ModelAPI_Folder.h
20#ifndef ModelAPI_Folder_H_
21#define ModelAPI_Folder_H_
23#include <ModelAPI.h>
24#include <ModelAPI_Object.h>
31{
32public:
33 MODELAPI_EXPORT ModelAPI_Folder();
35 MODELAPI_EXPORT virtual ~ModelAPI_Folder();
36
38 static const std::string& ID()
39 {
40 static const std::string MY_FOLDER_ID("Folder");
41 return MY_FOLDER_ID;
42 }
43
45 inline static std::string group()
46 {
47 static std::string MY_GROUP = "Folders";
48 return MY_GROUP;
49 }
50
52 virtual std::string groupName()
53 {
54 return group();
55 }
56
58 static const std::string& FIRST_FEATURE_ID()
59 {
60 static const std::string MY_FIRST_FEATURE_ID("first_feature");
61 return MY_FIRST_FEATURE_ID;
62 }
63
65 static const std::string& LAST_FEATURE_ID()
66 {
67 static const std::string MY_LAST_FEATURE_ID("last_feature");
68 return MY_LAST_FEATURE_ID;
69 }
70
72 MODELAPI_EXPORT virtual void initAttributes();
73
75 MODELAPI_EXPORT virtual void execute();
76
78 virtual bool isDisabled()
79 { return false; }
80
81 //
82 // Helper methods, aliases for data()->method()
83 // -----------------------------------------------------------------------------------------------
85 inline std::wstring name()
86 {
87 return data()->name();
88 }
90 inline std::shared_ptr<ModelAPI_AttributeReference> reference(const std::string& theID)
91 {
92 return data()->reference(theID);
93 }
94
97 MODELAPI_EXPORT std::shared_ptr<ModelAPI_Feature> lastVisibleFeature();
98
99protected:
102 MODELAPI_EXPORT virtual void init();
103};
104
106typedef std::shared_ptr<ModelAPI_Folder> FolderPtr;
107
108#endif
Folder feature (groups the features).
Definition: ModelAPI_Folder.h:31
static const std::string & LAST_FEATURE_ID()
Attribute referring last feature in the folder.
Definition: ModelAPI_Folder.h:65
Definition: ModelAPI_Folder.h:45
Folder feature ID.
Definition: ModelAPI_Folder.h:38
virtual MODELAPI_EXPORT void initAttributes()
Request for initialization of data model of the object: adding all attributes.
Definition: ModelAPI_Folder.cpp:36
virtual MODELAPI_EXPORT void execute()
Computes or recomputes the results.
Definition: ModelAPI_Folder.cpp:42
Definition: ModelAPI_Folder.h:52
MODELAPI_EXPORT std::shared_ptr< ModelAPI_Feature > lastVisibleFeature()
Returns the last visible feature in the folder, passing through invisible, that may appear as the las...
Definition: ModelAPI_Folder.cpp:46
static const std::string & FIRST_FEATURE_ID()
Attribute referring first feature in the folder.
Definition: ModelAPI_Folder.h:58
std::wstring name()
Definition: ModelAPI_Folder.h:85
virtual MODELAPI_EXPORT ~ModelAPI_Folder()
To virtually destroy the fields of successors.
Definition: ModelAPI_Folder.cpp:28
Definition: ModelAPI_Folder.h:78
virtual MODELAPI_EXPORT void init()
This method is called just after creation of the object: it must initialize all fields,...
Definition: ModelAPI_Folder.cpp:32
std::shared_ptr< ModelAPI_AttributeReference > reference(const std::string &theID)
Definition: ModelAPI_Folder.h:90
Represents any object in the data model and in the object browser.
Definition: ModelAPI_Object.h:45
virtual std::shared_ptr< ModelAPI_Data > data() const
Definition: ModelAPI_Object.cpp:45
