ModuleBase_WidgetFactory.h
20#ifndef MODULEBASE_WIDGETFACTORY_H_
21#define MODULEBASE_WIDGETFACTORY_H_
23#include <ModuleBase.h>
24#include <ModuleBase_ModelWidget.h>
26#include <QString>
27#include <QList>
28
29class QObject;
30class QWidget;
34
40class MODULEBASE_EXPORT ModuleBase_WidgetFactory
41{
42 public:
47 ModuleBase_WidgetFactory(const std::string& theXmlRepresentation,
48 ModuleBase_IWorkshop* theWorkshop,
49 const std::string theAttributePrefix = "");
51
55 void createWidget(ModuleBase_PageBase* thePage, bool alignToTop = true);
56
60 void createPanel(ModuleBase_PageBase* thePage, const FeaturePtr& theFeature);
61
65 void createWidget(ModuleBase_PageBase* thePage,
66 const std::string& theWidgetId);
67
69 QList<ModuleBase_ModelWidget*> getModelWidgets() const
70 {
71 return myModelWidgets;
72 }
73
77 void getAttributeTitle(const std::string& theAttributeId,
78 std::string& theTitle);
79
82 void getGreedAttribute(std::string& theAttributeId);
83
85 const Config_WidgetAPI* widgetAPI() const { return myWidgetApi; }
86
87protected:
89 bool hasExpandingControls(QWidget* theParent);
90
94 ModuleBase_PageBase* createPageByType(const std::string& theType,
95 QWidget* theParent);
96
100 ModuleBase_ModelWidget* createWidgetByType(const std::string& theType,
101 QWidget* theParent = NULL);
102
105 static QString qs(const std::string& theStdString);
106
111 void moveToWidgetId(const std::string& theWidgetId, bool& theFound);
112
113 private:
115 Config_WidgetAPI* myWidgetApi;
116
118 ModuleBase_IWorkshop* myWorkshop;
119
121 QList<ModuleBase_ModelWidget*> myModelWidgets;
122};
123
124#endif /* ModuleBase_WidgetFactory_H_ */
Provides low-level API for WidgetFactory for reading xml definitions of widgets.
Definition: Config_WidgetAPI.h:46
Class which provides access to Workshop object services.
Definition: ModuleBase_IWorkshop.h:48
An abstract custom widget class.
Definition: ModuleBase_ModelWidget.h:60
Definition: ModuleBase_PageBase.h:35
A class for creation of widgets instances in for property panel using XML deskription of a feature.
Definition: ModuleBase_WidgetFactory.h:41
QList< ModuleBase_ModelWidget * > getModelWidgets() const
Returns list of model widgets.
Definition: ModuleBase_WidgetFactory.h:69
bool hasExpandingControls(QWidget *theParent)
check if ModuleBase_Widget has expandable widgets in getControls
const Config_WidgetAPI * widgetAPI() const
Returns widget API from XML.
Definition: ModuleBase_WidgetFactory.h:85
