, const void *theSender)
Useful method that creates and sends the AttributeEvalMessage event.
Definition: ModelAPI_Events.h:292
Returns a document stored in the message.
Definition: ModelAPI_Events.cpp:132
Sets an attribute to the message.
Definition: ModelAPI_Events.cpp:137
MODELAPI_EXPORT ModelAPI_AttributeEvalMessage(const Events_ID theID, const void *theSender=0)
Creates an empty message.
Definition: ModelAPI_Events.cpp:124
static MODELAPI_EXPORT Events_ID & eventId()
Static. Returns EventID of the message.
Definition: ModelAPI_Events.h:284
Definition: ModelAPI_Events.h:407
MODELAPI_EXPORT const std::list< std::shared_ptr< ModelAPI_ResultParameter > > & params() const
Returns the results of processing: list of parameters found in the expression.
Definition: ModelAPI_Events.cpp:241
Sets a parameter to the message.
Definition: ModelAPI_Events.cpp:226
Definition: ModelAPI_Events.h:416
MODELAPI_EXPORT const std::string & error() const
Returns the interpreter error (empty if no error)
Definition: ModelAPI_Events.cpp:251
Returns a parameter stored in the message.
Definition: ModelAPI_Events.cpp:221
MODELAPI_EXPORT ModelAPI_BuildEvalMessage(const Events_ID theID, const void *theSender=0)
Definition: ModelAPI_Events.cpp:213
Returns true if the expression is processed.
Definition: ModelAPI_Events.cpp:246
MODELAPI_EXPORT void setResults(const std::list< std::shared_ptr< ModelAPI_ResultParameter > > &theParamsList, const std::string &theError)
Sets the results of processing.
Definition: ModelAPI_Events.cpp:231
static MODELAPI_EXPORT std::shared_ptr< ModelAPI_BuildEvalMessage > send(FeaturePtr theParameter, const void *theSender)
Useful method that creates and sends the event.
Definition: ModelAPI_Events.h:426
virtual MODELAPI_EXPORT ~ModelAPI_BuildEvalMessage()
Definition: ModelAPI_Events.cpp:218
Message that sends the constraints to check or remove.
Definition: ModelAPI_Events.h:674
MODELAPI_EXPORT ModelAPI_CheckConstraintsMessage(const Events_ID theID, const void *theSender=0)
Definition: ModelAPI_Events.cpp:475
MODELAPI_EXPORT const std::set< ObjectPtr > & constraints() const
Get list of constrains.
Definition: ModelAPI_Events.cpp:485
MODELAPI_EXPORT void setConstraints(const std::set< ObjectPtr > &theConstraints)
Set list of constrains.
Definition: ModelAPI_Events.cpp:490
virtual MODELAPI_EXPORT ~ModelAPI_CheckConstraintsMessage()
Definition: ModelAPI_Events.cpp:481
Message to ask compute the positions of parameters in the expression.
Definition: ModelAPI_Events.h:460
MODELAPI_EXPORT void set(const std::wstring &theExpression, const std::wstring &theParameter)
Sets an expression and parameter needed for computation.
Definition: ModelAPI_Events.cpp:274
virtual MODELAPI_EXPORT ~ModelAPI_ComputePositionsMessage()
Definition: ModelAPI_Events.cpp:261
MODELAPI_EXPORT const std::wstring & parameter() const
Returns a parameter name stored in the message.
Definition: ModelAPI_Events.cpp:269
MODELAPI_EXPORT const std::list< std::pair< int, int > > & positions() const
Returns the results of processing: position start and end indices.
Definition: ModelAPI_Events.cpp:287
MODELAPI_EXPORT ModelAPI_ComputePositionsMessage(const Events_ID theID, const void *theSender=0)
Definition: ModelAPI_Events.cpp:256
MODELAPI_EXPORT const std::wstring & expression() const
Returns an expression stored in the message.
Definition: ModelAPI_Events.cpp:264
Definition: ModelAPI_Events.h:467
static MODELAPI_EXPORT std::shared_ptr< ModelAPI_ComputePositionsMessage > send(const std::wstring &theExpression, const std::wstring &theParameter, const void *theSender)
Useful method that creates and sends the AttributeEvalMessage event Returns the message,...
Definition: ModelAPI_Events.h:477
MODELAPI_EXPORT void setPositions(const std::list< std::pair< int, int > > &thePositions)
Definition: ModelAPI_Events.cpp:281
Message that document (Part, PartSet) was created.
Definition: ModelAPI_Events.h:256
Definition: ModelAPI_Events.cpp:114
MODELAPI_EXPORT ModelAPI_DocumentCreatedMessage(const Events_ID theID, const void *theSender=0)
Definition: ModelAPI_Events.cpp:106
virtual MODELAPI_EXPORT ~ModelAPI_DocumentCreatedMessage()
Definition: ModelAPI_Events.cpp:111
static MODELAPI_EXPORT Events_ID eventId()
Definition: ModelAPI_Events.h:265
Sets a document to the message.
Definition: ModelAPI_Events.cpp:119
Allows to create ModelAPI messages.
Definition: ModelAPI_Events.h:201
virtual void sendDeleted(const std::shared_ptr< ModelAPI_Document > &theDoc, const std::string &theGroup) const =0
creates deleted message and sends to the loop
virtual void sendReordered(const std::shared_ptr< ModelAPI_Feature > &theReordered) const =0
creates reordered message and sends to the loop
virtual void sendUpdated(const std::list< ObjectPtr > &theObjects, const Events_ID &theEvent, const bool isGroupped=true) const =0
creates created, updated or moved messages with the objects collection and sends to the loop
virtual void sendUpdated(const ObjectPtr &theObject, const Events_ID &theEvent, const bool isGroupped=true) const =0
creates created, updated or moved messages and sends to the loop
Contains the state information about the feature: is it enabled or disabled.
Definition: ModelAPI_Events.h:226
MODELAPI_EXPORT bool hasState(const std::string &theFeatureId) const
Returns true if feature has specific state.
Definition: ModelAPI_Events.cpp:77
MODELAPI_EXPORT ModelAPI_FeatureStateMessage(const Events_ID theID, const void *theSender=0)
Definition: ModelAPI_Events.cpp:57
MODELAPI_EXPORT bool state(const std::string &theFeatureId, bool theDefault=false) const
Returns true if feature is enabled.
Definition: ModelAPI_Events.cpp:82
MODELAPI_EXPORT std::list< std::string > features() const
Returns all feature IDs with states.
Definition: ModelAPI_Events.cpp:95
MODELAPI_EXPORT void setFeature(std::shared_ptr< ModelAPI_Feature > &theFeature)
Stores the feature this message is related to.
Definition: ModelAPI_Events.cpp:72
virtual MODELAPI_EXPORT ~ModelAPI_FeatureStateMessage()
Definition: ModelAPI_Events.cpp:64
MODELAPI_EXPORT void setState(const std::string &theFeatureId, bool theValue)
Stores the feature state.
Definition: ModelAPI_Events.cpp:90
MODELAPI_EXPORT std::shared_ptr< ModelAPI_Feature > feature() const
Returns the feature this message is related to.
Definition: ModelAPI_Events.cpp:67
Message that sends the features which license is checked and valid.
Definition: ModelAPI_Events.h:695
MODELAPI_EXPORT void setFeatures(const std::set< std::string > &theFeatures)
Sets list of features with valid license.
Definition: ModelAPI_Events.cpp:505
MODELAPI_EXPORT const std::set< std::string > & features() const
Returns list of features with valid license.
Definition: ModelAPI_Events.cpp:510
MODELAPI_EXPORT ModelAPI_FeaturesLicenseValidMessage(const Events_ID theID, const void *theSender=0)
Creates an message.
Definition: ModelAPI_Events.cpp:497
virtual MODELAPI_EXPORT ~ModelAPI_FeaturesLicenseValidMessage()
Default destructor.
Definition: ModelAPI_Events.cpp:502
Definition: ModelAPI_Events.h:703
Definition: ModelAPI_Events.h:368
Definition: ModelAPI_Events.h:374
Sets a filename to the message.
Definition: ModelAPI_Events.cpp:208
static MODELAPI_EXPORT std::shared_ptr< ModelAPI_ImportParametersMessage > send(std::string theParameter, const void *theSender)
Definition: ModelAPI_Events.h:384
virtual MODELAPI_EXPORT ~ModelAPI_ImportParametersMessage()
Definition: ModelAPI_Events.cpp:199
Returns a filename stored in the message.
Definition: ModelAPI_Events.cpp:203
MODELAPI_EXPORT ModelAPI_ImportParametersMessage(const Events_ID theID, const void *theSender=0)
Definition: ModelAPI_Events.cpp:192
Message that feature was deleted (used for Object Browser update)
Definition: ModelAPI_Events.h:160
virtual void Join(const std::shared_ptr< Events_MessageGroup > &theJoined)=0
Appends to this message the given one.
virtual const Events_ID messageId()=0
Returns the identifier of the kind of a message.
virtual const std::list< std::pair< std::shared_ptr< ModelAPI_Document >, std::string > > & groups() const =0
Returns the groups where the objects were deleted.
virtual std::shared_ptr< Events_MessageGroup > newEmpty()=0
Creates the new empty message of this kind.
Message sent when feature or attribute has been moved.
Definition: ModelAPI_Events.h:603
Return moved object.
Definition: ModelAPI_Events.h:623
MODELAPI_EXPORT void setMovedAttribute(const AttributePtr &theMovedAttribute, const int thePointIndex=-1)
Set attribute which is being moved (if the message already contains object it will be cleared)
Definition: ModelAPI_Events.cpp:404
Return moved attribute.
Definition: ModelAPI_Events.h:626
const std::shared_ptr< GeomAPI_Pnt2d > & originalPosition() const
Return original mouse position.
Definition: ModelAPI_Events.h:637
MODELAPI_EXPORT void setMovedObject(const ObjectPtr &theMovedObject)
Set object which is being moved (if the message already contains attribute it will be cleared)
Definition: ModelAPI_Events.cpp:398
const std::shared_ptr< GeomAPI_Pnt2d > & currentPosition() const
Return current mouse position.
Definition: ModelAPI_Events.h:645
Return index of the moved point.
Definition: ModelAPI_Events.h:629
Set current mouse position.
Definition: ModelAPI_Events.cpp:431
Set original mouse position.
Definition: ModelAPI_Events.cpp:412
Message that the object is renamed.
Definition: ModelAPI_Events.h:507
Sets an object.
Definition: ModelAPI_Events.cpp:319
MODELAPI_EXPORT void setNewName(const std::wstring &theNewName)
Sets a new name.
Definition: ModelAPI_Events.cpp:339
Returns a new name.
Definition: ModelAPI_Events.cpp:334
static MODELAPI_EXPORT void send(ObjectPtr theObject, const std::wstring &theOldName, const std::wstring &theNewName, const void *theSender)
Definition: ModelAPI_Events.cpp:301
Definition: ModelAPI_Events.h:514
Returns an old name.
Definition: ModelAPI_Events.cpp:324
virtual MODELAPI_EXPORT ~ModelAPI_ObjectRenamedMessage()
Definition: ModelAPI_Events.cpp:298
MODELAPI_EXPORT ModelAPI_ObjectRenamedMessage(const Events_ID theID, const void *theSender=0)
Definition: ModelAPI_Events.cpp:293
MODELAPI_EXPORT void setOldName(const std::wstring &theOldName)
Sets an old name.
Definition: ModelAPI_Events.cpp:329
Returns an object.
Definition: ModelAPI_Events.cpp:314
Message that feature was changed (used for Object Browser update): moved, updated and deleted.
Definition: ModelAPI_Events.h:140
virtual const std::set< ObjectPtr > & objects() const =0
Returns the feature that has been updated.
Creates a new empty group (to store it in the loop before flush)
Allows to join the given message with the current one.
Message that order changed (used for Object Browser update)
Definition: ModelAPI_Events.h:184
virtual std::shared_ptr< ModelAPI_Feature > reordered()=0
Returns the document that has been updated.
Message that parameter feature expression should be evaluated: value and error producing.
Definition: ModelAPI_Events.h:314
MODELAPI_EXPORT const double & result() const
Returns the expression result.
Definition: ModelAPI_Events.cpp:181
virtual MODELAPI_EXPORT ~ModelAPI_ParameterEvalMessage()
Definition: ModelAPI_Events.cpp:147
Definition: ModelAPI_Events.cpp:170
Definition: ModelAPI_Events.cpp:155
Definition: ModelAPI_Events.cpp:176
Definition: ModelAPI_Events.h:324
static MODELAPI_EXPORT std::shared_ptr< ModelAPI_ParameterEvalMessage > send(FeaturePtr theParameter, const void *theSender)
Definition: ModelAPI_Events.h:334
Definition: ModelAPI_Events.cpp:150
Definition: ModelAPI_Events.cpp:186
MODELAPI_EXPORT ModelAPI_ParameterEvalMessage(const Events_ID theID, const void *theSender=0)
Definition: ModelAPI_Events.cpp:142
MODELAPI_EXPORT void setResults(const std::list< std::shared_ptr< ModelAPI_ResultParameter > > &theParamsList, const double theResult, const std::string &theError)
Definition: ModelAPI_Events.cpp:160
Message that the parameter should be replaced with its value.
Definition: ModelAPI_Events.h:548
virtual MODELAPI_EXPORT ~ModelAPI_ReplaceParameterMessage()
Definition: ModelAPI_Events.cpp:349
static MODELAPI_EXPORT void send(ObjectPtr theObject, const void *theSender)
Definition: ModelAPI_Events.cpp:352
Returns an object.
Definition: ModelAPI_Events.cpp:361
Definition: ModelAPI_Events.h:553
MODELAPI_EXPORT ModelAPI_ReplaceParameterMessage(const Events_ID theID, const void *theSender=0)
Definition: ModelAPI_Events.cpp:344
Sets an object.
Definition: ModelAPI_Events.cpp:366
The construction element result of a feature.
Definition: ModelAPI_ResultParameter.h:34
Message that sends the failed vertices of 1D-fillet to highlight them in 3D viewer.
Definition: ModelAPI_Events.h:651
virtual MODELAPI_EXPORT ~ModelAPI_ShapesFailedMessage()
Default destructor.
Definition: ModelAPI_Events.cpp:461
MODELAPI_EXPORT ModelAPI_ShapesFailedMessage(const Events_ID theID, const void *theSender=0)
Creates an message.
Definition: ModelAPI_Events.cpp:456
MODELAPI_EXPORT void setShapes(const std::list< std::shared_ptr< GeomAPI_Shape > > &theVertices)
Sets list of failed vertices.
Definition: ModelAPI_Events.cpp:464
MODELAPI_EXPORT const std::list< std::shared_ptr< GeomAPI_Shape > > & shapes() const
Returns list of failed vertices.
Definition: ModelAPI_Events.cpp:469
Definition: ModelAPI_Events.h:658
Message that sends the sketch solver and sketcher GUI processes to show in the property panel.
Definition: ModelAPI_Events.h:578
MODELAPI_EXPORT const std::set< ObjectPtr > & objects() const
Returns list of conflicting constraints.
Definition: ModelAPI_Events.cpp:387
Sets degrees of freedom.
Definition: ModelAPI_Events.h:591
MODELAPI_EXPORT ModelAPI_SolverFailedMessage(const Events_ID theID, const void *theSender=0)
Creates an message.
Definition: ModelAPI_Events.cpp:373
MODELAPI_EXPORT void setObjects(const std::set< ObjectPtr > &theObjects)
Sets list of conflicting constraints.
Definition: ModelAPI_Events.cpp:382
const int & dof() const
Returns degrees of freedom.
Definition: ModelAPI_Events.h:593
virtual MODELAPI_EXPORT ~ModelAPI_SolverFailedMessage()
Default destructor.
Definition: ModelAPI_Events.cpp:379
